Old May 25, 2012, 03:09 PM
krikkens is online now
Find More Posts by krikkens
Joined Aug 2009
1k or 2k clear coat?or gel-coat?
hi ,
what are the benefit's of 2k paint over 1k?
can i use a spray can to bring color on a 2k clear coated mold?
and what about gel-coat?
i guess there are diffrences in 2k clear coat , wich one to use?
i'm looking for high gloss ultra durable 2k clear..
special safety precautions need to be taken? just experimented with this one:
http://www.fishermotorfactors.co.uk/...cquer-hardener
my eyes got a bit irritated during spraying , maybe this stuff is to aggresive ? are there other options?
are there people who tried several stuff? what do they think? pro's , con's..
thanks
-kristof-
krikkens is online now Find More Posts by krikkens
Old May 26, 2012, 05:17 PM
heliwill10 is online now
Find More Posts by heliwill10
heliwill10's Avatar
Greensburg, PA
Joined Feb 2008
Humm..
2k is going to be more durable than a spray can. Not sure what your asking?
Are you wanting to clear a mold then add spray paint over top? That might work or just buy a 2k paint.
I've had good luck with shop line ppg clear coats....
Safety.... You need gloves, respirator, and a well ventlated area, or paint outside.
heliwill10 is online now Find More Posts by heliwill10
Old May 26, 2012, 05:23 PM
Joined Aug 2009
Originally Posted by heliwill10 View Post
Humm..
hi , i think you can add glasses to that list !
and the respirator should have a carbon filter, no?
yeah , i would like to use a spray can on the clear , and wan't a 2k clear for it's durabilty and a spray can color for it's simplicity , i only paint small area's with 2,3or 4 color's , it would be a pain to mix some up for such a small thing..
i know a gelcoat is used by many but i don't like the fact it yellow's...
-kristof-
Old May 26, 2012, 06:10 PM
Jim.Thompson is offline
Find More Posts by Jim.Thompson
Entropy is happening!
Jim.Thompson's Avatar
Australia, NSW, Bellingen
Joined Aug 2008
What are you planning to spray paint Kristof?
Jim.Thompson is offline Find More Posts by Jim.Thompson
Last edited by Jim.Thompson; May 26, 2012 at 06:10 PM. Reason: spelling correction.
Old May 26, 2012, 06:48 PM
Joined Aug 2009
a dlg wing , painted in the mold
this one has quit a bit of color on it , isually i just paint the wingtips
Old May 26, 2012, 07:55 PM
Joined Aug 2008
Kristof,
The reason that I asked was to get some impression of what the paint has to withstand etc.
On my slopers, I use all single pack acrylic lacquer. This is mainly due to the advantage of it's ease of touch up after dings etc. Slopers often have a hard life, as you no doubt know.
I have no experience with DLG's, but expect they fare much better in this regard. However, weight is your main concern is it not? In which case I assume you want fewer coats rather than more. One coat of either a good quality 2 pack or a single pack acrylic lacquer might be best choice for you? I'm guessing the latter would be very light, as it can go on very thin. Relatively less risk to the operator to spray. (than the 2 pack). Also cheaper and does not go off if you don't thin any more than what is required for the job. When thinned, it has a limited shelf life.
Jim.
Old May 26, 2012, 08:40 PM
wyowindworks is offline
Find More Posts by wyowindworks
Just fly it!
wyowindworks's Avatar
Cody, WY
Joined Nov 2007
2K vs. 1K Clear-coats
2K Clear-coats - Urethanes, Epoxy-based
+ More durable
+ More resistance to solvents
+ Often blocks UV rays that slow fiber and resin degradation
+ Can be rapid cured with IR light and hot-boxes (15 minutes)
+ Spray very nicely and flow out well (not necessary for in mold coatings)
- More expensive
- Required mixing, mixing cups, sticks for every use.
- Require gun cleaning after every use
- Often contain Iso's within the hardener that can be very harmful. Almost every manufacturer and instructor recommends a fresh air supply respirator rather than a canister respirator.
- Can take quite a while to cure before the layup can be performed if left at room temp.
- Can be more difficult to spray onto semi-permanents and wax only
- Can be heavier than 1K
1K Clear-coats
- Rattle cans, sprayable lacquers,
+ Inexpensive compare to 2K paints
+ Convenient if in rattle cans
+ Sprayable clear-coats can be left in gun for weeks if the gun and cup seal well. This cuts down on gun clean-up in a production setting.
+ Are easier and faster to apply on semi-permanents and wax only releases
+ Lacquers can set up at room temp and be ready for layup in 20 minutes.
+ Can be lighter than 2K
+ Typically aren't as harmful as 2K urethane formulations and only require a canister respirator.
- Little solvent resistence
- Less durable
- Typically offers no UV protection.
- Are more difficult to spary (not a problem for in mold coatings)
You can spray almost any color paint on top of a clear-coat. The color needs to be applied within the re-coat window. Many 1K clear-coats can be re-coated at anytime (after flashing has occurred). Most 2K clear-coats have a re-coat window of 1 to 24 hours depending on the cure velocity.
Gel-coats are not very favorable for DLGs or most RC aircraft use. Gel-coat needs to sprayed to required thickness to cure properly. If it's not applied thick enough you will end up with host of problems. Usually you need to spray it to a thickness of .010 to .020 to get a proper cure. Since DLG laminates are often thinner than this (wings, tails) the added weight can astronomical. Most of the clear-coat applications that I use on DLG fuses, for comparison, is less than .0005". It's also prone to micro-cracking because it's very brittle. Since gel-coat is polyester based there can be interface issues with epoxy resins. The gel-coat has an air-inhibited cure...meaning that the surface that exposed to the air will remain tacky and uncured. This is great for polyester layups since the layup resin will now chemically bond to and cure out the gel-coat. This tacky state can cause epoxy interface issues that requires some testing.
On DLG parts I typically use 1K lacquer based clear-coats out of a spray gun. I will typically only clean the gun once every two weeks when I'm in full production mode. The urethane based 2K clear-coats can be noticeably heavier and take more time to apply....at least on top of semi-permanent releases. You can get 2K urethane to be light but it takes some timely, careful techniques that require IR lamps or safe hot-boxes in the spraying area to control heat but evacuate the harmful fumes.
wyowindworks is offline Find More Posts by wyowindworks
Old May 27, 2012, 12:08 AM
Joined Aug 2008
............................. I will typically only clean the gun once every two weeks when I'm in full production mode. .............
Is your gun gravity feed or a syphon type Adam?
Mine is syphon with an air vent (or course) on top of the pot. I wonder how long I could leave the paint in it?
Good report!
Jim.
Old May 27, 2012, 12:10 AM
Just fly it!
Cody, WY
Joined Nov 2007
Good report!
Jim.
Jim, I have a gravity feed gun. There is a vent on top of the cup but it also a vent plug.
Old May 27, 2012, 12:14 AM
Joined Aug 2008
Ahh! That is smart.
edit: Just by the way (off topic), I bought myself one of these little guns some time ago which is proving really good for detail work when the airbrush is just a bit too small.
http://www.ebay.com.au/itm/125-ml-Sp...item3a6c07a8a3
Old May 27, 2012, 01:45 AM
Joined Aug 2009
hi,
thank u for the help!
adam, i use spray can clear coat now but the main reason i wan't to move away from it is tha fact it ain't waterproof , water seems to go thru this...
gel-coat is used is used for dlg's sal-peter for instance , i contacted my supplier about this and he said it can be diluted 50% and you need much more harder .
it will need a cure at elevated temprature tough.
main advantage is it will be ready to lay-up for month's and the epoxy will stick to it well.
i didn't knew there was 1k for a spray gun , thanks ! it will reduce my pile of empty rattle can's every clean-up!
-kristof-
Old May 27, 2012, 02:48 AM
Joined Aug 2009
hi,
just pulled out a test part with 2k clear.
i think the clear is just to aggressive , i couldn't pull off the thick pva coating as it was bonded to the clear .
i couldn't even wash it of with warm water and soap , it remained feeling "greasy" .
-kristof-
Old May 27, 2012, 07:14 AM
JIM CALDWELL A is offline
Find More Posts by JIM CALDWELL A
Cleveland Cuyahoga, Ohio, United States
Joined Dec 2000
Has anybody found a spray can clear that works well on 770NC??
JIM CALDWELL A is offline Find More Posts by JIM CALDWELL A
Old May 27, 2012, 09:17 AM
tom43004 is offline
Find More Posts by tom43004
Father of Fr3aK, DLG Pilot
tom43004's Avatar
USA, OH, Worthington
Joined May 2002
Jim,
With very light coats I've had good luck painting over 770-NC but heavier coats always bead up. I generally use the "painters touch" sold at HD for my quick color needs.
tom43004 is offline Find More Posts by tom43004
Old May 27, 2012, 10:50 AM
Just fly it!
Cody, WY
Joined Nov 2007
Almost any spray can lacquer will work. The key is spraying the first coat very lightly, let it set (doesn't take long), then shooting a slightly heavier coat, let it set (doesn't take long), then a heavier coat. If you use a heavy coat right off the bat it will fish-eye.
The problem with rattle cans is that it's harder to control the light mist coats. With a gun you can set the stop on the product release needle so very little product is released from the gun. Then the next coat you can open the stop a little further and so on.
Adam
Question Clear Coat Options Blue Falcon Painting and Finishing Tips 4 May 10, 2012 04:59 PM
Discussion Clear coat. 420TEE Scale Boats 2 Mar 11, 2012 02:40 PM
Discussion Clear Coating Before or After Color Sanding? FoamCrusher Painting and Finishing Tips 8 Feb 01, 2012 11:31 AM
Discussion Clear coat houseboat 3D Foamies 4 Jan 23, 2012 03:18 PM
Clear Coat - Yay or Nay? screamin' eagle Slope 8 Oct 17, 2005 09:12 AM
