Old May 22, 2012, 10:15 PM
Thetoad is offline
Find More Posts by Thetoad
Joined Dec 2011
Simple query
Although most standard li-po's are designed for 3.7 volts d.C ....it has been said these can be charged up to 4 .2 volts,,,as opposed to their assigned designation of 3.7
I would like some clarification....if possible
Thetoad is offline Find More Posts by Thetoad
Old May 22, 2012, 10:37 PM
JohnGilmore is offline
Find More Posts by JohnGilmore
Joined May 2012
3.7 is the nominal voltage for a cell and the 4.2 is the fully charged voltage for the same cell.
For the gruesome details do a search on "LIPO nominal voltage".
JohnGilmore is offline Find More Posts by JohnGilmore
Old May 22, 2012, 10:53 PM
TheWoodCrafter is offline
Find More Posts by TheWoodCrafter
RC Helicopter Pilot
TheWoodCrafter's Avatar
United States, CA, Westminster
Joined Mar 2010
All rechargeable batteries are similar in that respect.
TheWoodCrafter is offline Find More Posts by TheWoodCrafter
Old May 24, 2012, 04:21 PM
Thetoad is offline
Joined Dec 2011
For that info..
After reading so many pieces on the possibilities of things going wrong while charging these,,I did need some clarification.
Are there any signs that I should be aware of if the batteries are under some sort of duress .Would they feel warm to the touch,,,,,,?
Batteries have been used for centuries,,,,,but clearly LI PO'S,are a different animal indeed
Old May 24, 2012, 04:50 PM
Rayne is offline
Find More Posts by Rayne
"Landing" in a tree somewhere
Rochester, NY
Joined Sep 2009
Batteries being a little warm to the touch after flying is normal. It's when the battery is too hot to touch or it's puffed up that you need to worry. If you follow the basic guidelines for how to use lipos then you won't likely have any problems with them.
Rayne is offline Find More Posts by Rayne
Discussion DX6i Radio Mixing query zagiflyer67 Electric Plane Talk 0 Mar 10, 2012 05:17 PM
Yippee! Several queries for the Ninja 400 Irish Steve Skyartec 2 Nov 08, 2011 03:56 AM
Discussion HK6DF receiver and transmitter query part deux dave1993 Radios 0 Nov 05, 2011 04:27 PM
Discussion HK6DF receiver and transmitter query! Marty7n Radios 2 Oct 17, 2011 08:00 AM
Discussion Help with some simpl questions ChargerF18 Micro Ready-to-Fly 3 Dec 27, 2010 07:17 PM
