Gurgaon - India
Joined Jul 2009
RFD900 tested for 58.5KM @57600 baud on APM1
RFD900 tested for 58.5KM @57600 baud on APM1, done ten times read & write of 50 Waypoints sucessfully, one location was at ground (285mt from sea level) and other location was in hilly area in Kasauli at 1865mt from sea level. 3dBi, single antenna used on both modems.
Amazing performance. http://diydrones.com/forum/topics/rf...ource=activity |
Joined Feb 2012
Australia, QLD, Brisbane
Joined Nov 2011
Hi narpat007 - Wow, that is an awesome result !
From those figures you should be able to exceed 100km using 2x 6dBi yagis at each end - providing there is clear enough line of sight between them... Hmmmm, wonder who will the first to break 100km
Gurgaon - India
Joined Jul 2009
Hi Saario !
Infact I had taken 13dBi yagi with for testing this, I was thinking that for such long range, there would be requirement of 13dBi Yagi but I was surprised and it was just unbelievable to see the results without Yagi. There is clear line of sight between the two tested points. because one point is at 1865mt from sea level. In 1991, I made a 500 mW TV transmitter made of all hand made coils, and all discrete components Transistors 2N3866. At that time I was a school boy of higher secondary level. At the TV side, I used high gain UHF booster with high gain Yagi antenna and got clear reception from these two points only from where RFD900 is tested. Regards Rana |
Joined Nov 2011
Hi Narpat007,
Would you by chance have the rssi and noise levels for the radios at this range? It would be interesting to compare it with theory to see how much link margin there was remaining. If you use the commands +++ (wait one second till you get OK) AT&T=RSSI it will give you local and remote RSSI and noise levels. Cheers, Seppo |
Gurgaon - India
Joined Jul 2009
Hi Seppo !
That place is in the country side, far away from my present location. I have been to that place after many years. Regards, Rana Quote:
Other than the info on this page: http://rfdesign.com.au/index.php/rfd900
Are there any more clear setup and connection instructions? I'm trying to hook the modem up to a APM2 - and USB/Win7 on the Ground side. |
Joined Nov 2011
Hi Oso M,
The pinout across the serial port is the same order as on the FTDI cables and 3DR radios. Their wiki has some nice pictures of a connection which is the same as the RFD900 across the serial port. http://code.google.com/p/ardupilot-mega/wiki/3DRadio I will make a few good diagrams showing the connection to APM1/2 shortly. Cheers, Seppo |
I have the two RFD900s powered up and am getting a solid green light. I assume that means the two radios are linked up. When I jump the UART 0/2 pins from the APM to the RX/TX ins on the RFD (pins 7 & 9) I get a blinking red light, I assume this means I'm sending data. On the RFD that is connected to my laptop I have a solid green light. and the data/activity light is blinking, but it is very very dim compared to the other modem connected to the APM. |
| Thread Tools | |
| Discussion Range of 2.4GHz RF Modem? | GuerillaFilm | Video Piloting (FPV/RPV) | 1 | Apr 18, 2013 06:06 PM |
| Discussion 12ch Radio relay for wireless long range UHF ground station | i3dm | Video Piloting (FPV/RPV) | 0 | Mar 22, 2012 03:20 AM |
| Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX | crashtested | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 11, 2012 05:32 PM |
| Discussion Radio Frequency for Long Range? | AeroWRX | Video Piloting (FPV/RPV) | 3 | Feb 13, 2012 10:36 PM |
