Old May 22, 2012, 07:37 PM
Dave8888 is offline
Find More Posts by Dave8888
United States, AZ, Seligman
Joined Nov 2011
Question
How do you tell which tricopter firmware you have?
How do you tell the differences between tricopter firmwares? I am not asking about all the different versions, just the difference between Kaptein Kuk's KK, Minsoo Kim's XX KR, and Mike Barton's XX.
Dave8888 is offline Find More Posts by Dave8888
Old May 22, 2012, 08:50 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
Let me add to the question. I flashed the KK board for Dave but I don't remember which firmware I flashed on it. It is definitely not the Mike Barton's version. So it is either Minsoo Kim's or KK's original. It seems like he can plug in tail servo to motor slots 4 and 5 to reverse the servo direction. So that makes me think I may have flashed it with the Minsoo Kim's firmware.
I have not used the original KK tricopter firmware. From everything that I have read it does not have the feature to reverse the tail servo direction by plugging it into motor slots 4 or 5.
Does anyone know for sure?
SeismicCWave is offline Find More Posts by SeismicCWave
Old May 22, 2012, 09:24 PM
Dave8888 is offline
Joined Nov 2011
My main question about this, I think I found out researching. KK's original and Minsoo Kim's both are adjusted through the pots in the same way right? Roll pot is P for pitch an roll, Pitch pot is I for pitch and roll, and Yaw pot is P for yaw. Am I correct? Also I read Mike Barton's firmware needs a LCD screen to adjust everything, again am I correct?
Old May 23, 2012, 04:30 AM
er9xuser is offline
Find More Posts by er9xuser
Slovenia, Ljubljana
Joined Sep 2011
Minsoo's FW doesn't have PID included. Just raw gyro gain
kapteinkuk's and Mike's does have PI. But with Mike's FW you have to have LCD. Kaptein's have roll pot for P and pitch pot for I.
er9xuser is offline Find More Posts by er9xuser
Old May 23, 2012, 01:35 PM
AMA 46133
Hawaii
Joined Feb 2003
>> KK's original and Minsoo Kim's both are adjusted through the pots in the same way right? <<
KK V1.X and Minsoo Kim V1.X and 2.X both adjust through the pots the same way. All the gains are adjusted via the three pots.
>>Roll pot is P for pitch an roll, Pitch pot is I for pitch and roll, and Yaw pot is P for yaw. <<
NO, that is only valid in the "improved" KK firmware V4.X.
>>Also I read Mike Barton's firmware needs a LCD screen to adjust everything, again am I correct?<<
Yes.
Old May 23, 2012, 02:29 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
On KK v1.6 Tricopter firmware, roll pot is P for pitch+roll, pitch pot is I for pitch+roll, yaw pot is P for yaw (same as KK quad v4.7). On earlier KK Tri firmware it's just simple pitch, roll and yaw according to the labels on the board.
mattcro is offline Find More Posts by mattcro
Old May 23, 2012, 02:42 PM
Dave8888 is offline
Joined Nov 2011
So, Minsoo Kim v2.5 Tricopter is just gyro gain on the pots, no PI loop?
Old May 23, 2012, 03:12 PM
AMA 46133
Hawaii
Joined Feb 2003
Minsoo doesn't have PI.
Discussion Dymond D47 servo, Which version do you have on hand, how can you tell??? TDboy Hand Launch 5 Apr 21, 2012 02:26 AM
Razor 300 motor how do you tell which wires are which steve ypsi mi Power Systems 3 May 28, 2004 05:25 PM
Question Do You have a MSW and a MSW250? Tell me how you like'em! Helicool Foamies (Kits) 7 Feb 29, 2004 10:21 AM
How do you tell if you have damaged windings? Paul Power Systems 1 May 13, 2002 02:37 PM
How do you tell if you have a cold solder? Foxtrot Power Systems 6 Jul 28, 2001 07:56 PM
