This thread is privately moderated by wbrannies, who may elect to delete unwanted replies.
Old May 23, 2012, 10:53 PM
wbrannies is offline
Find More Posts by wbrannies
Trader Rating: 35
"The Need 2 Flip"
wbrannies's Avatar
Westminster, Ca
Joined Jul 2009
Trader Rating: 35
For Sale
New E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC
New 60 amp pro esc
Key Features
Up to 60-amp continuous current with proper air flow, 75-amp peak
5-volt Switch-Mode BEC circuit capable of 2.5-amp continuous current on any recommended input voltage
Drives up to 7 analog or 6 digital standard-sized servos, with the BEC on any recommended input voltage
3–6S Li-Po, 9- to 18-cell Ni-Cd/Ni-MH input voltage
Finned heat sinks
Programmable motor braking
Safe power-arm mode prevents accidental starts
Programmable low voltage cutoff with settings for 3-cell Li-Po (9V), 4-cell Li-Po (12V), 5-cell Li-Po (15V), 6-cell Li-Po (18V), or 70% of battery starting voltage
Programmable soft start for helis and airplanes
Auto motor shut down if signal is lost or there is interference
Programmable timing—5 user-selectable ranges for use with a larger variety of brushless motors
Programmable throttle input range (1.1–1.9 ms or 1.2–1.8 ms)
Utilizes new smaller MOSFETs technology to minimize weight
Radio System Power On/Off Switch
Pre-wired connectors—E-flite EC3 on battery input and 3.5mm female gold bullets on motor output leads
70.00 shipped
wbrannies is offline Find More Posts by wbrannies
Old Nov 06, 2012, 09:23 PM
Jason Justice is offline
Find More Posts by Jason Justice
Trader Rating: 7
Jason Justice's Avatar
United States, KY, Louisville
Joined Mar 2012
Trader Rating: 7
Is this still up for sale?
Jason Justice is offline Find More Posts by Jason Justice
Sold E-flite 60-Amp Pro Switch-Mode BEC Brushless ESC jimmy34256 Aircraft - Electric - Power Systems (FS/W) 2 Apr 18, 2012 07:44 AM
For Sale E-Flite 960Kv Brushless Outrunner+Hub and 30-Amp Pro Switch-Mode BEC ESC $80 Shipped wattflyer6161 Aircraft - Electric - Power Systems (FS/W) 0 Nov 06, 2011 09:57 PM
Sold E-Flite 60-Amp Pro Switch-Mode BEC Brushless ESC $65 Shipped wattflyer6161 Aircraft - Electric - Power Systems (FS/W) 2 Oct 29, 2011 06:59 PM
Sold 40-Amp Pro Switch-Mode BEC Brushless ESC by E-flite LIKE NEW delfin2003 Aircraft - Electric - Power Systems (FS/W) 0 Oct 12, 2011 08:17 PM
Sold 40-Amp Pro Switch-Mode BEC Brushless ESC by E-flite LIKE NEW delfin2003 Aircraft - Electric - Power Systems (FS/W) 5 Oct 07, 2011 12:32 PM
