Old Jun 11, 2012, 03:52 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
so if we want to use the HF Gimbal and HV servos just send only the signal wire from the Rx to the HF Gimbal.... that way no power is going from the HF G to the Rx....
simple enough.... actually come to think about it that is just an unregulated circut, the only HF could have done it differently is to put a 5v power regulator on the Rx side of the connectors
Adidas4275 is offline Find More Posts by Adidas4275
Old Jun 11, 2012, 10:22 AM
ThaiskyDigital is offline
Find More Posts by ThaiskyDigital
Thailand
Joined Apr 2006
Bad Manual
Originally Posted by photronix View Post
I am finishing up the manual......next few days.
The Power input on the HoverflyGIMBAL is directly output to the servos and the receiver. If the servos need 6v then you MUST power the HFG with 6v. If you use a 3s battery it will destroy the receiver and servos!
Use a BEC to power the HFG--->Servos--->receiver. Its all the same connection.
How you will responsible to my two servo (savox) it damage from 4s battery.
I do not know about my Rx yet.
This is so bad.
ThaiskyDigital is offline Find More Posts by ThaiskyDigital
Old Jun 11, 2012, 12:41 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
does anyone know how to slow down the tilt servo and make it run on the all travel of the tick
flytahiti is offline Find More Posts by flytahiti
Old Jun 11, 2012, 05:17 PM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
If you believe that you have damaged servos or RX because you used greater than the recommended voltage as a result of the incorrect entry in the manual please PM me. I will take care of this on a case by case basis.
photronix is offline Find More Posts by photronix
Old Jun 11, 2012, 07:04 PM
Adidas4275's Avatar
Joined Mar 2011
thats great to hear....
although i am not sure if the "manual" or quick start guide was wrong.... since it said it was unregulated....
but thats is a nice offer to anyone who had an issue...
Old Jun 11, 2012, 10:39 PM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
The Gimbal manual will be posted on our site in the morning. But for now here ya go.
Understand that it is the first version and we need to go through it carefully to check for errors.
Old Jun 11, 2012, 11:38 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
thanks fellas
elliott000 is offline Find More Posts by elliott000
Old Jun 12, 2012, 12:46 PM
flashervn is offline
Find More Posts by flashervn
Joined Sep 2011
Thanks for the manual. Can people with PH AV200 post screenshots of their settings roll and pitch,or including Max&min with +gain and scale factor( i find this the hardest to tune)
I am quite happy with my pitch settings is as follow:
Scaling factor: 83750
Min width:0.98753
Max width:2.08064
Gain:710.
I am struggling to tune my roll. Another issue is I cannot get pitch to do a full 90 degree in Angle Velocity mode. Angle Position works just fine. Any guideline would be nice.
Minh
flashervn is offline Find More Posts by flashervn
Old Jun 12, 2012, 03:36 PM
flytahiti's Avatar
Joined Mar 2010
with the new user guide everything works fine now. i use a single stick with velocity angle on roll and tilt like a joystick. but the horizon is still drifting in less than one minute.
any idea ?
Old Jun 13, 2012, 05:16 AM
Thailand
Joined Apr 2006
Damaged servos
PM sent
Old Jun 13, 2012, 01:07 PM
Adidas4275's Avatar
Joined Mar 2011
he said PM, call or email him
Old Jun 15, 2012, 03:08 AM
Joined Sep 2011
Anyone got a solution for drifting centers on both pitch and roll? This always happen during flight for me. Thanks
Old Jun 15, 2012, 03:13 AM
Adidas4275's Avatar
Joined Mar 2011
Gary found the board to be sensory to EMI from from cameras perhaps moving where the board is located could be a fix?
I have not seen center drifting.
I'll have mine tomorrow.
Old Jun 15, 2012, 03:29 AM
flytahiti's Avatar
Joined Mar 2010
mine drift without camera
Old Jun 17, 2012, 12:43 AM
Joined Feb 2012
I found in flight that my av200 would loose its center in both roll and pitch if i induced yaw on my hexa. Im running it as a 2 axis controller. Any news on this... I haven't flown since i buried it in the dirt lol but rebuild is near completion
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1788 Feb 03, 2016 10:32 AM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
