Old Nov 25, 2012, 03:01 PM
Jeffem62 is offline
Find More Posts by Jeffem62
Jeffem62's Avatar
United States, TX, El Paso
Joined Apr 2012
How do I go back to version 1.3. Having major coupling with Version 1.7 r2
Jeffem62 is offline Find More Posts by Jeffem62
Old Nov 25, 2012, 03:26 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Use the firmware upgrade software. It has the previous firmwares within it.
gww528 is offline Find More Posts by gww528
Old Nov 25, 2012, 03:35 PM
Jeffem62 is offline
Jeffem62's Avatar
Joined Apr 2012
Looking at it now but:
Where do we download the v1.03 configuration Client ?
I only see on hoverflytech ..Config Client 1.7 for download.
I know that when I got the board it was loaded with older firmware code ( using 1.7 Config Client) would never connect.
I flashed to 1.7 firmware and 1.7 config client and it connects.
But same problem as describe here..
I don't see where to download the 1.03 config client .
anyone have a copy ?
Old Nov 25, 2012, 06:14 PM
Jeffem62 is offline
Jeffem62's Avatar
Joined Apr 2012
Ok got it down loaded. Thanks Gary for walking me through it. Hopefully this version will stop the coupling.
Old Nov 25, 2012, 06:44 PM
jerrymeister is offline
Find More Posts by jerrymeister
jerrymeister's Avatar
Joined Oct 2011
So when I put version 1.3 back was I also supposed to downgrade the computer software as well?
Jerry
jerrymeister is offline Find More Posts by jerrymeister
Old Nov 25, 2012, 09:29 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Jerry
I did not downgrade the computer software. It works with v1.03, v1.07 & all in between.
Old Nov 26, 2012, 12:18 AM
flashervn is offline
Find More Posts by flashervn
Joined Sep 2011
Hi guys, anyone can help me to confirm that Angle Velocity mode does not work in 1.03? I tried everything I could but failed to make it work in1.03. 1.6 and 1.7 works fine but with heavy jitter. Thanks!
flashervn is offline Find More Posts by flashervn
Old Nov 28, 2012, 12:34 AM
UAV.Pilot is offline
Find More Posts by UAV.Pilot
Joined Sep 2012
WOW I just read all 43 pages of this thread...all I can say is Im exhausted for you all...
and here I thought it was a plug and play controller,
the one thing I did get out of it is Gary makes some killer gimbals and the results are in the videos...
UAV.Pilot is offline Find More Posts by UAV.Pilot
Old Nov 28, 2012, 06:48 AM
elossam is offline
Find More Posts by elossam
Joined Feb 2006
43 pages in a single read for me too looking for an answer about why the tilt control in stick mode uses halve the stick range 1 to 1.5 ms instead 1 to 2 ms even when it reads right the output pulse.
elossam is offline Find More Posts by elossam
Old Nov 28, 2012, 08:32 AM
Joined Sep 2012
I think for the time being i will order a ... for my roll, and Pan on my PS1...not that it does not present its own challenges but...
also dude flying on Naci, good flying, and like me big balls flying continuously over water, I do it all the time. good job
Old Dec 10, 2012, 05:54 AM
sportcam is offline
Find More Posts by sportcam
Joined Dec 2012
today i started my hoverfly gimbal setup and saw, there is a new version online.
1.8
does anyone know the difference between 1.7 rev 2 to 1.8 ?
thanks
sportcam is offline Find More Posts by sportcam
Old Dec 10, 2012, 06:31 AM
gww528 is offline
gww528's Avatar
Joined Mar 2008
I do not know what the difference is but it did eliminate the jitters I had on v1.07.
Old Dec 10, 2012, 06:55 AM
sportcam is offline
Joined Dec 2012
thx a lot for your fast answer.
is this the only difference?
what can the hoverfly support can say about?
on their website there are no infos between the versions
Old Dec 10, 2012, 07:29 AM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Originally Posted by c3d76 View Post
Hmm, looks like I missed a setting in 1.8 that seems to have done the trick
In the HF configurator, go to Config and calibration > Gimbal mode > calculation modes, and change both to mode 1 instead of mode 0.
Info in attached pic...
I'll have to go on a test flight when rain stops (again), but it looks good on the footage I just took "fake" flying the Lobster around the house
The above post is from here...
http://www.rcgroups.com/forums/showp...postcount=5914
Old Dec 10, 2012, 07:33 AM
gww528 is offline
gww528's Avatar
Joined Mar 2008
https://hoverflytech.zendesk.com/ent...mbal-1-8-rev-0
HoverflyGIMBAL 1.8 rev 0
Dan Burroughs
posted this on Dec 04 08:48 pm
Components Included:
HoverflyGIMBAL Firmware (version 1.8 rev0)
HoverflyGIMBAL Setup Client (version 1.8 rev0)
This version of the firmware corrects the roll drift (sometimes described as a yaw axis coupling) error that was present in the previous version of the firmware. It also has a couple features that allow the user to select behaviors that were present in earlier versions of the firmware. It is recommended to first try this version with default settings for the new featues (see below - mode 0 angle and mode 0 rate calculations).
New features:
Gimbal Angle Calculation Mode
The angle calculation is used to determine the orientation of the HoverflyGIMBAL. The calculation mode can be set on the Gimbal Mode configuration page in the setup client. The default value is ‘mode 0’.
Mode 0 is a more accurate calculation of the orientation of the HoverflyGIMBAL. It is particularly important to use mode 0 when attached to a gimbal with continuous rotation servos (a gimbal where the sensor is attached to the camera tray).
Mode 1 is designed to allow users to mimic the behavior of the system in earlier versions of the firmware. It is not our recommended mode, but a number of users have expressed a preference for this behavior.
Gimbal Rate Calculation Mode
The rate calculation is used in conjunction with the ‘rate gain’ factor on a servo. The calculation mode can be set on the Gimbal Mode configuration page in the setup client. The default value is ‘mode 0’.
Mode 0 is designed to eliminate axis coupling issues that can arise when the HoverflyGIMBAL is mounted far away from the center of rotation. However it may produce some jitteriness if there is a lot of vibration in the system.
Mode 1 produces a smoother value, which allows for higher rate gains. However if the HoverflyGIMBAL is mounted far away from the center of rotation, some coupling between axes may be seen while performing more extreme maneuvers.
Updated features:
Roll Horizon Stabilization / Vibration Dampening
Some users have been experiencing drift on the roll axis. This appears to have been due to vibration during flight. Additional filtering on the accelerometer data as well as the calculation of the rotational rate has been added to counter this effect.
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
