Old Feb 21, 2013, 12:45 PM
jtprouty is offline
Find More Posts by jtprouty
Inherent Tinkerer
Wichita, Kansas, USA
Joined Jul 2003
Actually, I think what I wanted to ask is are they "serial UART" ie, the same serial data interface as the XBees?
Jimmy
jtprouty is offline Find More Posts by jtprouty
Old Feb 21, 2013, 05:11 PM
Seppos is offline
Find More Posts by Seppos
Australia, QLD, Brisbane
Joined Nov 2011
Hello Jt,
The RFD900s have a standard hardware serial port (UART) which is electrically the same as on XBees etc. -
It is a TTL level serial port, it can accept 3.3v, or 5v signals. If you want to connect to an RS232 port, you will need a level translator, which will convert the +/- ~9-~12v RS232 signal levels to +5, or +3.3v...
Hope it helps!
Seppos is offline Find More Posts by Seppos
Old Mar 01, 2013, 01:42 AM
stilp is offline
Find More Posts by stilp
Australia, QLD, Logan
Joined Aug 2011
Fyi: I've visited Seppo twice (at work), bought a fair bit of his gear and found him to be a pleasure to deal with. His service is efficient, he's very patient with my many questions, considerate of my requirements and reasonable with issues. And a thorough gentleman, to boot. M.02
stilp is offline Find More Posts by stilp
Old Mar 01, 2013, 07:05 AM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
We're going to start carrying the RFD900's as an option for our systems and I've also found the Seppo is very responsive to answering requests for assistance with his products. Really appreciate the support!
Jimmy
Old Mar 10, 2013, 09:37 AM
keeyen is offline
Find More Posts by keeyen
Joined Jul 2012
Reasonable noise level
Hi Seppos
I got my RDF900 few weeks ago and today I try a 2 KM flight at 200 meter ASL. The link is solid throughout the flight but upon check with Mission Planner graft log, the remnoise radio and rssiradio is almost touching. The remnoise level is about 100. I would like to know if the noise level is acceptable or I'll have to move around with the antenna.
The initial signal level is at about 220, the drop to 100 at the 2 KM turning point. The link drop may due to this is not a LOS flight. There is a hill about 80 meter high 500 meter in front of us.
keeyen is offline Find More Posts by keeyen
Old Mar 10, 2013, 10:00 AM
jtprouty is offline
Inherent Tinkerer
Joined Jul 2003
I would bet that it's an LOS issue. 2 km at 200m can be challenging even on flat terrain. The further out you go, the higher you have to be.
Jimmy
Old Mar 11, 2013, 06:47 AM
Seppos is offline
Joined Nov 2011
Hi Keeyen,
the remote noise level is quite high, so definitely relocating the antennas is worth looking into. Typical noise levels can get to 60 or so, depending on whats around. What was the localnoise level at? If you are able to fit the dipole antenna into the airframe, it is worth using it as it has it's own ground reference and will not couple as much noise through the feed coax. The hill will definitely reduce coverage as well..
Cheers,
Seppo
Originally Posted by keeyen View Post
Hi Seppos
Old Mar 11, 2013, 09:56 PM
keeyen is offline
Joined Jul 2012
Thanks for the answer. I'm not quite sure about " fit the dipole antenna into the airframe " are you means fit the antenna directly into the radio modem without extension? I install both the monopole and dipole antenna into the modem. Is it better to use only one dipole ?
Old Mar 11, 2013, 11:32 PM
Seppos is offline
Joined Nov 2011
Hi Keeyen,
I meant that if there is enough room in the airframe, to use a dipole is preferred if possible.
The monopole connected directly to the modem will utilise the modem and attached wiring as the antennas ground reference - this will couple more noise into the receiver, giving higher remnoise levels... It would be better in this case to use only one dipole in the airframe.
To get the best performance out of a monopole, a groundplane on the external surfaces of the airframe is needed with a bulkhead connector mounting the monopole externally.
Seppo-
Old Mar 13, 2013, 03:36 PM
Jdmagoo is online now
Find More Posts by Jdmagoo
Australia, SA, Adelaide
Joined Aug 2012
Hi all,
Just wondering if anyone has had experience with this and the autoquad FC? Are there any issues? Has anyone managed to carry out a range test?
Also, mounting on a hexakopter frame what antenna's are recommended? I'm guessing two dipole 3db antennas facing down located on opposite arms would be ideal? Or is it better to have 1 dipole and 1 monopole located on opposite arms?
Cheers
James
Jdmagoo is online now Find More Posts by Jdmagoo
Old Mar 17, 2013, 03:40 PM
Copenhagen is offline
Find More Posts by Copenhagen
Joined Mar 2013
RFD900 max data throughput?
Hi all,
RFD900's max air data rate is given as 250kbit/s, but seeing that it's UART interface is max 115200 baud, I guess that the max data throughput becomes 115200 bit/s in any case. I know that 1 baud is not always = 1 bit but given no other information to go on, it would seem to be the case here, right?
Regardless of the above, would it be possible to operate 2x2 RFD900 on different freq's in parallel if one wanted more data thoughput?
Cheers,
C
Copenhagen is offline Find More Posts by Copenhagen
Old Mar 17, 2013, 11:36 PM
Seppos is offline
Joined Nov 2011
HI Copenhagen,
Yes, we have successfully run 2 modems in one air platform - There was a notable increase in sporadic noise levels when the channels clashed from time to time, but maintained link well at around 7km. The best way to test it is to try it in your application - we were sending Mavlink telemetry data so the link was not heavily loaded.
Hope it helps,
Seppo..
Old Mar 18, 2013, 03:29 PM
Joined Mar 2013
RFD900 max data throughput, 2x2 RFD900
Hi Seppo,
Thanks for the info! A 2x2 setup could be a useful option then.
Regarding the max data throughput, is it that 250kbit/s is a theoretical limit of the si1000 tranceiver while the uart 115200 baud is closer to the practial max transfer rates, given various losses? Or can true 250 kbit/s be realized under optimal conditions (modest range, good antennas, LOS etc) if e.g. the uart is disabled and flow-control is done by e.g. a external embedded computer connected to the RFD900? Or even if just bit-banged, if assuming optimal RF conditions?
Cheers,
C
Old Mar 25, 2013, 09:55 AM
nick.sargeant is offline
Find More Posts by nick.sargeant
Perth, Western Australia
Joined Dec 2005
Seppos.
Any update on the RCLink?
Regards,
Nick
nick.sargeant is offline Find More Posts by nick.sargeant
Old Mar 27, 2013, 07:40 PM
Seppos is offline
Joined Nov 2011
Hi Copenhagen,
The 250kbit/s is the maximum supported air data rate, and 115200 is the maximum supported serial interface rate. Going extreme, it may be possible to feed in more data via other ports and get that across the air at 250k. There is a slight amount of packet overhead, at an estimate around 10-15%, so around 200kbit/s may be an upper limit. Not exactly sure as haven't looked into it for a while.
Cheers!, Seppo
Originally Posted by Copenhagen View Post
Hi Seppo,
Cheers,
C
Discussion Range of 2.4GHz RF Modem? GuerillaFilm FPV Talk 1 Apr 18, 2013 06:06 PM
Discussion 12ch Radio relay for wireless long range UHF ground station i3dm FPV Talk 0 Mar 22, 2012 03:20 AM
Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX crashtested FPV Equipment (FS/W) 7 Mar 11, 2012 05:32 PM
Discussion Radio Frequency for Long Range? AeroWRX FPV Talk 3 Feb 13, 2012 10:36 PM
