Is enabled now.
When I put the switch in pos "0" no shaking, it compesates butI can't use the sticks. Pos, 2 and 3 the pan axis is shaking badly back and forth and I can use the sticks but that doesnt stop the shaking. The center point on the servo tab is set at 1.5ms. What else can I adjust? Only problem I have is with the Yaw (pan) channel Thanks |
United States, CA, Santa Cruz
Joined Dec 2011
Power
Hey guys,
I'm using a spectrum ar8000 for my flight control rx. It has an open channel that I have connected to the HFG pitch channel. My ar8000 gets power from my flight pack. When I plug in my flight pack, my HFG gets power and so does my gimbal. I have my 6v ubec and 3slipo alll ready to go. I'm not sure if I need to connect it now. My servos do run best on 6volts. Will my 6volts overide the volts coming from the ar8000 rx?? Should I plug it in also? Thanks
United States, TX, Thrall
Joined Feb 2010
You should ony have one source of power coming in to the gimbal cotroller not two. If you are using a single receiver you only need to run a single wire for signal to the receiver using a common ground. If you use a seperate battery you will need to run ground as well just not hot lead.
Michael64 Quote:
Joined Dec 2011
So pull the red wire connecting the receiver to the HFG? |
You need to adjust the center point of your yaw servo to get it to stop spinning.
With the below fireware update, What is the output rate for servos before the v1.9 firmware update?
---------------------------------------------------------------------------------------------------------------- HoverflyGIMBAL firmware version 1.9 Ben Halsted posted this on Jan 22 03:15 pm There are two changes in this firmware. 1) You can now select the output rate for the servos (200hz, 100hz, or 50hz). Analog servos should use 50Hz. The majority of digital servos will use 200Hz, but a few on the market may use 100Hz. 2) There is a feature to limit the roll servo when the tilt angle exceeds a certain amount. This is useful for some of the more exotic continuous rotation gimbal designs in which the roll axis comes after the pitch axis in priority. |
| Thread Tools | |
| Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* | Z06 Tony | Multirotor Talk | 1687 | May 15, 2013 01:43 AM |
| Discussion HoverflyGIMBAL Demonstration Videos | photronix | Hoverfly Technologies | 10 | May 18, 2012 03:53 PM |
| Link HoverflyGIMBAL Manual and Setup Client | hoverben | Hoverfly Technologies | 1 | May 17, 2012 02:25 PM |
| Discussion HoverflyGIMBAL - Input Voltage? Manual? | defxxx | Hoverfly Technologies | 10 | May 17, 2012 01:54 PM |
| New Product HoverflyGIMBAL - Now Shipping! | photronix | Multirotor Talk | 9 | May 15, 2012 12:46 PM |
