Joined May 2012
Need inputs on (re)building Piper Cub
Hi folks,
Long-time lurker here, but this is my first post: Someone handed me a never-used Piper Cub kit from General Hobby (http://www.generalhobby.com/piper-fu...low-p-185.html) and I set it up for an electric conversion with the following RTF configuration:- 6s 5000mAh LiPo Turnigy TR 50-65B 350kv Brushless Outrunner (Eq: 4030/16 from Axi) 16x10 Zinger wood prop (you can see where this is headed) Flying weight was about 8.6lb. I also tested that I was getting about 880-900 Watts at a theoretical ~8800 RPM. First and only flight resulted in strong uncontrollable bank to the left and crash. Luckily I was able to bring it nose down, and the only damage was bent landing gear and a broken engine mount. I can only point the crash to the effect induced by the oversized prop, all controls were working fine even after the crash, and the CG was carefully balanced. The plane did taxi straight down the runway and I could not see any other problems. I understand that I possibly need a different prop. What do you guys suggest for this plane? I also think I may not have put enough angling to the down and right for the motor mounting (it was perhaps a degree or so both ways). I'd appreciate some suggestions for this too. Importantly, is there any way to test this on the ground or by suspending the plane in air by some rope to check for torque effect? I have flown the Radian, Radian Pro, and a couple of smaller foam warbirds. I understand that the Cub can be a handful, so any flying tips are also most welcome. Thanks for your time, Vijay |
Be sure that your motor is angled a little down and a little to the right, helps control tendency to yaw left and pitch up during takeoffs and when applying sudden throttle.
Start takeoff roll with up elevator to hold tailwheel down and aid steering, gradually increase throttle, as speed builds, let tail rise and control direction with gentle nudges of right rudder to counteract torque, and keep from veering left. Let model rise off at around 3/4 throttle and keep climb angle moderate. Give a little down elevator to countreract tendency of nose to rotate up and cause a stall, back off on throttle as needed to transition to level cruising flight. To land, reduce throttle to 1/2 and have nose slightly down, use RUDDER to keep wings level, (ailerons lose effectiveness at landing speeds), reduce throttle gradually until model's main wheels touch down and reduce throttle more until tail wheel touches down. Raise elevators to keep tail wheel down on runway and to aide steering. Keep some power on during landings, aids steering and control, I use coupled aileron and rudder most ot the time, makes flying scale models easier. Over-ride it or shut it off when needed or desired. |
United States, FL, The Villages
Joined Oct 2010
vijayfx35 - These folks must know what they are talking about, because I AGREE 100% with what they say. Good smart folks!
The smooth application of power looks better too. I have 3D planes that can takeoff in almost no space, but I do more scale like departures. Just looks better, IMHO.Don |
Tucson
Joined Nov 2009
My Seagull 80" Cub is the most difficult plane that I have ever flown. Weird points about this Cub are:
1. Must keep 30% down elevator to keep the nose down until it gets up flying speed 2. MUST use rudder to keep it straight on take off (it will try to turn into the wind, and roll) 3. Do RUDDER turns, with a little aileron to keep angle of turn nice. The Seagull Cub will snap roll if you let it just lift off (the main wing loads before the tail has enough air to control the plane). When this happens, you get a strong bank in one direction, that is actually a stall and slow snap roll. Maybe little foamie Cubs are stable, but Cubs that fly like the full-size plane have very demanding flying habits. You will learn real flying skill to get them into the air, and learn how to make them fly gracefully. Practice taxiing it and keeping the plane straight with the rudder, and keeping the nose down. It will build your flying skills. (The generalhobby P-51 54 inch and 1600 watt aeolian motor and 3,000 mAh 6S LiPo and 190A speed controller was MUCH, MUCH easier to fly than this 80" Cub!! The P-51 is a flying brick, but it has lots of wing, goes exactly where you point it, and slows down wonderfully to land. It tracks true on the ground, and take off. I would suggest the P-51 before I would ever suggest a "low wing trainer" such as the Escapade.) ![]() ![]()
| Thread Tools | |
| Discussion need help flying my piper cub | LikeARock | Beginner Training Area (Aircraft-Electric) | 20 | Apr 26, 2012 06:11 PM |
| Discussion Hobbyking Piper Cub vs Dynam Piper Cub For First Plane? | HempfieldHunter | Beginner Training Area (Aircraft-Electric) | 2 | Apr 25, 2012 12:54 PM |
| Question Need input on AP build | rgoins21 | Multirotor Talk | 12 | Mar 15, 2012 01:27 PM |
| Help! 50% Piper Cub build, need advice! | scolen3 | The Builders Workshop | 24 | Jan 16, 2009 12:45 AM |
| Discussion Need plan for scale 70'' Piper J-3 Cub (going to build in 6mm Depron) ! | ruben | Scale Electric Planes | 8 | Mar 13, 2006 07:29 PM |
