Old May 25, 2012, 11:45 AM
Axefly is online now
Find More Posts by Axefly
South Africa
Joined Feb 2010
Help!
Ferrite ring substitute ?
Hi
I can't find any ferrite rings locally, i need 4 ferrite rings for a quadcopter for the esc's and receiver are close together, is there anything i can buy from say a local hardware shop or anything i can make diy as a substitute for each of the esc's ferrite rings ? i'm using 35mhz radio that's why i want the rings.
Axefly is online now Find More Posts by Axefly
Old May 25, 2012, 03:41 PM
eflightray is online now
Find More Posts by eflightray
An itch?. Scratch build.
eflightray's Avatar
South Wales U.K.
Joined Mar 2003
If you don't want to order from outside your country, you could try any local electronic shops, radio, TV repair shops etc.
Another way to reduce pick-up was by twisting the leads together, (often called a twisted pair), but with three wires in a servo/ESC lead, especially the current flat strip wire used, not so easy.
You could try taking the three connectors out of the plastic housing, strip the flat strip into the individual wires, and then twist, (or plat), the wires, and refit the connectors. You would need to do some testing afterwards to see if it was OK.
Also screening might work, i.e. wrapping each ESC lead in some aluminum foil, (kitchen foil etc).
Or better still, ask in the - DIY Electronics forum - as to be honest, I'm guess a bit here.
eflightray is online now Find More Posts by eflightray
Old May 25, 2012, 10:29 PM
keyman923 is offline
Find More Posts by keyman923
Former Futaba employee
Joined Aug 2006
Do you have a LHS that can order the Align rings?
http://www.fxaeromodels.com/product_...q3hbs2tes65ij1
keyman923 is offline Find More Posts by keyman923
Old May 26, 2012, 11:54 AM
ltc is online now
ltc
Find More Posts by ltc
ltc
AMA 97737
ltc's Avatar
United States, MA, Mendon
Joined Mar 2010
Check your local online distributors.
Digikey, Mouser, Newark, Farnell, etc.
Readily available, you just have to know what you want fir core material, size, impedance vs frequency, etc.
ltc is online now Find More Posts by ltc
Old May 26, 2012, 04:39 PM
whitecrest is offline
Find More Posts by whitecrest
Frequent Flyer
whitecrest's Avatar
Orleans, MA
Joined Feb 2007
They are used extensively in amateur radio circuits. Amidon is a well known supplier:
https://www.amidoncorp.com/
You can get them on EBay as well.
whitecrest is offline Find More Posts by whitecrest
Question ferrite ring. where to buy locally? out of stock Electric Plane Talk 20 May 22, 2012 03:33 PM
Discussion Ferrites- which wires? Moose2 FPV Talk 14 Mar 03, 2012 03:55 AM
Question Ferrite ring on downlink camera? My set up - suggestions? CactusJackSlade FPV Talk 1 Jan 30, 2012 11:15 PM
Discussion Do I need an esc Ferrite Ring if I am not using esc for power? NickBee Power Systems 3 Jan 28, 2012 04:27 PM
Question Removing "ferrite core" ring on ubec? rateoneturn Power Systems 9 Oct 05, 2011 10:31 AM
