I own and fly both. Skywalker is more versatile. X8 is faster and
can carry enough battery to go long distance, but launching and especially landing in tight spaces is a problem as there's no way to run flaps on the X8 and it floats in ground effect forever. Can hand launch and land the Skywalker almost anywhere (especially if you use flaps) and if you need to carry more weight to loiter for a long time, could use the 1900mm wings. Both require some mods to improve strength/rigidity, but are fairly easy builds. Easier to mount an HD camera on pan or even pan & tilt on the Skywalker. X8 has the coolness factor, but being a big distinctive drone-like plane, may also attract a lot more unwanted attention if you're trying to fly discreetly. I do not see one as a direct replacement for the other at all. I think any well rounded FPVer needs a plane like the Skywalker, plus some sort of faster flying wing, like the X8, Foamaroo, ZII, etc.. ian |
Latest blog entry: My 2012 FPV year in Review
HK EPP FPV plane is not in the same league as the SW. It's very slow,
and hits a brick wall of drag when you try to go faster. Seems to require shimming and such just to get the wing and horizontal stab aligned. ian |
higher average current draw in level flight, poorer climb rate, shorter flight times, etc. One of the reasons you can't get it to spin, is that it's just constantly trying to pull the nose down. ian |
Germany, HE, Darmstadt
Joined Feb 2013
Which Skywalker ... ?
I have ordered an X8 and do still wait for the delivery. But I am interested in buying a SW as well, exactly for the reason that it is much more convenient to handle by means of launching and landing.
Now I have seen that there is a real MONSTER thread with almost 17000 posts which is basically impossible to read before I retire. For that reason, could someone summarize the pros and cons of the SW versions which are available? I've seen that there is a 1680mm Version, one with 1900mm and one with 1880mm. Besides this there seem to be not only foam-versions but glass-versions as well. It seems hopeless to filter that out of the SW thread. If there is already such a comparison somewere in the forum, I would be happy if somebody could point me to that thread. Searching didn't reveal reasonable results. But I would as well appreciate a summary here in this thread very much! |
| Thread Tools | |
| Discussion Best Horrizon Hobby platform for FPV. | qwerty11 | Video Piloting (FPV/RPV) | 16 | Mar 22, 2012 10:47 PM |
| Discussion Best FPV Platform? | qwerty11 | Video Piloting (FPV/RPV) | 3 | Mar 16, 2012 09:06 PM |
| Help! About building SkyWalker V5 RC FPV | RanDavari | Video Piloting (FPV/RPV) | 4 | Mar 10, 2012 03:51 AM |
| Discussion best fpv platform for electronic experiments | emerge | Video Piloting (FPV/RPV) | 6 | Feb 29, 2012 06:33 PM |
| Discussion Delta or pod/boom - which is the best all-purpose FPV platform? | TheNiceGuy | Video Piloting (FPV/RPV) | 15 | Oct 09, 2011 08:30 AM |
