Old Jul 16, 2012, 10:59 PM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
Fill out a support ticket on there website. They are great about responding
Twister773 is offline Find More Posts by Twister773
Old Jul 16, 2012, 11:08 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
support ticket via their website or a phone call is their only official support method, they come here to help but that is not their official support method (thank GOD)
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 17, 2012, 06:38 AM
Al Ducharme
photronix's Avatar
Orlando, FL
Joined Jan 2005
Originally Posted by ThaiskyDigital View Post
Any one know which is the best way to communicate with HF and get them return email.
I did post here about my servo but , was ask to sent PM, i did sent PM but no reply.
In some company i did sent them 1us$ by paypal and attached my message " pls contact me"
may be this will be my best way.
My mistake. I'll get on this and send you what you need.
photronix is offline Find More Posts by photronix
Old Jul 17, 2012, 08:36 AM
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Originally Posted by Adidas4275 View Post
nex-5n
with 16mm pancake (it is too soft, looking into the 19mm sigma)
I would buy the ultra wide convertor for your 16mm and just use it for those really wide shots. The 16mm look better through this convertor. It's crazy. Normally these adaptors are worthless but these things were made to be together.
If you can find it in stock. Read reviews. Great piece for the 16mm pancake. http://www.bhphotovideo.com/c/produc...onversion.html
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 20, 2012, 01:21 PM
Jonny Carroll
jonnydonut's Avatar
United States, TX, Arlington
Joined Jul 2012
Hey guys. I'm new to the forum and new to RC but a veteran in aerial video. Happy to finally join.
I have a f550 Naza with the Sony nex-5n TPpacks mount, and a hoverfly gimbal control. Love it, but there's a jitter.
I've tested multiple options and the jitter appears to be the hoverfly settings. Basically when the servos are unplugged it's smooth, but not stable.. (if that makes sense).
I turned down the acceleration settings on the gimbal and it seemed to help but there is still a lot of tweaking to do. I was hoping someone was willing to share their settings to give me a good starting place.
Thanks.
jonnydonut is offline Find More Posts by jonnydonut
Old Jul 20, 2012, 01:44 PM
Adidas4275's Avatar
Joined Mar 2011
believe it or not i use acclerator settings on tilt and roll that are some where between -10 and 0 crazy I know, but that is where it needs to be for no jitter and fast movement
Old Jul 20, 2012, 01:51 PM
Jonny Carroll
jonnydonut's Avatar
Joined Jul 2012
Thanks Adidas. I actually commented on one of your youtube videos today. wow -10 - 0. Mine is at 300 I think.
Here's a video from earlier today. It looks better on youtube than on my computer, but it gives you an idea.
Old Jul 20, 2012, 01:55 PM
Adidas4275's Avatar
Joined Mar 2011
yeah, i would go down to 0 and see if the jitter goes away.... then work back up
i was around 300 to begin with as well
Old Jul 20, 2012, 01:59 PM
Jonny Carroll
jonnydonut's Avatar
Joined Jul 2012
Thanks. Will do.
Oops. forgot to link to the video in my last post.
Hoverfly gimbal test 2 (2 min 29 sec)
Old Jul 20, 2012, 02:06 PM
Adidas4275's Avatar
Joined Mar 2011
looks like you can fly and film.... you should make short work of this
Old Jul 20, 2012, 04:45 PM
Jonny Carroll
jonnydonut's Avatar
Joined Jul 2012
When I turned the acceleration rate gain down to 0 it seemed like the stabilization hardly did anything, and I still had a little jitter (but less). It jitters a little just sitting on the table.
Anything I can do with scaling factor or etc?
It's raining now so I can't test anymore.
Adidas, are you running the same system as me?
Old Jul 20, 2012, 04:50 PM
Adidas4275's Avatar
Joined Mar 2011
askman's AG550n gimbal and the HFGimbal
here are my settings YMMV
Old Jul 20, 2012, 10:10 PM
S11D336B's Avatar
USA, FL, Winter Springs
Joined Apr 2006
You should start with your acceleration gains at 0. Set the scale factor setting so that the mount compensates with slow motion. Then increase the acceleration gain to speed up your mount a bit.
Most hiccups you see with a stabilized camera mount (small occasional jitters, or loosing stabilization during very fast movement) are a result of limitations imposed by your camera mount and are mechanical in nature. For example, acceleration gain by itself is there for the sole purpose of compensating for the camera mount's inability to keep up with fast movement.
Sometimes you can fix these kinds of things by stiffening your camera mount or using higher voltage to your servos, or using faster servos.
Originally Posted by jonnydonut View Post
Thanks. Will do.
http://www.youtube.com/watch?v=zbazHRIh4Ro
S11D336B is offline Find More Posts by S11D336B
Site Sponsor
Old Jul 21, 2012, 07:50 AM
Jonny Carroll
jonnydonut's Avatar
Joined Jul 2012
I have an esc bringing down voltage to 12v for my downlink.
Will that be too much to send into the hoverflygimbal?
Old Jul 21, 2012, 12:06 PM
Adidas4275's Avatar
Joined Mar 2011
Well the HF gimbal will take
I think up to like 22 volts.
But whatever you put into it it will also send out to the servos and receiver plugged into it.
Most Rx cannot take 12v and most servos cannot either.
I would pick up a BEC that is either variable (castle creations with the link to adjust it) or a non adjustable that is at 6v
The mks servos you have run on 5 or 6v
Can you hook 12v up to your HFG, yes..... Should you, probably not.
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1687 May 15, 2013 01:43 AM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
