Old Oct 06, 2012, 06:42 AM
darkovujasinovic is offline
Find More Posts by darkovujasinovic
Bosnia
Joined Dec 2010
Originally Posted by Daloaf View Post
Did you go into the receiver config menu and click on Current Angle Set Range button on the pitch channel? From there you can adjust the Max Deflection, which should control how far it tilts. Depending on your gear ratios, servos, etc, you might have to put in a number higher or lower then 90 to actually get 90 degrees. Mine tilts from level to 90 degrees with a setting of 87, go figure.
I use Angle Position as well.
I tried endpoints and it does not help !
I would like to know if I can use angle velocity to tilt the camera 90 degrees down or not ?
With angle position I can get 80 degrees but not more, even if I set over 90 degrees in receiver setting it does not move more than 80 degrees and with angle velocity the maximum is 45 degrees !
darkovujasinovic is offline Find More Posts by darkovujasinovic
Old Oct 06, 2012, 10:06 AM
Bosnia
Joined Dec 2010
Update :
I managed to get 90 degrees with angle position but I would like to know if it is possible or not to be done with angle velocity as with angle velociti the servo goes only 45 degrees!
Old Oct 07, 2012, 12:11 AM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
To tell you the truth, I don't actually know what angle velocity does. I understand angle position and it works for me to get 90 degrees (plus another 30 degrees for tilt) and I can control the speed of the tilt, so I'm happy. Here are two videos I took recently using the HF gimbal controller with a Askman AG550 v2 gimbal and a Sony NEX 5N on my DJI F550:
DJI F550 and Askman AG550 over the Golden Gate Park Windmills (4 min 57 sec)
DJI F550 with Askman AG550 V2 gimbal including Quadcopter midair crash (5 min 7 sec)
Daloaf is offline Find More Posts by Daloaf
Old Oct 07, 2012, 02:58 AM
Bosnia
Joined Dec 2010
http://www.youtube.com/watch?v=_zsjA...ature=youtu.be
http://www.youtube.com/watch?v=W5rFJmBNqFA
Very nice videos
You probably use your angle position on the slider so you do not see the difference between position and velocity as when you use it on the second radio on the stick once you release the stick the tilt goes to the start position and does not stay where you leave like it is the case with velocity !
Old Oct 07, 2012, 11:26 PM
Daloaf is offline
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Originally Posted by darkovujasinovic View Post
Very nice videos
Thanks for explaining it, I learned something new today
Old Oct 10, 2012, 01:42 AM
crashtested is offline
Find More Posts by crashtested
crashtested's Avatar
USA, RI, East Providence
Joined Jun 2010
Originally Posted by Twister773 View Post
Using 1.06, happy with everything except for the yaw coupling problems and the fact that sometimes the horizon will stay level and perfect and other times it gets stuck crooked and almost like it forgets where level is...
http://www.youtube.com/watch?v=Af57moqVzzA&hd=1
Great shots man.
Thats a whole day of over-water... You must trust your rig!
crashtested is offline Find More Posts by crashtested
Old Oct 12, 2012, 04:31 PM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
To the guys at Hoverfly...would it be possible to let pan and pitch have their own smoothing factor setting? My pan was perfect at 25 but pitch needs to be at like 5-10...any chance at doing this? I am still trying to figure out why it doesnt like to stay level and will also change level while yawing...the board is not close to my camera but it is somewhat close to an esc wire. I may reroute them and see how it goes.
Twister773 is offline Find More Posts by Twister773
Old Oct 12, 2012, 04:39 PM
Private Pilot
Twister773's Avatar
Joined Jul 2009
Work in progress which is why I have it as unlisted but here it is anyways.
http://youtu.be/1S-jc1_WK_k?hd=1
Old Oct 12, 2012, 05:18 PM
Forrest12 is offline
Find More Posts by Forrest12
DS state of origin NSW Vs QLD
Forrest12's Avatar
Joined Jul 2009
Love it!!
Great work Twister.
Forrest12 is offline Find More Posts by Forrest12
Old Oct 13, 2012, 10:39 AM
hexa is offline
Find More Posts by hexa
hexa's Avatar
United Kingdom, Scotland, Edinburgh
Joined Nov 2010
Wow! stunning.
very nice pro shot there .
love the song too.
hexa is offline Find More Posts by hexa
Old Oct 13, 2012, 10:49 AM
hexa is offline
hexa's Avatar
Joined Nov 2010
even better.
pleasure to watch
Old Oct 13, 2012, 04:16 PM
jcmonty is offline
Find More Posts by jcmonty
United States, CA, San Diego
Joined Apr 2012
Awesome stuff, Twister!
Was that lake naci in the wakeboarding shots? Assuming so since you seem to be based out of SLO.
Mind sharing what camera you are using and what post stab software (if any)?
Really professional looking IMO
jcmonty is offline Find More Posts by jcmonty
Old Oct 15, 2012, 07:20 AM
nisouck is offline
Find More Posts by nisouck
Belgique, Région Wallonne, Braine-l'Alleud
Joined Dec 2008
Can't keep horizontality
Hi,
I am a new user of the Hoverfly Gimbal onto my S800.
I made a first setup with version 1.6 and now upgrade with the 1.7a (beta) and get the same problem :
during flight, I loose the horizon, roll goes always to the left (left site goes down and right goes up).
If I rotate with rudder, for some time, horizon become good but don't stay.
Where is the problem, what can I do??
Pan is not enabled, Roll is enabled but transmitter control none and pitch enabled with angle.
Clearly, horizontality react when I give rudder ......
nisouck is offline Find More Posts by nisouck
Old Oct 15, 2012, 04:41 PM
Daloaf is offline
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Almost everyone that is using the HF board has reverted back to firmware 1.03 as that seems to be the last firmware where the horizon tilt during Yaw wasn't that bad (but still present). But it's much more manageable in that older firmware. Also, it really helps to mount the HF board behind the camera, further back the better. Doing these things and getting the correct gains and accel will help you get some really good footage.
Old Oct 15, 2012, 10:54 PM
nisouck is offline
Joined Dec 2008
Thanks I'll do that and let you know my result.
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
