Old May 25, 2012, 11:31 PM
giantkevmiester is offline
Find More Posts by giantkevmiester
United States, CO, Lakewood
Joined May 2011
Help!
is using a high temp glue gun to cut foam hazardous to my health
i have recently been using a high-temp glue gun to make the edges smooth instead of sanding them. I am melting fan-fold foam, and i am wondering if it might be bad for me, as I am usually naeseated afterwards.
giantkevmiester is offline Find More Posts by giantkevmiester
Old May 25, 2012, 11:58 PM
KE Spin is offline
Find More Posts by KE Spin
Shore Huckin'
KE Spin's Avatar
Ohio
Joined Aug 2010
YES!!!!!!! EPP fumes (from burning/melting) can blister the throat and breathing passages...not sure about fan fold but certainly not a good idea to inhale those fumes either. Adequate ventilation is essential!!!!!!
KE Spin is offline Find More Posts by KE Spin
Old May 27, 2012, 02:20 PM
ozmo01 is offline
Find More Posts by ozmo01
ozmo01's Avatar
USA, MO, Ozark
Joined Nov 2006
From an rn
YES VENTILATION IS A MUST
ozmo01 is offline Find More Posts by ozmo01
Old May 27, 2012, 09:16 PM
javier668 is offline
Find More Posts by javier668
Chile, Araucanía, Angol
Joined Jan 2012
Is very nocive, if you love your life use a fan or go to ventilated area.
Regards!
javier668 is offline Find More Posts by javier668
Old May 28, 2012, 09:37 AM
A_Pilot is offline
Find More Posts by A_Pilot
A_Pilot's Avatar
Joined Apr 2009
Fan on, window open.
A_Pilot is offline Find More Posts by A_Pilot
Old May 28, 2012, 11:37 AM
Joined May 2011
oh thats ok then because i am working in a very welll ventilated are (3 windows open on one side of the room, and 2 on the other).
Sold Low Temp Glue Gun flyarmy58 Aircraft - General - Miscellaneous (FS/W) 1 Aug 27, 2011 03:19 PM
Discussion Hot glue gun - which glue to use? (and other industrial supply tidbits) Dan_K Beginner Training Area (Aircraft-Electric) 7 Oct 27, 2008 04:07 PM
Question Can I use a hot glue gun instead of GOOP when building battery pack? Yen Batteries and Chargers 9 Sep 23, 2008 07:44 PM
Question What is the best glue to use on High Density Bead Foam? HL "LYNX XF" Flyextreme Pusher Prop Jet Models 1 Feb 16, 2008 11:46 AM
What cut-off temp to use for Triton thermal probe? Peter Young Batteries and Chargers 2 Jun 15, 2003 05:52 PM
