Old May 26, 2012, 02:41 PM
Mike_Then is offline
Find More Posts by Mike_Then
I hate waiting for parts
Mike_Then's Avatar
United States, NC, Garner
Joined Apr 2001
Question
What am I missing? CastleLink with disabled BEC on ICE 100...
Hopefully someone has the answer, because I am totally confused. I have installed a Castle ICE 100 in my T-Rex 600e. It is connected to a y-harness... the male end is plugged into the receiver, and the other female end is meant for plugging into the CastleLink. I disabled the BEC by removing the red/middle wire from the male end of the y-harness. As far as the radio is concerned, the ESC works fine.
Here's my problem: I cannot use the CastleLink programmer while the ESC is plugged into the receiver. When I plug the CastleLink into the y-harness, the ESC will give the power-up tones and count two cells. It's very faint but it's audible. When I plug a battery into the power leads of the ESC (first a 3-cell then a 5-cell), nothing happens. I then pulled the red wire from the extension that plugs into the y-harness (the male-male cable that goes between the CastleLink and the y-harness). The ESC no longer makes weak power-up sounds. I plugged a LiPo into the power leads and the ESC powers up like normal with a strong, loud tone. The CastleLink still does not connect.
The y-harness accidentally came out of the receiver and then everything worked fine. I thought that was strange as that shouldn't have anything to do with it. The whole point of the y-harness is that the receiver is very difficult to get to, and I'd like to easily make adjustments to the ESC at the field.
What am I doing wrong? Any suggestions are appreciated... thank you!
Mike_Then is offline Find More Posts by Mike_Then
Latest blog entry: F-14 resurrection
Old May 26, 2012, 04:11 PM
_Peter is online now
Find More Posts by _Peter
Gotta Luv Gasser Helis..
_Peter's Avatar
Gold Coast, Qld , Australia
Joined Apr 2006
normal Y harness won't work , you need the CC y harness to isolate the rx from the castlelink.....
http://www.castlecreations.com/produ...k_connect.html
_Peter is online now Find More Posts by _Peter
Old May 26, 2012, 06:23 PM
RC Man is offline
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I standard Y-harness will never work for that purpose.
To do what you want you need a Castle Link Quick Connect. http://www3.towerhobbies.com/cgi-bin...?&I=LXZYU2&P=7
To disable the BEC you remove the red wire from the connector that goes to the receiver. After that everything should work just as you want it to.
I use the Castle Link Quick Connect on most all my ESCís as it makes it much easier to view the logs, change parameters and upgrade firmware.
RC Man is offline Find More Posts by RC Man
Old May 26, 2012, 08:16 PM
Mike_Then's Avatar
Joined Apr 2001
Thanks for the replies; guess I will have to pick one of those up. Never would have figured that out...
Sold SOLD Castle Creations ICE 100 with CC Pro BEC Bonestockz06 Aircraft - Electric - Power Systems (FS/W) 2 Feb 07, 2012 09:02 PM
Sold Castle Creations ICE 100 with Castle 20 amp BEC sdimaio Aircraft - Electric - Power Systems (FS/W) 1 Jan 30, 2012 08:57 AM
Question Am I on the right track? (Brand new build, what am I missing) molish FPV Talk 22 Sep 09, 2011 09:29 AM
Discussion Is the built in 5A BEC on CC ICE 100 as powerful as the CC BEC on 6s? cleansho93 Electric Ducted Fan Jet Talk 12 Mar 15, 2011 03:53 PM
Discussion Is the built in 5A BEC on CC ICE 100 as powerful as the CC BEC on 6s? cleansho93 Foamy EDFs 0 Mar 15, 2011 12:29 AM
