Joined Jun 2012
Put it back to normal and start again from scratch. Easy to get mixed up. ![]() If you do what I did in the video below - note the board and battery are the normal way up, I've put it on the scales to show how much lift you get. A few grams different to before. Maybe this battery was heavier - and then put the props upside down on the shaft where you've cut a hole in the top of them you must get more lift than I did because they'd be the right way up and spinning in the correct direction. (Also see why you don't need glue to hold cable-tie feet on )
New York
Joined Oct 2008
apparently acceptable is in the eye of the beholder.
Joined Jun 2012
![]() I can't take all, or even much really, of the credit for the experiments - anyone who was bored enough could have done what I did: swap a few props about, plug in the motors differently, point a camera at it - it was nerys who came up with the intial suggestion and the yaw correction fix after the first video test. He was right both times. ![]() My next theory - based on the results of the previous U816/v929 tests and his suggestions - is that if I made all the same swaps - including arms - to the U816 as I did to the v929 - it could fly semi-inverted in a controllable manner. Throttle and Yaw work as normal, but maybe Aileron and Elevator will be swapped. We'll see. ![]() Someone recently said: |
Joined Jun 2012
![]() If you have new info, please share. No rush, my 4 bnf's from BG ordered on 30 August, are still some where in the ether. First orders where 16 days .. that shipping speed has gone out the window. I'll still build the dern thing, when the stuff gets here. Nuthin' wrong with sweepin' ants .. a couple feet agl works for a wasp killer
Joined Jun 2012
I think that's illegal in California if I'm not mistaken Stonecutter. Yep .. I just checked .. psuedo-inverted semi-inverted back-asswards flying has been outlawed here. Forntunatelly, nobodyy's been busted yet, cause even the lawmakers don't know what that means either.
Joined Jun 2012
![]() Basically half of it (ish) is umop apisdn - the legs and all the props - but the main board and battery are the normal way up.
Joined Jun 2012
The video was to test for inverted and reversed prop thrust. There are captions, a slowmo section and it's in 720p. ![]() U816 props are a very different shape (pretty standard looking direct-drive prop) and are ~87% efficient in reverse. See test here. Enough to easily lift the craft. v929 /Blade MQX props are differently shaped - made for slower, geared-down rotation (a bit like on my Parrot AR.Drones; no chance they'll do anything useful in reverse; they are so slow you can stop them with a finger) but I just wanted to see how good/bad these were. The result was a bit disappointing; as I was hoping for 20-25g so it would fly, but that's experiments for you: no bias. If ArchillesElbow does the same experiment, but puts his drilled-out props on the shafts the normal way up (no need to drill mine out if he's already done it) then he'll see the original amount of lift - well, maybe a few grams less as he'll be drawing air down past the motor mount and the foot/gear/arm. Should be flyable, with possibly Aileron and Elevator pseudo-semi-flip-swapped.
Joined Dec 2011
Has anyone seen the newly named PULSE? I believe it is near production.
It is simply a stunning work of art! it totally transforms an MQX/V929 into sci-fi land. It's got minimal spray paint on it just to show some of the detail. Production weight for whole body kit is said to be 16gr. I've got dibs! who else is getting one?
| Thread Tools | |
| Discussion WLToys WL-2019 Mini car | wallaguest1 | Micro Cars | 32 | Apr 11, 2013 04:34 PM |
| Discussion Rebranded NineEagles Solo Pro V2? (WLtoys V911) | gettinglucky | Coaxial Helicopters | 1 | Dec 26, 2011 01:06 AM |
| Discussion Keil Kraft ladybird tips anyone? | tim hooper | Vintage & Old-Timer Designs | 101 | Aug 27, 2009 03:02 PM |
| Discussion Ladybird Special | imp.bob | Vintage & Old-Timer Designs | 4 | Feb 03, 2008 10:08 PM |
| ladybird beetle/gws easybug | nebuchadnezzar | Foamies (Kits) | 1 | Aug 14, 2004 08:48 AM |
