Old May 22, 2012, 02:43 PM
TylerL is offline
Find More Posts by TylerL
United States, IL, Momence
Joined Nov 2003
motor for 2m pattern/sport plane
I have a 2 meter pattern/sport plane that I converted from nitro 1.80 four stroke to electric. Running on 10s and using a Hacker A60-20s V2 28P motor the plane simply does not fly properly. I am forced to fly at 80% throttle stick, verticals are weak, and the plane just seems to drag through the air instead of fly on the wing and cruise.
I believe I need a motor that can run a smaller prop at higher rpm than this hacker is happy to run. The Hacker seems to want a 22" in prop range, but due to airframe limitations I am forced to run an 18" prop.
Can anyone recommend a motor that will give this 14 lb airframe unlimited performance on an 18" propeller?
I am using a Castle Creations 80HV esc. The version before the ice series came along.
TylerL is offline Find More Posts by TylerL
Last edited by TylerL; May 22, 2012 at 02:57 PM. Reason: wrong model number listed
Old May 22, 2012, 02:55 PM
wingster is offline
Find More Posts by wingster
Massachussets
Joined Nov 2005
The Hacker A60-20S likes a 18-19inch prop. A few years back we ran the A60-20S on 11lb pattern planes. Since then most have switched too a lower KV motor and run 20.5-21" props. For a 14lb plane you need a bigger motor. Possibly the A60-M series. with a Kv of about 200 on 10s. You might want to consider 12S since on 10S we are pushing 75-95Amps on a 10-11lb plane.
wingster is offline Find More Posts by wingster
Old May 22, 2012, 02:58 PM
TylerL is offline
Joined Nov 2003
Sorry, I had to edit my post to reflect the proper motor that I have installed. It is an A60-20s V2 28p.
Tyler
Article Dirty Birdy Sport/Pattern .60 ARF Review CSpaced Classic Pattern Flying 85 May 11, 2015 04:40 PM
Discussion What is the best vintage 60 size motor for a classic pattern plane? bpink43 Classic Pattern Flying 50 Mar 27, 2012 12:05 PM
For Sale E-Sport 8 Pattern Plane opualuan Aircraft - Electric - Airplanes (FS/W) 0 Mar 12, 2012 02:18 AM
Discussion 2M Pattern Plane/12S Set Up? ben_beyer F3A Pattern 5 Nov 04, 2011 09:16 AM
Sport/pattern plane for Phasor 30/3 Flyin'jack Sport Planes 3 Jun 03, 2001 03:01 PM
