E-flight BL32 disassembly
Has anyone disassembled an E-flight BL32? I'm interested in machining the shaft from 5mm to 3.2mm and could use a little help with how the ends come off. Thanks
USA, ME, Ellsworth
Joined May 2008
This describes the process pretty well for a typical motor, you just need to figure out if your ends are glued on a screwed on:
http://www.maxxprod.com/mpi/tips2.html The shafts on inrunners cannot be easily replaced and are too hard to be cut in a lathe with a single point cutting tool. You'll have to use an abrasive cutting process like a tool post grinder to take that down from 5mm to 3.175mm. That 3.2mm you mention is wrong, there is no such shaft size commonly used in RC, it is actually 3.175mm or 1/8". Are you trying to fit a pinion gearor what? Jack |
Thanks for the heads up. I'll check with the shop to see if they have the machine to grind it. That's my fault, I was rounding. The reason I want to grind it down is I can't fit a small enough gear to make me happy. 17t is the smallest I can find for a 5mm shaft, and I'd like something more like a 13. |
| Thread Tools | |
| For Sale E-Flight 40amp ESC & E-Flight Park 890Kv Motor, $50 Shipped | kctrading | Aircraft - Electric - Power Systems (FS/W) | 1 | Jun 23, 2012 08:13 PM |
| Sold E-Flight 70mm Delta V15 w/ BL32 Brushless Motor & CS 10 Blade | fastjetadic | Aircraft - Electric - Jets (FS/W) | 0 | Apr 16, 2012 08:44 AM |
| Sold E-Flight 40amp ESC & E-Flight Park 890Kv Motor, $35 Shipped | kctrading | Aircraft - Electric - Power Systems (FS/W) | 3 | Apr 07, 2012 06:20 PM |
| Discussion Turnigy SK3 disassembly for rewind | blademaker22 | Electric Motor Design and Construction | 6 | Mar 30, 2012 01:11 PM |
| Help! Old OS Max 20 R/C Disassembly | bkh | Engines | 2 | Mar 21, 2012 10:46 PM |
