Hmm. Definitely call later. See if you can get Dan. If not, I can help. In the demos we've set up it was no where near that slow.
Canada, BC, Vancouver
Joined Feb 2012
Probably to be expected but every gimbal will have completely different gains lok. I plugged garys numbers into mine and it was terrible, off to tune i go in search of results like yours.... How much for the gimbal these days any how gary do u have a webpage? Av200 is good but i cant get it to where u are at. Any pointers on dialing it in? Proccess etc
Joined Feb 2012
I went to do some setting up today and noticed there was firmware 1.01 i updated but now i cannot set the slider i had on tilt back up? I double checked the operation by attaching my camera trigger to it. It works but hoverfly gimbal client does not show any signs of input... whaaat i wanted to shoot some vid while camping this week.
Any help is appreciated Im on gimbal client 1.01 aswell |
edit: also, are you using a mode switch? |
Quick update:
Been talking with George and Dan at Hoverfly and making progress. A factory reset/default settings to gimbal board let me control my pan axis again with my transmitter. Also updated to the new software which Dan put in a PID adjustment for yaw so I could try and fix the slow reacting issue. Somewhat helped for that but another problem I had was if i where to pick up the multi and spin it, the gimbal would stay fairly on its correct heading until i stop spinning, or stop it and spin the other way...the heading would change 20-25 degrees in either direction while turning the multi. Dan has some ideas and some settings that arent in the setup client that he thinks can be adjusted to solve my issue. I will update again once I get the stuff from Dan and am able to test those settings. Dan and George have both been great trying to help and get this issue solved though
I keep popping in here hoping they will post a real video proving it works or hoping to see someone using the pan feature but nope. Nada. |
| Thread Tools | |
| Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* | Z06 Tony | Multirotor Talk | 1687 | May 15, 2013 01:43 AM |
| Discussion HoverflyGIMBAL Demonstration Videos | photronix | Hoverfly Technologies | 10 | May 18, 2012 03:53 PM |
| Link HoverflyGIMBAL Manual and Setup Client | hoverben | Hoverfly Technologies | 1 | May 17, 2012 02:25 PM |
| Discussion HoverflyGIMBAL - Input Voltage? Manual? | defxxx | Hoverfly Technologies | 10 | May 17, 2012 01:54 PM |
| New Product HoverflyGIMBAL - Now Shipping! | photronix | Multirotor Talk | 9 | May 15, 2012 12:46 PM |
