Brisbane
Joined Aug 2007
Seppo is a bit reticent to push the temperature higher, because even though he doesn't mind sacrificing a module (FOR SCIENCE!) the testing cables are another story... |
Australia, QLD, Brisbane
Joined Nov 2011
RFD900 at 125deg !
Prior to releasing RFD900 modems, I had done high temperature testing up to 90 deg C with nil adverse effects. This was sufficient to satisfy specification requirements, but was not an absolute test.
Test setup: Duty cycle limiting disabled, Vcc=5.0V, Radio set to maximum output power, monitoring current consumption, power output, and AT&T=RSSI on the radio. Sending "0123456789" repeatedly. With this we can read the radio temperature on the CPU die, using its internal temp sensor. (uncalibrated at the moment, but a reasonable indication) After some careful roasting in the environmental chamber, the limit at which RFD900s drop link is at 125deg C . Up to this point, they work fine, with a gradual decay in output power, and approx 8dB or so reduction in RSSI level.The output power gradually dropped from 29.5 at 25 degC, down to 27.3 at 120degC. Below are some pics of the modem in the chamber at 120degC. The cool thing is, after cooling back down, the modem started working normally ! I am sending it back down to -70 degC to see what happens. This kind of *really* extreme testing is completely over the top, but kind of fun !. End result: I couldn't kill the RFD900 ! and melted strain relief boots on my nice test cables.PS: More information on how duty cycle offset (DCO) works... During the transmit cycle, the radio monitors the radio temperature and if it exceeds a preset threshold (70degC for currently released modems), it will gradually reduce the duty cycle to maintain 70 deg C on the radio. You can see what the duty cycle offset it by typing in AT&T=RSSI in command mode. The last parameter (dco= ) will tell you what the offset is in (%). The maximum offset is 80%, which will still allow data to go through, without risking damage. From these results, it can be seen that I have been very conservative, and this limiting temperature can be comfortably raised to 100 degC. Typical difference between the CPU temperature and heatsink temperature are around 15 deg C. The maximum junction temperature on the PA is around 150degC so there is good margin with most normal applications. PPS2: Operating an RFD900 at these extremes is completely out of specification and not recommended. Standard disclaimer: *Don't try this at home*
Gurgaon - India
Joined Jul 2009
I am very glad to see the results of the RFD900 at high temperature extreme conditions. Its very great thing about this modem that even if the temperature in the testing exceeded 125degC, the modem shut down and again started when it cooled down below that temperature.
In fact such high temperature conditions will never come, most people consider +85degC the highest point for normal operation of any RF Modem. Let me tell you this modem is going to hit in the FPV and UAV market very high and this product will be the largest revenue generating product of your company. Suggestions for future enhancement; 1. For commercial UAV application, the the telemetry data needs to be encrypted so that hackers can not hijack it. If encription option is already there, then its great. 2. Point to point and point to multipoint network topologies should be supported so as to find place of this modem in the industrial use as well. If it is already there, then its great. 3. Benchmark product for point 1 & 2 could be DNT900. Many many thanks for shipping my pair of RFD900 modems within 4 hours of making the the payment. Even big MNC's can,t meet such fast shipping. |
Gurgaon - India
Joined Jul 2009
Folks, I have received mine today, quality of manufacturing is really majestic.
It worked out of the box with APM 2560 board, loaded with Arducopter 2.71 firmware. It is even working with the pair of 3DR Radios I bought from DIY Drones. |
Joined Nov 2011
Hi narpat007,
Thanks for your feedback!. Looking forward to hearing how you find the performance in your application. We have a distributor in Thailand, Jani Hirvinen from Jdrones ( jdrones.com ) who has modems listed in $USD. Modems from Australia are sold at $AUD. These days, the exchange rate is pretty close to 1:1, but for those who prefer USD, that option is available. We are also gearing up for the next build of modems to make sure they are always available from stock. To date, 99% of orders placed before 1pm Australia time (UTC+10), get shipped the same day, we aim to keep it that way !
Gurgaon - India
Joined Jul 2009
Hi Seppos !
My GPS getting locked without any issue even when the RFD900 modem is operating at distance of hardly one feet. Long Range performance is yet to be checked, for checking this I will use 13dBi Yagi antenna at the ground station and 5dbi omni whip antenna in the air. But since there is rainy season in northern part of our country, till October end, so really difficult to find chance. |
Joined Nov 2011
The latest firmware has updated temperature limiting thresholds set to 100 deg, from 70 deg. This will let the board transmit at full power, maximum duty cycle to the rated temperature of the RFD900 of +85degC. Above this temperature, the modem will start to limit the transmitter duty cycle. Based on earlier testing, this is still a safe limit.
| Thread Tools | |
| Discussion Range of 2.4GHz RF Modem? | GuerillaFilm | Video Piloting (FPV/RPV) | 1 | Apr 18, 2013 06:06 PM |
| Discussion 12ch Radio relay for wireless long range UHF ground station | i3dm | Video Piloting (FPV/RPV) | 0 | Mar 22, 2012 03:20 AM |
| Sold Short Range - Long Range ! 2x Lawmate receivers, 1x 1000mw VTX & 1x 50mw VRX | crashtested | FPV/RPV - Equipment and Vehicles (FS/W) | 7 | Mar 11, 2012 05:32 PM |
| Discussion Radio Frequency for Long Range? | AeroWRX | Video Piloting (FPV/RPV) | 3 | Feb 13, 2012 10:36 PM |
