Old May 22, 2012, 05:29 PM
snipeworm is offline
Find More Posts by snipeworm
Snipe the Skies!
snipeworm's Avatar
United States, CA, Roseville
Joined Feb 2012
Question
Are flaps and ailerons included in wing loading calcs?
Hi guys,
This may be a silly question but are the ailerons and flaps included when talking about wing loading? And lastly, what about the nacelles? Do I need to subtract the nacelles out since they are rounded and don't appear to help flight characteristics?
Thanks!
snipeworm is offline Find More Posts by snipeworm
Old May 22, 2012, 05:34 PM
SeanAlexander is offline
Find More Posts by SeanAlexander
To Slip is Divine
Joined Sep 2011
Yes, control surfaces are calculated and nacelles all depend on the nacelle. Some nacelles are lifting surfaces and are calculated.
SeanAlexander is offline Find More Posts by SeanAlexander
Old May 22, 2012, 05:46 PM
Snipe the Skies!
snipeworm's Avatar
Joined Feb 2012
How about these nacelles? Should I subtract for those? (B-25)
Old May 22, 2012, 06:40 PM
Lnagel is offline
Find More Posts by Lnagel
Senile Member
Lnagel's Avatar
Moab, Utah, USA
Joined Apr 2003
Generally wing area used for calculating wing loading is simply the wingspan times the mean aerodynamic chord (MAC). The areas of the wing covered by the fuselage and any nacelles are ignored (not subtracted out), as are any fuselage or nacelle areas that extend beyond the wing boundaries. Those ignored areas will have some effect, but it will be minimal.
Larry
Lnagel is offline Find More Posts by Lnagel
Old May 22, 2012, 06:51 PM
Snipe the Skies!
snipeworm's Avatar
Joined Feb 2012
Cool thanks!
Discussion habu play in ailerons and flap lorhd2005 Electric Ducted Fan Jet Talk 2 Apr 30, 2012 06:42 PM
Wanted Wanted Topaz Center section with flaps and right wing with ailerons icharus Aircraft - Sailplanes (FS/W) 10 Apr 27, 2012 04:25 PM
Discussion what is habu wing area ? for wing loading calc ? rcfun2005 Electric Ducted Fan Jet Talk 1 Mar 03, 2012 04:35 PM
Discussion camber: Are flaps the same as Ailerons? hidaven Sailplane Talk 4 Feb 04, 2012 11:26 AM
Wing Area/Load Calc Question Basil Foamies (Kits) 2 Jan 19, 2004 11:08 PM
