Old Aug 05, 2012, 06:42 PM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
Originally Posted by Razzil View Post
Salmon fishing and flyin ... havin a time ... what rain ... hehe
yeah on that river we were fishing for trout, big huge rainbow trout (24-30")
Adidas4275 is offline Find More Posts by Adidas4275
Old Aug 05, 2012, 06:57 PM
Razzil is offline
Find More Posts by Razzil
Canada, NL, St John's
Joined Sep 2011
wicked .. love fishing .. your videos are great. I can watch hours of the aerial outdoors videos. Hoverfly gimbal is one of the next things on the list. Once I master this flying.
Razzil is offline Find More Posts by Razzil
Old Aug 06, 2012, 11:36 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
I'm really starting to get the HF Gimbal gains dialed in very close now. Here is a short test video I did yesterday using our AG550v2 gimbal on a standard DJI F550. The camera is a Sony RX100.
AG550v2 RX 2 Axis Gimbal Test 01 (3 min 26 sec)
I have the tilt axis gain set at 30.1250, and the roll set to 30.3750, with both acceleration values set to 10. I have the HFG board mounted on top of the AG550's isolated mounting plate, above the camera.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Aug 07, 2012, 02:59 PM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
Probably some of my last footage with the hoverfly gimbal board. Planning on picking up the Free Fly Radian Stabilization so that I can make use of my 3 axis gimbal.
"Home" Teaser (2 min 15 sec)
Twister773 is offline Find More Posts by Twister773
Old Aug 07, 2012, 07:00 PM
elliott000 is offline
Find More Posts by elliott000
Canada, BC, Vancouver
Joined Feb 2012
http://youtu.be/gDL7xDs_BYo
-- Gary
Looks awesome gary, when you say tilt axis gain are you referring to the scaling factor? And the 10 is the bottom. Rate gain
elliott000 is offline Find More Posts by elliott000
Old Aug 07, 2012, 10:28 PM
Benjamin Rowland is offline
Find More Posts by Benjamin Rowland
Benjamin Rowland's Avatar
United States, GA, Atlanta
Joined Feb 2012
Gary, you've got that thing dialed in! Well done.
Benjamin Rowland is offline Find More Posts by Benjamin Rowland
Old Aug 07, 2012, 11:07 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Yes, on both counts.
-- Gary
Old Aug 07, 2012, 11:15 PM
S11D336B is offline
Find More Posts by S11D336B
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
The HoverflyGIMBAL stabilizes on all 3 axis. If you're having trouble, you should contact support so we can help fix it.
http://www.youtube.com/watch?v=6K04Lcg_caU&hd=1
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Aug 07, 2012, 11:20 PM
Adidas4275's Avatar
Joined Mar 2011
From my conversations with twitter he has contacted you guys by phone
And support ticket and has had no solution.
We do need to see demo footage of pan stabilization and heading hold style camera lock.
Seems the HFG smooths out pan axis for a camera op but will not hold the camera in a locked positions.
I have not used pan but this is from my conversation with twister.
Old Aug 07, 2012, 11:28 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
You need to update to the latest firmware/configurator and check the auto compensation box for yaw in the servo config.
HoverflyGIMBAL 3-Axis Gimbal controller (2 min 35 sec)
Site Sponsor
Old Aug 07, 2012, 11:42 PM
Private Pilot
Twister773's Avatar
Joined Jul 2009
http://www.rcgroups.com/forums/showp...96&postcount=1
Have done all of that. For the longest time it would not compensate at all. I also notice in your directions online your screen shot lets you choose between mode switch etc for pan...but the software online those options are greyed out. Moving my aileron stick(pan servo) the pwm in receiver config moves up and down as it should but the pan servo does not work. In the receiver config tab when i move the pitch channel (throttle) the current angle and offset speed numbers change...they stay the same (0) when I do the same thing with pan.
Under the general tab the pan pwm does not change when i move my aileron stick either. Not sure what is going on but has got to be a software/firmware issue because I have literally tried everything.
edit: Also, I cant control pan at all from my transmitter when going through hoverfly gimbal board.
Adidas4275's Avatar
Joined Mar 2011
great to see that video, ill watch it now. I was gone a little over the last week or so
I know I am getting picky, but any chance we see 1080p version of the onboard, or 720?
it looks okay from what I see, not locked in..... tilt wobbles and such.
I would really love to see what the optimum performance is so i know how close I am to that point.....
Old Aug 07, 2012, 11:49 PM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
The grayed out settings is done deliberately. Auto compensation for pan only works when the mode switch is set to velocity control. Pan auto compensation must not be activated while on the ground. This prevents the auto compensation algorithm from spinning the multirotor on the ground. This is why you are not given the option.
Site Sponsor
Old Aug 07, 2012, 11:54 PM
Private Pilot
Twister773's Avatar
Joined Jul 2009
I think I remember them saying something about them being greyed out deliberately. but that doesnt fix my pan issue. in the receiver config tab the pwm is changing as it should...BUT its switch position stays at 1. thoughts on that?
Old Aug 08, 2012, 12:04 AM
S11D336B is offline
S11D336B's Avatar
Joined Apr 2006
The channel the switch is connected to should be set as the mode switch in receiver configuration. Your radio should have that channel connected to a 3 position switch with it's spa set to 100% on both sides. If you aren't seeing the switch moving in the configurator it's likely that you have something connected incorrectly. If you're still having trouble tomorrow, I'd be happy to spend some time with you on the phone working it out.
George at (hoverflytech dot com)
Site Sponsor
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1792 May 22, 2016 03:04 PM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
