Old Apr 19, 2013, 04:13 PM
feivel2211 is offline
Find More Posts by feivel2211
Joined Feb 2012
moriwaky, the demo videos are looking fantastic! I also preordered a gimbal and i cannot wait to have it in my hands / on the spidex :-). Is there any chance to get my Gopro2 working on it, in case i will build the front plate for myself - or will there be problems with the balancing, space (because of larger depth of gopro2) or the weight?
Oliver
feivel2211 is offline Find More Posts by feivel2211
Old Apr 19, 2013, 08:45 PM
AeroVideoUS is offline
Find More Posts by AeroVideoUS
aka Helidaho
AeroVideoUS's Avatar
United States, ID, Boise
Joined Jun 2010
I'm sorry I missed out on the pre-order but I signed up for the notification of the next order, hopefully that will be soon?
Paul
AeroVideoUS is offline Find More Posts by AeroVideoUS
Old Apr 19, 2013, 08:52 PM
migser85 is offline
Find More Posts by migser85
Tegucigalpa, Honduras
Joined Feb 2007
just preordered mine today, check their site, the preorder is back
migser85 is offline Find More Posts by migser85
Old Apr 20, 2013, 12:42 AM
aka Helidaho
Joined Jun 2010
Thanks for the info, I just put in my pre-order as well! I guess their notification system isn't as fast as RCGroups
I ordered the frame as well as it looks like a pretty good setup together. Can't wait to get it! Should improve my videos a bunch!
Paul
Old Apr 20, 2013, 06:47 AM
mitsaras is offline
Find More Posts by mitsaras
total newbie
mitsaras's Avatar
Greece, Makedonia Thraki, Thessaloniki
Joined Jan 2012
Hi, what are some good motors to use with the spidex, I know quaternium recommend the EMP2830/11 1120kV, any other suggestions?
I would like to fly with 4S, slow/easy for AP, hopefully around 7-8mins.
Also, how long/wide is the battery space, can it fit a 4000mAh 4S?
thx
mitsaras is offline Find More Posts by mitsaras
Old Apr 20, 2013, 08:49 AM
moriwaky is online now
Find More Posts by moriwaky
Spain, Valencia, V
Joined Nov 2007
If you want to use a 4s 40000 mha you will have no problem with the battery bay. I use a gensace 3s 4000 mha and the size itīs the same as the 4s but little bite wider.
For 4s you will need a lower kw motors maybe around 900 kw but it will depence on what prop will you use.
moriwaky is online now Find More Posts by moriwaky
Old Apr 20, 2013, 10:03 AM
mitsaras is offline
total newbie
mitsaras's Avatar
Joined Jan 2012
Thank you moriwaky, btw I like your videos very much!
What props are you running with the 3S? I was thinking 8" or 9"
Old Apr 20, 2013, 10:19 AM
Altimat is offline
Find More Posts by Altimat
FPV Recon
Altimat's Avatar
United States, TX, Liberty Hill
Joined Nov 2005
I like the 4S/900KV with 10-3.8 DJIs.
Altimat is offline Find More Posts by Altimat
Old Apr 20, 2013, 10:55 AM
mitsaras is offline
total newbie
mitsaras's Avatar
Joined Jan 2012
Are you using the DJI motors as well? Can they handle the load with gimbal, Gopro & FPV Tx?
PS Just noticed you're in Texas, hope you're far away from the recent events...
Old Apr 20, 2013, 11:46 AM
mitsaras is offline
total newbie
mitsaras's Avatar
Joined Jan 2012
One other question moriwaky, if I may, does the BL gimbal allow access to the GoPro's USB port for video out?
Old Apr 20, 2013, 11:50 AM
Spain, Valencia, V
Joined Nov 2007
yes there is enought space for a right angle conector for FPV output. All my video was done in FPV.
Old Apr 20, 2013, 12:02 PM
aka Helidaho
Joined Jun 2010
I would think it would be very difficult to fly from gimbal stabilized video as you wouldn't know the angle of the craft as the video would always look level.
I plan to have a separate FPV cam but am wondering if there is a place to mount it where the gimbal wont be in the way?
Old Apr 20, 2013, 12:41 PM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
I too was wondering about that as I intend to connect the video to the GoPro at some point. It seems plenty of people do fly this way with gimbaled cameras. You certainly can tell if you are pushing the right stick forward. My guess is you get used to knowing if you are flying crooked or not and this mostly would be to fight the wind I would think... thus being OK too.
As for motors. When I get mine I will be using Sunnysky V2216 800s, 9inch Graupners and 4s 3300 mah batts and I'll have the Spidex V2 frame. I'll report back when I see how that works. I'm thinking 10 inch Graupners might give more lift but I bought the 9 inch ones to make sure they were not in my shot using the Discovery.
AlanGold is offline Find More Posts by AlanGold
Old Apr 20, 2013, 09:43 PM
Altimat is offline
FPV Recon
Altimat's Avatar
Joined Nov 2005
About 100 miles upwind when it happened and we noticed nothing here.
They are TBS motors and it flew great at 5.25 lbs. (8400mA).
I'm flying with the GoPro on this latest rebuild. Not seeing the attitude of the quad when flying FPV should not be an issue at all IMO. Flight is gyro controlled with auto-leveling and the quad does exactly what stick inputs tell it to do. I see no need for visual confirmation of attitude.
There is another option besides the USB for video out.
Old Apr 20, 2013, 11:21 PM
aka Helidaho
Joined Jun 2010
True, I guess for basic, simple, slow FPV flying in auto level mode where the FC is doing most of the work then the gimbal stabilized video from the GoPro would work okay. It would be good for making sure you're getting the shot you want, that's for sure.
New Product GOPRO FPV Spider Quadcopter V4.0 + Anti Virbation Mount (NEW Pics Updated 15Apr2012) DiVidesign Multirotor Talk 98 Nov 05, 2013 06:12 AM
Build Log *NEW* X468 FlameGear GoPro Camera Mount/LG For DJI Flame Wheel Frames(Build Log) Z06 Tony Multirotor Talk 293 Jan 07, 2013 08:26 PM
Video Quadcopter flight with gopro mop Electric Heli Talk 0 Jan 23, 2012 08:04 AM
Sold RC-Carbon 650mm Y6 frame with GoPro mount Sid3ways Aircraft - Electric - Multirotor (FS/W) 22 Aug 19, 2011 08:24 PM
Discussion Testing X468 Frame with GoPro mount cdi3d Multirotor Talk 53 May 05, 2011 06:31 PM
