Old May 23, 2012, 02:25 PM
bsteabagger is offline
Find More Posts by bsteabagger
Joined May 2012
Spektrum DX4e Transmitter V-tail Mixing with AR600 receiver
I have a Spektrum DX4e transmitter, which I use for my 3-channel Super Cub. I want to upgrade to a 4-channel airplane, specifically the Hobby King Dynamic-S (http://www.hobbyking.com/hobbyking/s...dProduct=21946). This is a V-tail plane.
I will be using a Spektrum AR600 receiver.
Can someone please give me the basic steps how to configure a V-tail plane with the DX4e remote?
Are there one or two cables from the "V" tail to the receiver?
Most importantly:
Is it even possible to fly this plane with the DX4e?
Thanks!
bsteabagger is offline Find More Posts by bsteabagger
Old May 23, 2012, 03:10 PM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
The DX4e is a very basic radio and doesn't have the ability to program for V-tails. You can try plugging servos into the AILE & ELEV channels and using elevon mixing (flip the mix switch to on) HOWEVER either left and right rudder will be reversed or up & down elevator will be reversed. There's no way to reverse one without the other since the DX4e only has individual channel reversing. You will need a more sophisticated radio to use v-tails (like the DX6i or better). If you want a 4-channel plane have you considered adding ailerons to your Super Cub? There's a guide for how to do so here (the brushless upgrade is optional). Since you have the DSM2 version of the Super Cub you won't need to replace anything and it will still work with your DX4e radio.
Rayne is offline Find More Posts by Rayne
Old May 23, 2012, 05:38 PM
freechip is offline
Find More Posts by freechip
Surface, Air & Water Rc Toys..
freechip's Avatar
Canada, ON, Ottawa
Joined Aug 2008
According to HK
Requires: Your own 4 Channel TX/RX with V-Tail mixing
If you what to use a spektrum radio it will not be with the DX4e but like mentioned above the DX6i will do the job.
freechip is offline Find More Posts by freechip
Old May 23, 2012, 05:57 PM
ivanc is offline
Find More Posts by ivanc
S.A.D. member
ivanc's Avatar
United States, TX, Round Rock
Joined Dec 2004
If you already have the DX4e and want to use it - get a v-tail mixer.
ivanc is offline Find More Posts by ivanc
Old May 23, 2012, 05:59 PM
Fricotin is offline
Find More Posts by Fricotin
Mexico, Oax., Puerto Escondido
Joined Sep 2010
There is something about elevons on page thirteen of the manual, it says you have to move the MIX switch in the UP position and adjust the servos, you may want to read it. I don't know anything about it.
Fricotin is offline Find More Posts by Fricotin
Old May 23, 2012, 11:16 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Most importantly:
Thanks!
It's possible but a bit awkward. You have three ways to do it:
1. Do without rudder and just plug both tail servos into a Y-cable connected to the aileron channel (ch2).
2. Use a v-tail mixer installed in the model. This takes output from the R and E channels and outputs mixed signals for the two tail servos. GWS makes one that's supposed to work well.
3. Use the elevon mix on the DX4e and plug the tail servos into A and E. Then learn to fly with aileron on the left stick (mode 3). [not a serious suggestion!]
Only number 2 is likely to be satisfactory!
The remaining options are to choose a different model or upgrade to a more capable transmitter (which you will want to do anyway as soon as you have more than one flyable model at a time).
Daedalus66 is offline Find More Posts by Daedalus66
Help! Parkzone Transmitter conversion - V-Tail Mixing helipilot Scratchbuilt Indoor and Micro Models 15 Jul 02, 2012 07:03 PM
For Sale Spektrum DX-6i transmitter with AR600 DSMX shw18t Aircraft - General - Radio Equipment (FS/W) 8 Apr 19, 2012 11:09 AM
Help! V-Tail mixing with dx5e will this item work. BonyTone Electric Plane Talk 19 Feb 26, 2012 11:43 AM
Help! Spektrum DX6i V-Tail Mix - Reduced Throws? ckalkhof Radios 5 Jan 02, 2012 03:40 AM
Help! V-Tail Mixing Question SOLVED! seedo Radios 6 Dec 24, 2011 10:09 PM
