Old Jul 14, 2012, 05:44 PM
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
yeah, not sure. I will get my rig out later today and see, i know gary has hooked up a servo to the yaw, and i know the new firmware enabled some more yaw stuff, but i have not had time to mess with it.
email the support and open a ticket (while you are trying to figure it out) and someone will get a hold of you and save you some frustration
I had a tech call me last week about an issue i had, nice to get real service
Adidas4275 is offline Find More Posts by Adidas4275
Old Jul 14, 2012, 10:02 PM
nicnaimless's Avatar
United States, MI, Jenison
Joined Jun 2008
Originally Posted by Twister773 View Post
Ok, I got my board and started setting it up. Two things I have noticed so far. My throttle only works from mid stick and up or visa versa if i reverse the throttle...it works fine when just plugged into the receiver and gimbal servos but once i add the hoverfly gimbal board to the equation it wont move the servos from 0-50% throttle...default transmitter model. Also, I can get it to compensate correctly for roll and tilt but even when set to compensate for yaw it wont...and all of my options are greyed out in servo configuration. All I can do for channel 3 yaw is auto compensate, center point and enable yaw servo...what am i doing wrong. Also, once i get the max throws i want while manually using my radio, how do i keep the hoverfly board from maxing out past those? Thanks!
nicnaimless is offline Find More Posts by nicnaimless
Old Jul 14, 2012, 10:05 PM
Adidas4275's Avatar
Joined Mar 2011
yeah not sure on the throttle setting.
I have not used the throttle channel with mine (just ele and aileron)
Old Jul 14, 2012, 10:37 PM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
how do you get your tilt to stay in one position then autocompensate from there?
Twister773 is offline Find More Posts by Twister773
Old Jul 14, 2012, 10:52 PM
Adidas4275's Avatar
Joined Mar 2011
well for my one man setup (i am using one man 90% of the time) I use a knob on my Dx8 for tilt and it auto compensates from where i set it.
when i have it set to a 2 man setup I was using the right stick for angular deflection or angle velocity (elevator) and rudder for yaw ..... perhaps backwards from what you are using.
since the
Old Jul 15, 2012, 02:10 AM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
I sent in a support request. Thus far it is not user friendly and seems to have some issues when using a transmitter to control the gimbal board. I have noticed also, if I power the gimbal and get it all set so the throttle moves the pitch to the max and min I want...if i unplug the gimbal, and then move the transmitter stick from where it was before, then power back on gimbal it screws up my max and min settings and starts from a new point...Also, I got the 360 pan to autocompensate kind of but it is way to slow to react and no way to adjust it. Also having trouble getting it to even let me control pan at all now for some reason...This thing is frustrating me to no end right now. Bed time and gonna work some more on it tomorrow.
Old Jul 15, 2012, 08:34 PM
Adidas4275's Avatar
Joined Mar 2011
i am sure you'll get it, i know 1.0 was suppose to unlock those grey boxes.... so perhaps something like an update assistant software is needed.
this was shot with the gimbal controller (some clips could be better )
Aerial Highlight Reel Wyoming 2012 (ATV, Horseback, Fly Fishing, Real Estate, Salt & Snake Rivers) (4 min 36 sec)
Old Jul 15, 2012, 11:59 PM
flytahiti's Avatar
Polynésie française, Îles du Vent, Papeete
Joined Mar 2010
still no info or release note about 1.0 it doesn't work for me
flytahiti is offline Find More Posts by flytahiti
Old Jul 16, 2012, 12:34 AM
Joined Sep 2011
http://www.youtube.com/watch?v=cT2PPKQDr0E
Wow, great job! What camera this was shot on?
flashervn is offline Find More Posts by flashervn
Old Jul 16, 2012, 12:42 AM
Adidas4275's Avatar
Joined Mar 2011
nex-5n
with 16mm pancake (it is too soft, looking into the 19mm sigma)
Old Jul 16, 2012, 01:19 AM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
Care to share your settings? No idea where to even begin
Old Jul 16, 2012, 01:34 AM
Adidas4275's Avatar
Joined Mar 2011
yeah, i was using auto focus (which is dumb and i am changing to manual set to infinity)
Shutter Priority @ 1/160 for most stuff shot here.
I am changing to full manual for flying next time around..... i use the iA as light a light meter to get a ballpark and then set it in manual.
Old Jul 16, 2012, 02:01 AM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
I meant gimbal settings
Old Jul 16, 2012, 03:32 AM
Private Pilot
Twister773's Avatar
San Luis Obispo
Joined Jul 2009
I must have missed the last 15 pages of the gimbal manual lol. Just reread and think I will be able to solve most of my issues. EXCEPT for the yaw settings issue, and not sure how I'm supposed to mount gimbal board. Is there a way to lock the pan? Mine seems to be able to move like the servo is not strong enough to keep it in position which shouldn't be the case. Mine is mounted so it moves with pan and roll of gimble but not pitch. Cinestar 360 mount with continuos rotation servos and potentiometers on roll and tilt.
Old Jul 16, 2012, 10:59 PM
Thailand
Joined Apr 2006
Any one know which is the best way to communicate with HF and get them return email.
I did post here about my servo but , was ask to sent PM, i did sent PM but no reply.
In some company i did sent them 1us$ by paypal and attached my message " pls contact me"
may be this will be my best way.
ThaiskyDigital is offline Find More Posts by ThaiskyDigital
Discussion DJI Wookong-M Owners Thread *Pics*Videos*Settings* Z06 Tony Multirotor Talk 1697 Jun 13, 2013 07:45 PM
Discussion HoverflyGIMBAL Demonstration Videos photronix Hoverfly Technologies 10 May 18, 2012 03:53 PM
Link HoverflyGIMBAL Manual and Setup Client hoverben Hoverfly Technologies 1 May 17, 2012 02:25 PM
Discussion HoverflyGIMBAL - Input Voltage? Manual? defxxx Hoverfly Technologies 10 May 17, 2012 01:54 PM
New Product HoverflyGIMBAL - Now Shipping! photronix Multirotor Talk 9 May 15, 2012 12:46 PM
