Old May 24, 2012, 01:25 PM
drewwrx is offline
Find More Posts by drewwrx
Ain't Nothing but a Peanut
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
Question
Hyperion stored in package for 2 years still good?
I bought a Hyperion 3.7v 160mah 25c battery two years ago and never took it out of its original packaging. I am ready to use it now but was wondering if it is still good? I'm not sure what voltage it was stored at for two years because I don't know what voltage Hyperion sends their batteries out at. Anything special I need to do with it?
Drew
drewwrx is offline Find More Posts by drewwrx
Old May 24, 2012, 01:34 PM
Beckler is online now
Find More Posts by Beckler
Beckler's Avatar
Canada
Joined Apr 2008
The 3 Hyp 3S packs I have were all at 50% when I bought them. What voltage is yours at now?
Beckler is online now Find More Posts by Beckler
Old May 24, 2012, 01:57 PM
drewwrx is offline
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
I'll have to check I have a voltmeter coming in tomorrow. What should I be looking for for the voltage on this?
Old May 24, 2012, 02:42 PM
Beckler's Avatar
Canada
Joined Apr 2008
What I've read is that if cell voltage is less than 3.3V no load, then charging isn't recommended.
Old May 24, 2012, 08:19 PM
ggcrandall1 is offline
Find More Posts by ggcrandall1
ggcrandall1's Avatar
USA, GA, Marietta
Joined Aug 2005
LiPo cells are shipped at 3.85V or very close to that. If your battery reads close to that and it takes about 80ma when you charge it, then it is probably good.
Glen
ggcrandall1 is offline Find More Posts by ggcrandall1
Old May 24, 2012, 08:25 PM
zeropointbug is offline
Find More Posts by zeropointbug
Joined May 2012
Is this a G3 25C pack?
It definitely won't have the power that it 'would' have vs. brand new, but try it out. You will have to do a few (5+ cycles) at low charging levels to wake them up before you thrash them.
zeropointbug is offline Find More Posts by zeropointbug
Old May 24, 2012, 09:39 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
Not al are the same but a few months ago I assmeble some Hyperion 25C bare 240 mAh cells which I had purchased two years prior in to 2S packs for my EFlite Beast and a last week a few of them as 1S packs for my Blade mCPX. I also purchased 5 new Hyp. 240 cells for use in the mCPX. I can tell not difference in any of these cells during CBA graph test or during flying.
Charles
Old May 25, 2012, 10:46 AM
Speeddaddy is offline
Find More Posts by Speeddaddy
Delton,Mi
Joined Jun 2009
Charles
Hey Charles, when you test batteries on your CBA do you use a 1c discharge rate. Like a 1300 3cell battery do you discharge it at 1.3 amps?
Speeddaddy is offline Find More Posts by Speeddaddy
Old May 25, 2012, 02:55 PM
drewwrx is offline
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
Got my volt tester. The two year old hyperion (3.7v 160mah 25c G3) is at 3.74v. You guys don't think it will have the power of a brand new one ever again?
Old May 25, 2012, 03:25 PM
rampman is online now
Find More Posts by rampman
Frankenstein recycled packs
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Did you not read Charles' post? EDF, what is that acronoum you came up with for this?
Rick
rampman is online now Find More Posts by rampman
Old May 25, 2012, 03:41 PM
drewwrx is offline
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
Rick
Rick,
I just saw that one person said it will not have the power and one person said it would. I just thought that my volt reading might have given enough info to tell maybe. Anyway, I'll just try it out and see.
Drew
Old May 25, 2012, 05:43 PM
rampman's Avatar
USA, AZ, Gilbert
Joined Jan 2006
Volts is only how full the gas tank is. The unknown at this time is how big the tank is and how fast the hole (amps) will allow the gas (voltage) to flow out of the tank.
Confused? Good. :P Charge them, fly them and report how they do. My $$$ says better than your used cells.
I have heard before that there is a chemical reaction that has to happen and it takes a few cycles to activate the cells; hense a break-in of 3 to 5 cycles to get them up to max performance. This is to have better shelf life than a cell cycled a few times and stored.... or so the rumor goes...
Rick
Old May 25, 2012, 06:00 PM
drewwrx is offline
drewwrx's Avatar
Lewes, DE
Joined Mar 2010
Rick, I just flew it for the first time and my Hobbyzone Champ flew great. It had alot of climb power. I had to cut the flight short due to wind but so far so good!
Old May 25, 2012, 06:52 PM
Southern Pride
IMO a 1C discharge would not really tell us much unless you do in fact get 1 hour flights. Three C is about where I normaly start at then I most often go up to 60% plus of the LiPoly cont. C rating as long as it holds voltage fairly well, do not get to hot and delicvers reasonable capacity.
A recent test fromn the Battery graph vault of small LiPOlys ( mCPX class).
http://www.rcgroups.com/forums/showthread.php?t=1643704
Charles
Old May 25, 2012, 10:04 PM
Delton,Mi
Joined Jun 2009
Charles
Thanks Charles, I also notice you cut them off at 3.30 volts per cell
Discussion new engines stored for 30 years ltc Engines 8 May 18, 2012 09:46 PM
For Sale Brand new unassembled msrx & mqx still in original packages B dog Aircraft - Electric - Helis (FS/W) 4 Feb 10, 2012 10:35 PM
Discussion New Hobby store in CA, prices seems good on parts 11dmss Electric Plane Talk 4 Jan 19, 2012 04:09 AM
Sold New-Still in Package- Hacker X-40 40a Brushless ESC ptflyer Aircraft - Electric - Power Systems (FS/W) 3 Jan 16, 2012 06:38 PM
Discussion 10 stimulus packages in 8 years ... a decade lost. logan5 Life, The Universe, and Politics 3 Nov 04, 2011 09:25 AM
