Old May 30, 2012, 12:42 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
Originally Posted by krikkens View Post
what type of paint is it ? i looked at their website but can't find it.
does it require a air-feed mask and special clothing to work with it ? i just got a simple mask and airvent...
-kristof-
It's this stuff.
Here is the MSDS for the clear-coat.
According to the MSDS a properly fitting mask with the correct organic/particulate filter is suitable. No fresh-air set-up is required.
wyowindworks is offline Find More Posts by wyowindworks
Old May 30, 2012, 02:16 PM
krikkens is offline
Find More Posts by krikkens
Joined Aug 2009
Originally Posted by wyowindworks View Post
It's this stuff.
thanks, couldn't find the msds....
krikkens is offline Find More Posts by krikkens
Old Jul 03, 2012, 10:09 PM
tpczx6 is offline
Find More Posts by tpczx6
tpczx6
tpczx6's Avatar
USA, CA, Fremont
Joined Oct 2005
great info
tpczx6 is offline Find More Posts by tpczx6
Old Jul 13, 2012, 01:47 AM
ron gijzen is offline
Find More Posts by ron gijzen
ron gijzen's Avatar
Liempde, Netherlands
Joined Jul 2007
Almost any spray can lacquer will work. The key is spraying the first coat very lightly, let it set (doesn't take long), then shooting a slightly heavier coat, let it set (doesn't take long), then a heavier coat. If you use a heavy coat right off the bat it will fish-eye.
The problem with rattle cans is that it's harder to control the light mist coats. With a gun you can set the stop on the product release needle so very little product is released from the gun. Then the next coat you can open the stop a little further and so on.
Adam
I recently followed a 3-day composite workshop with a european commercial model builder. He recommended the 2K PU "In Mould" paint of Breddermann.
This paint, as opposed to many ' car' paints, has no silicones that migrate to the surface during curing, so it can be left in the mold a long time before the lay-up.
My question is about the fish-eying with a heavy coat: does applying a light mist, wait a few minutes, than another etc etc still work with a 2K paint? I mean, the cure time is the same for all the layers and started when the paint was mixed. It seems pointless to wait for a layer to 'dry' since there is no solvent to evaporate? Needless to say I got fish-eyes with my first attempt spraying 2K
ron gijzen is offline Find More Posts by ron gijzen
Old Jul 13, 2012, 08:36 AM
Just fly it!
Cody, WY
Joined Nov 2007
2K paints still have solvent carriers that need to evaporate. Even the high performance high solids polyurethane 2Ks are only about 40% solids. This means that 60% of the solutions needs to flash off. This is why manufacturers want you to wait between coats when spraying 2K. You want the solvent from each coat to flash off before the next coat is applied otherwise you risk entrapping the solvents causing the paint to never cure properly. Even epoxy paints are not 100 percent solids.
Spraying 2K is more problematic than single components. I use a high velocity paint and a heat box to force cure the mist coats. Some people will also further/over reduce the paint as well.
Old Jul 13, 2012, 09:43 AM
Dbox is offline
Find More Posts by Dbox
One Idiot is plenty...
Dbox's Avatar
United States, OR, Portland
Joined Jun 2005
Ron.
What he was using for mold release ?
Thanx.
Yuri.
Dbox is offline Find More Posts by Dbox
Old Jul 13, 2012, 03:07 PM
gideon is offline
Find More Posts by gideon
Meek A Mouse
Deutschland, BW, Stuttgart
Joined Aug 2004
To disclose a secret: this is a regular 2K polyurethane paint, used in a different mixing ratio. The latter enables a good bond to epoxy, even some days later
Thatīs all!
I have to admit that this system is working quite well, though
I really donīt think that regular car paints contain any silicone. This must be a myth or just ignorance
W 70 is recommend as release agent
gideon is offline Find More Posts by gideon
Old Jul 13, 2012, 04:44 PM
Dbox is offline
Dbox's Avatar
Joined Jun 2005
Please give us more information on W 70 mold release.I could not "Google" it.
Thanx.
Yuri
Old Jul 13, 2012, 06:05 PM
krikkens is offline
Joined Aug 2009
Thanx.
Yuri
hi i think he refers to norpol w70
-kristof-
Old Jul 14, 2012, 08:06 AM
gideon is offline
Meek A Mouse
Joined Aug 2004
There are different names and distributors for it, but just one manufacturer: http://www.oskars.biz/de/index.html
M-700 is the original name
Question Clear Coat Options Blue Falcon Painting and Finishing Tips 4 May 10, 2012 04:59 PM
Discussion Clear coat. 420TEE Scale Boats 2 Mar 11, 2012 02:40 PM
Discussion Clear Coating Before or After Color Sanding? FoamCrusher Painting and Finishing Tips 8 Feb 01, 2012 11:31 AM
Discussion Clear coat houseboat 3D Foamies 4 Jan 23, 2012 03:18 PM
Clear Coat - Yay or Nay? screamin' eagle Slope 8 Oct 17, 2005 09:12 AM
