This thread is privately moderated by Daryoon, who may elect to delete unwanted replies.
Old May 25, 2012, 02:54 PM
Daryoon is offline
Find More Posts by Daryoon
Team WarpSquad
Daryoon's Avatar
United States, CA, San Diego
Joined Dec 2010
Data
Coreless Motor measurement
I just tried a 9958 motor (rev 2: blue, red wires) versus a mSR X motor versus white cap Bravo SX motor. All using 8teeth pinion.
On a stock 9958 with stock 9958 blades...
9958 rev2 (5g): 58.5g of thrust.
mSRX (5.7g): 61g of thrust.
BravoSX (5g): 63.5g of thrust.
I hooked up 4 Eflite 25c 150mAh in parallel and charged all 4 cells between each test. So the voltage should all be stable. I wanted to see peak thrust output.
The tail motor wasn't running.
However, if the tail motor was left to run, the stock 9958 motor went from 58.5g to 54.5g.
The mSR X motor was almost a gram heavier than the Bravo SX motor. This is because it's 23mm versus 20mm.
Now, I wonder the difference between a black capped BravoSX motor versus the white capped one.
caveat: The 9958 and mSRX motors are used. The BravoSX was new. I'll take a look a new mSRX motor I have in my possession.
Discussion:
http://www.rcgroups.com/forums/showp...postcount=5558
Daryoon is offline Find More Posts by Daryoon
Old Jun 14, 2012, 01:11 AM
Brosol is offline
Find More Posts by Brosol
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Have you thought about trying the SP 270A main motor? I noticed its cheaper than BSX main motor but don't know if it has the same thrust.
http://www.myrcmart.com/ne402270019a...et-p-4632.html
I had good results modding parts which I transplanted to my 9958 frame based Frankencopter with V911 Rx:
- Bravo III lower head with 2mm OD CF rod main blade pivot bar, thin profile linkage guide rods to prevent binding
- SP 260A main blades modded with linkage balls from XTreme Solo Pro swash hub, 14mm linkage balls spacing amplifying main blade pitch & cyclic, 3/32 drill bit enlarged pivot holes
I was putting off sorting out the mess of Bravo III, NE 210A, SP 260A parts for recycling such as using Bravo III lower head & SP 260A blades instead of the MCX head & blade parts.
I was forced to do these mods after I crashed the heli which snapped off a MCX blade linkage ball.
After I fixed some issues with binding which caused bad wobbles & vibration the Franken 9958 now flys great with Bravo III lower head & Solo Pro blades combo.
I also tried out the 9958 9x Tx settings you so generiously posted and I must say Wow!!! What a big difference it made!!! The crazy uber-responsive settings actually help to make aggressive flying indoors easier with more control. My attempts to use toned down settings were actually working against me. Now I'm more able to succesfully do FFF indoor turns without losing control & hitting a wall.
I think Bravo III lower head, Solo Pro blade, XTreme MSR flybar combo is a viable cheaper alternative to MCX & MSR parts for performance modded 9958-V911Rx helis.
Brosol is offline Find More Posts by Brosol
Old Jun 14, 2012, 02:49 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Old Jun 14, 2012, 02:51 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
About the T9x settings. Yeah, having the sticks more sensitive makes for easier flying. I also find adding positive expo to dampen the heli to make it easier for "beginners" to handle actually does the opposite effect for me. It makes me more likely to crash.
Old Jun 14, 2012, 04:18 AM
Brosol is offline
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Originally Posted by Daryoon View Post
I thought of using the lower Bravo III head before. But never purchased one to test out. Thinking about it, the lower Bravo III head is essentially a v911 head, with the top part cut off. The v911 has stronger pivots, so no need to drill and insert a CF rod. Plus, parts are pretty cheap too. Or buy a bnf unit to harvest the head, blades and RX.
I was forced to use CF rod pivots after I crashed and broke off both Bravo III head pivots.
I used a 3/32 drill bit to increase the Solo Pro blade pivot hole dia to fix wobbles caused by binding on the unmodded Bravo III lower head before the crash.
I found the combo of the CF rod and the enlarged pivot hole allowed the main blades a increased teeter angle tilt.
Even without dampener o-rings, the heli flew super smooth, vibration & wobble free at all speeds. It flew just as well as my V911-XTreme with delrin head feathering shaft & dampner o-rings.
Similar Anti-Wobble Mods by EQMOD, h2osteam:
EQMOD: http://www.rcgroups.com/forums/showp...postcount=2892
h2osteam: http://www.rcgroups.com/forums/showp...postcount=2889
h2osteam:
How to stop NE solo pro wobble (1 min 29 sec)
I stilll have the head & blades from a Banggood BNF V911 which was modded to my V911-XTreme heli.
I will try to use the V911 head & blades with anti-wobble mods if I crash & break the MCX head & blade parts on my V911-BellHiller heli.
Old Jun 14, 2012, 10:48 AM
Brosol is offline
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
As for motors, after my experience modding the mSRX for brushless...it's an eye opener. So much more power with a brushless motor. And even with the mounting plate, wires, ESC, motor...it still comes out lighter than the stock brushed motor.
From the mSRX brushless experiments, is it possible & worth it to do a BL conversion for V911 Rx based Frankenheli?
Old Jun 15, 2012, 04:37 PM
Brosol is offline
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
$4.90 SP 270A Main Motors - miracle-mart
Shipping to your area may be cheaper than myrcmart
http://www.miracle-mart.com/store/in...oducts_id=8722
I asked miracle-mart to beat the myrcmart's 270A main motor price and they did!
Old Jun 15, 2012, 05:36 PM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Nice. But Greyhoundfan just put three new Bravo SX motors into my hands last night. All white capped version from MyRCMart.
I did find a point on the v911 RX to solder the brushless ESC to. And it works with the BLHeli Tail code. Just need some time to finish the mod.
Old Jun 15, 2012, 06:12 PM
Brosol is offline
Brosol
Brosol's Avatar
Canada
Joined Dec 2010
Cool, looking forward to the V911 Rx BL motor mod results.
I'll do a SP 270A vs BSX motor thrust test.
Old Jun 17, 2012, 11:55 PM
rcstringfellow is offline
Find More Posts by rcstringfellow
NE solo free spirit V2
The Netherlands, NB, Eindhoven
Joined Mar 2012
+1
Lurking to see the BL V911 combo.
9x almost in my hands. Your hacksandmods are inspiring. I'm going to try implanting the DSM module in the 9x.
(probably been asked before but: can't the same trick be performed with putting the NE Tx module into the 9x?)
rcstringfellow is offline Find More Posts by rcstringfellow
Old Jun 20, 2012, 10:10 AM
Daryoon is offline
Team WarpSquad
Daryoon's Avatar
Joined Dec 2010
Can't wait to get back to this as well. I am currently modding my garage so that's taking up my time.
Thanks for the feedback on hacksmods. I appreciate it.
About putting the NE TX module into the 9x. I have thought of it. But I don't know if the NE module simply takes a PPM signal. If it dosesn't, then some sort of conversion needs to happen.
There is a NeXT thread that I think you saw, where the OP's goal was to create a rear module for the NE TX module. I don't think effort has been put into Nine Eagles compatibility because of the disparate protocol Nine Eagles chose to use between their older lineup and the new one. Transmitter incompatibilities really put a damper on the adoption of hobby grade heli IMHO.
Help! Help with measures of motor bearings for a K & B 40 Rear Exhaust JROMA Engines 11 May 07, 2012 09:00 PM
Sold 3 Futaba coreless motor servos BD Flyer Aircraft - General - Radio Equipment (FS/W) 1 Jan 11, 2012 06:46 PM
Sold Futaba S9451 digital coreless motor servo BD Flyer Aircraft - General - Radio Equipment (FS/W) 1 Nov 30, 2011 09:46 PM
Coreless ESC and non-coreless motor? j8m8l Scratchbuilt Indoor and Micro Models 8 May 21, 2003 08:48 PM
