Old May 22, 2012, 09:41 PM
Scratch builder
Bixler13's Avatar
United States, CO, Colorado Springs
Joined Jul 2011
Easy Drone Build Along- FPV/Camera Plane
The Easy Drone is a remote control airplane that I designed myself for fpv. It is a very easy build and flies really good. The plane is very stable and gets good lift. Although it is intended for fpv, it does not need to be flown fpv. If you are not into fpv planes, this would be a great plane to build and fly.
Easy Drone Build Along (Part 1 of 2) (8 min 39 sec)
Easy Drone Build Along (Part 2 of 2) (8 min 4 sec)
Wing:
Wingspan: 60 inches
Root Cord(including ailerons): 10.5
Root Cord(not including ailerons): 9
Airfoil: 5X60
Fuselage:
Length:21
Width:4
Height:2.25
Tail:
length:5 incl. elevator
Elevator:1
Width:15
Middle vert stab height: 5
Side vert stab height: 3.5
Total Length: 44.5
Carbon Spar Length(from trailing edge of wing to leading edge of elevator): 18.5
Material: Dollar Tree Foam board and Home Depot 1/2 inch pink foam for airfoil
Bixler13 is offline Find More Posts by Bixler13
Old May 24, 2012, 10:12 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
A flight of this plane!
GoPro: Rc Airplane Pushing The Limits (3 min 3 sec)
Old May 25, 2012, 02:51 PM
Sniping worms is hard
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
I caught your video with the fire department on another forum... pretty cool! You should put it up here.
snipeworm is offline Find More Posts by snipeworm
Old May 26, 2012, 09:24 AM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
Here is the Fire Dpt. Video!
GoPro: Helping Fire Dpt. Find Fire! (4 min 4 sec)
Old May 27, 2012, 01:04 AM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
And here is some video around my high school!
GoPro: RC Airplane Flying Around School (6 min 17 sec)
Old May 27, 2012, 12:11 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
Here is the video of me hitting the power lines and destroying my plane...
GoPro: The Death of the Easy drone V3 (3 min 17 sec)
Off to build another one!!!!!
Old May 27, 2012, 01:13 PM
Jack
USA, ME, Ellsworth
Joined May 2008
Beautiful build and flying, Bix!
I love the simple stuff and that is a "have to have one" if I have ever seen i!
If you have any photos of the FPV gear installed with the top off thy would be lovely to see. And if you know the AUW you were flying at fully equipped that would be nice too.
Jack
jackerbes is offline Find More Posts by jackerbes
Old May 28, 2012, 09:03 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
GoPro: Park Flying (3 min 59 sec)
Old May 29, 2012, 08:31 AM
Columbus Ohio.
Joined Aug 2006
Neat plane and videos!!!
Can you tell us what is the AUW?
RJKIRK is offline Find More Posts by RJKIRK
Old May 29, 2012, 05:20 PM
snipeworm's Avatar
Joined Feb 2012
Sucks about that power line! Couldn't see it until it was in your face! Do you have any info on your fpv system? And how about some video from your video receiver?
Old May 29, 2012, 06:25 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
I don't have any video from my video receiver. It just looks like any other fpv set up... Here is my fpv set up.
Receiver: Hobbyking 900mhz 12 channel receiver
Transmitter: 800mw 1.3 ghz
OSD: none
Antennas: Stock whip and inverted v
Fpv camera: go pro
Old May 29, 2012, 06:37 PM
snipeworm's Avatar
Joined Feb 2012
Sorry to bug you with questions but I am planning out my fpv system because it will take me a while to get it all and I can only afford to buy it once! what kind of range do you expect from your system, what freq. transmitter are you using, and anything you wish you did different?
thanks!
Old May 29, 2012, 11:33 PM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
No problem!
I use 1280mhz for video and 2.4ghz for control. As most people say, range different for every one.There are so many factors that effect the range. I am limited by my spektrum dx7s. The range is pretty crappy on it! Video on the other hand is pretty good. I have never lost video because of range issues but the video does get pretty bad when I fly behind trees and other obstacles. The farthest i have flown my plane is about half a mile and the video was still going strong. One thing I wish I did do different is get a radio with more range! It really sucks when your flying and then your plane locks up..and then crashes!
Brett
Old May 30, 2012, 06:49 AM
Jack
USA, ME, Ellsworth
Joined May 2008
I think your ranges issues might relate, at least in part, to the 2.4 Ghz signals being blocked or absorbed by the near proximity to the ground you are flying at. The vegetation and structures will all contribute to that. You've probably noticed that if you fly for height your range is much better.
Can you describe how you are launching and making the transition from flying the plane by eye to using the goggles? I know some like to have a second person and even use buddy systems with a second TX to do.
And describing the routine you use for landing would be nice to hear too.
Over on the more "pure FPV" forums they don't go into much of the details of the actual getting it in the air and getting it back on the ground process.
Thanks for sharing!
Jack
Old May 30, 2012, 07:56 AM
Scratch builder
Bixler13's Avatar
Joined Jul 2011
To launch my plane i put the goggles on my forehead and launch the plane LOS. I fly it to a pretty good height then i take my hands off the controls and put my goggles on and then return my hands to the controls. For landing I just land with the goggles on... It is actually a lot easier than it looks
Discussion Easy Glider FPV Build ~ Ideas sought UPDATE Now built! vvV FANG Vvv Video Piloting (FPV/RPV) 15 Jun 26, 2012 10:00 AM
Mini-HowTo Easy Star 2 Camera plane conversion. Gray Aerial Photography 29 Apr 05, 2012 02:35 AM
Discussion Sander's Skywalker FPV camera plane build ssassen Video Piloting (FPV/RPV) 132 Jan 22, 2012 05:38 PM
Discussion Building a FPV Multicopter Drone, Advice Needed divedaddy03 Multirotor Talk 0 Dec 07, 2011 11:10 AM
Discussion Building a FPV Multicopter Drone, Advice Needed divedaddy03 Video Piloting (FPV/RPV) 9 Dec 07, 2011 10:54 AM
