Old May 27, 2012, 04:15 AM
YUSENWANG is offline
Find More Posts by YUSENWANG
Joined May 2012
TAIWAN TORNADO (7012) 70EDF Blades
7012 (70EDF Blades)
Blade dynamic balance doesn't disappear for disassembly, Rc player can optionally replace motor power
diameter: 68mm(7012-1)、69mm(7012-2)、70mm(7012-3)
number of blade: 12
weight of one blade: 68mm(15.1g)、69mm(16.1g)、70mm(17.1g)
dynamic balanced point:subtraction
shaft:3.17mm/1.7g & 4.0mm/1.7g
shroud:3.6g
www.tw-tornado.com E-mail:mail@tw-tornado.com
YUSENWANG is offline Find More Posts by YUSENWANG
Old May 27, 2012, 04:16 AM
Joined May 2012
7010 (70EDF Blades)
Aluminum alloy 7075-T6 CNC OR Aluminum alloy 7009 CNC
diameter: 68mm(7010-1)、69mm(7010-2)、70mm(7010-3)
number of blade:10
weight of one blade: 68mm(16.5g)、69mm(17.5g)、70mm(18.7g)
shroud:3.6g
Old May 27, 2012, 04:26 AM
Joined May 2012
TAIWAN TORNADO (7009) 70EDF Blades
7009 (70EDF Blades)
diameter: 68mm(7009-1)、69mm(7009-2)、70mm(7009-3)
number of blade:9
weight of one blade: 68mm(16.5g)、69mm(17.5g)、70mm(18.5g)
shroud:3.6g
TAIWAN TORNADO 2012 (0 min 16 sec)
台南銀座測試2 (2 min 21 sec)
HET 3300KV 1w40
14.8V TAIWAN TORNADO 3300KV 7009-3葉金屬 測試壓力秤.MTS (0 min 51 sec)
HET 2200KV 2W30
22.2V TAIWAN TORNADO 2200KV 6S.MTS (0 min 21 sec)
Old May 27, 2012, 04:57 AM
CoolerByTheLake is offline
Find More Posts by CoolerByTheLake
Do it Right, the first time!
CoolerByTheLake's Avatar
United States, MN, Hermantown
Joined Dec 2008
I guess test stands are out of style. So much easier to hold it in your hand!
CoolerByTheLake is offline Find More Posts by CoolerByTheLake
Old May 27, 2012, 05:20 AM
gianni sanchez is offline
Find More Posts by gianni sanchez
Belgium, Walloon Region, Mons
Joined Jan 2012
nice stuff man!
i sent an e-mail to u
gianni sanchez is offline Find More Posts by gianni sanchez
Old May 27, 2012, 05:28 AM
Joined May 2012
TAIWAM TORNADO 12012(120EDF Blades)
diameter: 118mm(12012-1)、119mm(12012-2)
number of blade:12
weight of one blade: 119mm(42g)、120mm(49g)
shaft:8.0mm/11.5g
shroud:13.5g
Old May 27, 2012, 05:29 AM
Joined May 2012
Taiwan tornado 90edf
90EDF CNC
length:180mm
weight:206.5g
Old May 27, 2012, 05:32 AM
Joined May 2012
TAIWAM TORNADO 9012(90EDF Blades)
9012(90EDF Blades)
diameter: 79mm(9012-1)、80mm(9012-2)
number of blade:12
weight of one blade: 79mm(29.5g)、80mm(32. 7g)
shaft:5.0mm/7g
shroud:9.5g
Fbcebook: https://www.facebook.com/tw.flight#!/tw.flight
Old May 27, 2012, 05:37 AM View Post
YUSENWANG
A moderator felt this post violated the following rule: Over-bumping. It is temporarily hidden while YUSENWANG edits it. Show it to me anyway.
Old May 27, 2012, 05:41 AM
Joined May 2012
TAIWAN TORNADO 9009 (90EDF Blades)
9009 (90EDF Blades)
diameter: 89mm(9009-1)、90mm(9009-2)
number of blade:9
weight of one blade: 89mm(24.8g)、90mm(27.8g)
shaft:5.0mm/7g
shroud:9.5g
Old May 27, 2012, 05:43 AM
Joined May 2012
TAIWAN TORNADO 9006 (90EDF Blades)
9006 (90EDF Blades)
diameter: 89mm(9006-1)、90mm(9006-2)
number of blade:6
weight of one blade: 89mm(22.7g)、90mm(25.7g)
shaft:5.0mm/7g
shroud:9.5g
Old May 27, 2012, 05:45 AM
Joined May 2012
TAIWAN TORNADO 8010 (80EDF Blades)
8010 (80EDF Blades)
diameter: 79mm(8010-1)、80mm(8010-2)
number of blade:10
weight of one blade: 79mm(21.3g)、80mm(24.3g)
shaft:5.0mm/7g
shroud:9.5g
Old May 27, 2012, 05:48 AM
alexandermh is offline
Find More Posts by alexandermh
alexandermh's Avatar
Fairborn, OH
Joined Nov 2009
No kidding. Don't try this at home kids.
alexandermh is offline Find More Posts by alexandermh
Joined May 2012
TAIWAN TORNADO 71mm EDF
71 EDF CNC
length:145mm
weight:116g
Old May 27, 2012, 05:52 AM
Joined May 2012
TAIWAN TORNADO 7006 (70EDF Blades)
7006 (70EDF Blades)
diameter: 68mm(7006-1)、69mm(7006-2)、70mm(7006-3)
number of blade:6
weight of one blade: 68mm(11g)、69mm(12g)、70mm(13g)
shroud:3.6g
Discussion Green Bay, Taiwan arthur0903 Slope 15 Mar 24, 2012 10:36 AM
Wanted Tornado 3 blade ( grish ) wanted M Spencer Aircraft - General - Miscellaneous (FS/W) 0 Sep 24, 2011 10:18 PM
Discussion BlitzRCWorks Tornado 3D vs. Blade SR RTF Tinytacohead 3D Electric Heli Flying 15 May 19, 2011 12:35 AM
Help! PLEASE HELP new user to Blade cx2 looks likes its in the middle of a tornado,Why? Morphisblazin Coaxial Helicopters 3 Apr 02, 2008 05:34 PM
