Old Sep 21, 2012, 10:15 PM
photronix is offline
Find More Posts by photronix
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Originally Posted by AEROXOOM View Post
Glad Ben got you sorted, I didn't see Dan when I went into the office to see an Erista test today so I couldn't mention it to him. Can't wait to see your test vids!
- Jeff
That's because he is locked in a dark room in the basement with only his lap top, a 2-liter bottle of diet Coke, and a red swinglie stapler writing his codes.
photronix is offline Find More Posts by photronix
Old Sep 23, 2012, 09:44 AM
tumad is offline
Find More Posts by tumad
Joined Nov 2000
Pan stabilization demo
HoverflyGimbal (3 min 49 sec)
tumad is offline Find More Posts by tumad
Old Sep 23, 2012, 03:52 PM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Nice video, it sure looks like the pan lock is working well.
Daloaf is offline Find More Posts by Daloaf
Old Sep 24, 2012, 05:43 PM
Reginak is offline
Find More Posts by Reginak
Reginak's Avatar
Joined Jul 2011
tumad,
Nice example of a pan lock.
Reginak is offline Find More Posts by Reginak
Old Sep 26, 2012, 06:20 AM
tumad is offline
Joined Nov 2000
Request to developers.
Please explain what Smoothing function does.
Also:
Is it possible to implement compass mode on/off in flight or at the field via stick combo or a switch. On occasion one finds oneself in a situation where the compass has to many disturbances but no laptop with software nearby.
Thanks kindly..
Old Sep 26, 2012, 06:35 AM
tumad is offline
Joined Nov 2000
Message deleted
Old Sep 26, 2012, 01:32 PM
flytahiti is offline
Find More Posts by flytahiti
flytahiti's Avatar
PolynÚsie franšaise, ╬les du Vent, Papeete
Joined Mar 2010
i can't tune the pan, it have hard oscillations !
any Pan setting example for the AV200 ?
flytahiti is offline Find More Posts by flytahiti
Old Sep 26, 2012, 04:04 PM
tumad is offline
Joined Nov 2000
First turn off all trims on your radio for pan servo.
Then launch software
Activate trim servo and find neutral so there is no movement
You must be in mode 0 (manual control) for this.
Go back to radio and set max travel of pan Chanel to about 25%
This will slow down your pan servo to a useable rate. Use a dual rate at 25% for manual control. You are looking for a nice slow pan at full throw. Not fast
Set controller to mode 2 (pan lock) by activating aux switch on radio
Make sure to lift gimbal off the ground for this otherwise copter spins around
Set dual rate on your radio for this mode to a higher value (80%)
Once that is all working correctly go into PID Tuning of pan servo
Set gyro gain to 0 and try
Then 0.5 then 1.0 etc until pan lock is slow and smooth
Mine is at 2.5
Now turn P down to 5000 then go up in 1000 increments
Mine is 100000.
P is the stop factor. To high and it will oscillate
Do the same with I
I is the launch or start to stabilize factor
Mine is at 8000
Gyro gain is the overall effect. To high and it will oscillate like a heli tail that is to twitchy
Good luck
Old Sep 26, 2012, 07:13 PM
flytahiti's Avatar
Joined Mar 2010
thank you . i have tried but still incredible oscillation . i give up , luckily everything works fine except the pan in head lock mode .
Old Sep 27, 2012, 12:38 AM
tumad is offline
Joined Nov 2000
I am not sure you have tried hard enough.
Start from scratch, and think about it for a minute.
Turn all the gains down to 0 and make sure that there is no movement and that you are indeed in heading hold mode (1 or 2)
You can check this in the Receiver tag under CH1
The bottom box changes between 0-1-2 when you activate the different modes.
Check your radio and make sure you have decreased the travel of the pan servo.
Go into PID gains and turn everything to 0 and see what happens.
Old Sep 27, 2012, 06:05 PM
rancherpete is offline
Find More Posts by rancherpete
Joined Dec 2011
Need a way to slow down the gimbal pitch movement via TX
I am still trying to find a way to slow down the manual pitch rate from the lever on my Futaba TX. I can't seem to find a control within the HFG Setup Client to allow me to slow down the MANUAL pitch movement independent of the automatic pitch leveling while in flight. Any thoughts on this?
rancherpete is offline Find More Posts by rancherpete
Old Sep 27, 2012, 06:12 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
The smoothing setting under receiver configuration does this
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Sep 27, 2012, 06:24 PM
Joined Dec 2011
Wow... that worked! Just what I was looking for. Thanks George. Is there by any chance an updated user manual for the HFG as mine makes no mention of this from what I could find. Any info you can share with regard to what is the latest user manual, firmware and software would be good info. As I mentioned earlier I am still getting some roll which throws off my horizon when I yaw very slowly to create a pan effect and I read that this had been addressed at some time in the past. I just want to be sure that I am up to date with everything for the best possible HFG experience. Please let me know and thanks again for the previous tip.
Old Sep 28, 2012, 01:14 PM
SunnyHK is offline
Find More Posts by SunnyHK
Joined May 2012
Share one of my lastest testing with HG board video .
I just cut and put the shots together with the nice song.
It has no any post-stabilization. so you will find there still have some jello effect from the camera gimbal. That is one of my last part need to fix it. i hope i could handle that soon.
Ok, guys enjoy ! the shooting location is my home town Hong Kong. =)
TestingSampleOne (4 min 1 sec)
SunnyHK is offline Find More Posts by SunnyHK
Old Sep 28, 2012, 04:47 PM
Joined Dec 2011
http://www.youtube.com/watch?v=i9JkXvb7_Kw
Great work! Thanks so much for sharing this with us.
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
