Old Aug 15, 2012, 01:16 PM
jhroof is offline
Find More Posts by jhroof
Orlando, Fl
Any news about when this will be released? Where does the new Hard Deck Module plug into the system?
jhroof is offline Find More Posts by jhroof
Old Aug 15, 2012, 01:29 PM
jhroof is offline
Orlando, Fl
I have a Copilot II that I ordered about 2 years ago. I got pretty good at 3D, so I never used it. The new Hard Deck feature is pretty cool, so I'd like to try it for teaching and learning some new moves. I'm not sure if it has the FUIM3 or FUIM2. How do I tell the difference? When did the FUIM3 come out?
Old Aug 15, 2012, 05:44 PM
Tim Marks is offline
Find More Posts by Tim Marks
President, FMA, Inc.
Tim Marks's Avatar
Joined Mar 2008
Hi:
Production is scheduled to be completed by end August according to latest estimates by our partners in Singapore. The HD Module plugs into the ACCY port on the Co-Pilot II Avionics Computer.
Tim Marks
Tim Marks is offline Find More Posts by Tim Marks
Old Aug 15, 2012, 05:47 PM
Tim Marks's Avatar
Joined Mar 2008
Check the following page which is for downloading the drivers for each device:
http://www.revolectrix.com/new_appli...re/pc.usb.html
Pay particular attention to the CAUTION at the bottom of the page. If you have any questions, let me know.
Tim Marks
Old Aug 15, 2012, 10:14 PM
jhroof is offline
Orlando, Fl
Thanks. I just ordered the Hard Deck module and the FUIM3 programmer.
Old Aug 16, 2012, 12:44 PM
Howard Matos is offline
Find More Posts by Howard Matos
AR-15 BRD!
Howard Matos's Avatar
Frederick, MD
Joined May 2002
Here is a picture I took showing the module mounted on my 550. Note: the module is installed on a downward angle so you can see the LED from the ground.
Howard Matos is offline Find More Posts by Howard Matos
Old Aug 16, 2012, 04:21 PM
Hati is offline
Find More Posts by Hati
Hati's Avatar
Perth, W.A.
Joined Mar 2008
Is that LED on only when the HD unit is ready to do its thing? I.e. above 50 feet?
Hati is offline Find More Posts by Hati
Old Aug 16, 2012, 05:31 PM
jhroof is offline
Orlando, Fl
I noticed you have some fuel tubing on the sensor. Is it affected the by the air from the blades?
Old Aug 16, 2012, 05:59 PM
Jack Doherty is offline
Find More Posts by Jack Doherty
CPII HD & PL8 beta tester
Jack Doherty's Avatar
Aubrey, Texas
Joined May 2009
Hi Hati,
The led is ON all the time when your remote switch on the transmitter is switched to the ON (HD mode) position. Not just when you are above the set hard deck altitude. A lit LED tells the pilot all aspects of the CoPilot II and HD module have passed all the requirements for the HD emergency recovery to work properly. A lit LED means everything is good to go and it is bright enough to be seen in the air while flying even on a bright sun lit day.
Jack
Jack Doherty is offline Find More Posts by Jack Doherty
Old Aug 16, 2012, 07:07 PM
Aubrey, Texas
Joined May 2009
Hi jhroof,
Yes to some degree. However, FMA has devised a method to mostly eliminated the adverse effects of multi-directional air flow around a helicopter that would prevent accurate HD emergency recoveries.
Jack
Old Aug 17, 2012, 03:23 AM
Hati is offline
Hati's Avatar
Perth, W.A.
Joined Mar 2008
Cheers Jack.
Old Aug 27, 2012, 12:44 AM
I-FELN is offline
Find More Posts by I-FELN
T-REX 250 -450-500-600-700G
I-FELN's Avatar
ITALY, PAVIA
Joined Mar 2009
Originally Posted by Jack Doherty View Post
Hi jhroof,
Jack
seem Hard Deck would read an air static pressure as an avionic Altimeter o Variometer. Correct?
I-FELN is offline Find More Posts by I-FELN
Old Aug 27, 2012, 10:39 AM
Tim Marks's Avatar
Joined Mar 2008
Hi:
We're finalizing the user guide for the HD Module as we speak. Please be patient. Soon, everybody's questions should be answered.
Tim Marks
Old Aug 27, 2012, 03:40 PM
I-FELN is offline
I-FELN's Avatar
ITALY, PAVIA
Joined Mar 2009
Originally Posted by Tim Marks View Post
Hi:
Tim Marks
Hi TIM,
Thanks kindly for that info..
I'm a trusted small client with four CII succesfull on Heli board and two with hard deck in back order. I buy hard deck as a closed box cause I estimate your company . Would be fine if you let us to read user guide before buy the system just to understand if match the specific personal agreement.
Another question is about the fixed minimum safety altitude of 50' as exposed in another forum:I think no claim to your company if the user would choose too low altitude at his own risk.
Best Regards
Claudio
Old Aug 29, 2012, 11:23 PM
jj604 is online now
Find More Posts by jj604
ancora imparo
jj604's Avatar
Melbourne, Australia
Joined Jul 2005
The manual is now available on the Revolectrix website.
http://revolectrix.com/support_docs/item_1416.pdf
jj604 is online now Find More Posts by jj604
Help! Hanseat 51" luxury cruiser deck plan modelmaker46 Dock Talk 8 Aug 24, 2015 08:12 PM
Discussion 2.4ghz hard deck ? Coyote64 FPV Talk 5 Jun 09, 2010 11:54 PM
For Sale Ace MicroPro 8000 RF deck and alternating RF deck switch rcflysal Aircraft - General - Radio Equipment (FS/W) 0 Feb 03, 2007 09:15 AM
Tally Ho... X-32A above the hard deck! Kevin Cox Electric Ducted Fan Jet Talk 18 Oct 05, 2001 09:49 AM
