Old May 22, 2012, 03:26 PM
PsychoDragon is offline
Find More Posts by PsychoDragon
Joined May 2012
Help me identify this plane I inherited in 1997
I posted in the Beginner's forum and they pointed me to this forum. Any idea what this plane is would be greatly appreciated!
The link to my original post:
http://www.rcgroups.com/forums/showthread.php?t=1650188
PsychoDragon is offline Find More Posts by PsychoDragon
Old May 22, 2012, 05:31 PM
AndyOne is offline
Find More Posts by AndyOne
Oxford Panic
AndyOne's Avatar
United Kingdom, Oxford
Joined Feb 2003
The fin shape is very Ed Kazmirski, but beyond that I wouldn't like to guess.
A.
AndyOne is offline Find More Posts by AndyOne
Old May 22, 2012, 06:58 PM
Curare is offline
Find More Posts by Curare
KE your cub.
Curare's Avatar
Australia, WA, Perth
Joined Jun 2005
Oh god, now you've said it.
Curare is offline Find More Posts by Curare
Old May 22, 2012, 09:31 PM
doxilia is online now
Find More Posts by doxilia
doxilia's Avatar
Montreal, Canada
Joined Mar 2008
That's pretty funny Greg...
David
doxilia is online now Find More Posts by doxilia
Old May 22, 2012, 11:27 PM
roncoleman is offline
Find More Posts by roncoleman
Joined Oct 2007
Try RC Universe Classic Pattern section. I think they ID'd that one.
roncoleman is offline Find More Posts by roncoleman
Old May 23, 2012, 01:09 AM
EscapeFlyer is offline
Find More Posts by EscapeFlyer
CPA# 39
EscapeFlyer's Avatar
United States, MN, Brooklyn Center
Joined May 2009
doxilia-
David
HA!!!! You know it's coming....
EscapeFlyer is offline Find More Posts by EscapeFlyer
Old May 23, 2012, 09:55 AM
hook57 is offline
Find More Posts by hook57
hook57's Avatar
United States, IL, North Aurora
Joined Sep 2009
Out with the nose plugs, that odor is about to get strong... (sorry, couldn't help myself again).
hQQk
hook57 is offline Find More Posts by hook57
Old May 23, 2012, 10:51 AM
Vertigo II is offline
Find More Posts by Vertigo II
Former Guppy Flyer
Vertigo II's Avatar
Simi Valley, California
Joined Jan 2010
Fresh- like a summer's eve.
Vertigo II is offline Find More Posts by Vertigo II
Old May 23, 2012, 11:28 AM
PhoenixFlyer is offline
Find More Posts by PhoenixFlyer
PhoenixFlyer
PhoenixFlyer's Avatar
United States, SC, Campobello
Joined Dec 2006
The Fuselage
I will go out on a limb, and say it is a Hartman Zeus fuselage. You can see the Taurus fin, all that was needed here, was the Taurus wing. We used the Zeus fuselage and a Taurus wing, swept at the LE, straight TE, with 1" under each tip. I have not see a white gel coat Hartman fuselage, all brown resin that I ever built.
Vince (Crank)
PhoenixFlyer is offline Find More Posts by PhoenixFlyer
Old May 23, 2012, 12:09 PM
Mike Denest is offline
Find More Posts by Mike Denest
Brighto?
Mike Denest's Avatar
United States, DE, Newark
Joined Dec 2003
Nope, not a Hartman Zeus. Dwight used a green tinted resin and and placed an ID label inside all his fuselages. He installed some support structure in the wing saddle and a firewall. The original Zeus Taurus fuselage was supplied with no vertical stab as was the Mk. II and Mk. IV. There was a variation of the Mk. I for a design called the Sweeper (published in M.A.N.). It used a Taurus wing modified for aft sweep and a Taurus stab also modified for aft sweep with dihedral. The engine was inverted. The Zeus Mk. II was designed for the deBolt Interceptor, the Mk. III has a vertical fin and is similar to Vic Husak's King Altair in looks and size. The Zeus Mk. IV is smaller and was designed for a Kraft Kwik Fli wing section. Dwight also left the aft end of the fuselage underside open so you could install pushrods, etc. then close it up with balsa sheeting.
I'll say that it is a typical knockoff of the Taurus or maybe an Orion. In the early sixties there were several vendors who made fuselages to fit the Taurus or Orion wing and stab. I'll bet that if you had a Taurus wing, it would fit nicely.
I do have a question about the wing trailing edge at the center section. From one of the pictures, it looks like it is swept. Could be the angle of the view though.
FMI: http://www/vintagercsociety.org
Mike Denest is offline Find More Posts by Mike Denest
Old May 23, 2012, 12:57 PM
stuntflyr is offline
Find More Posts by stuntflyr
stuntflyr's Avatar
United States, AZ, Tucson
Joined Jun 2010
Looks very neat, I like it. To the OP...
Seems as if it's a Zeus-like fibreglass fuselage (see above for explanation of fibreglass fuse maker) of a Taurus knock-off (Taurus was a 60's Top Flite kit of a popular Nats and Worlds Pattern winner) with swept wings like a Phoenix-or-something (early swept wing pattern model of the 60's).
The model was to have a clear bubble canopy glued to the top, most likely.
Good looking fuselage, worth building if you like early Pattern models. One could find a few swept wing 60's Pattern plans and see if it fits the sweep, go with that, paint it up in a 60's era scheme and have a ball.
Chris...
stuntflyr is offline Find More Posts by stuntflyr
Old May 23, 2012, 05:09 PM
imodel is offline
Find More Posts by imodel
USA, CT, Farmington
Joined Nov 2003
The nose moment is far too long to be a Taurus. It sure does have a Zeus look to it though.
R
imodel is offline Find More Posts by imodel
Old May 24, 2012, 07:14 AM
Brighto?
Joined Dec 2003
I think Chris got it. Note the rear of the fuselage at the center section. It certainly looks to have sweepback. Also note the nose moment compared to the RCM cover. I'll vote Phoenix.
Old May 24, 2012, 09:54 AM
PhoenixFlyer
Joined Dec 2006
More Info on this Fuselage
Did some research, these pictures going back to 11/18/2007. On RCU, a member named Dbacque, posted these, and Raindave did a photoshop with a wooden Phoenix. Looks like all points to that. Refreshing my memory, you are correct on the numbered fuselage of Hartman.
These pictures are from 2007, and it could be the same fuselage we are looking at today. After first click on these pictures, click agan.
Included here, is original wooden Phoenix V.
PF (Crank)
Found Can someone help me identify this? wing881 Aircraft - Sailplanes (FS/W) 22 May 20, 2012 07:48 AM
Discussion Help me identify a plane I inherited PsychoDragon Beginner Training Area (Fuel) 6 May 13, 2012 01:23 PM
Question Can someone help me identify this car indycobra Off-road Cars 7 Apr 05, 2012 12:23 PM
Help! Identify this plane for me! kromaey Beginner Training Area (Fuel) 7 Feb 29, 2012 08:16 PM
Help! Can anyone help me identify this plane? ctib Vintage & Old-Timer Designs 8 Feb 02, 2012 10:47 AM
