Old Jul 27, 2012, 08:10 AM
au117 is offline
Find More Posts by au117
Joined Jun 2010
photo 1 glue the bottom fillets on to the wing plate. photo 2 tape the side and bottom fuse up using the tabs. now drop that down on the wing plate the fillets will help hold it straight, only glue at the fillet.
au117 is offline Find More Posts by au117
Old Jul 27, 2012, 01:52 PM
mkcp40 is offline
Find More Posts by mkcp40
mkcp40's Avatar
United States, MD, Potomac
Joined Oct 2010
Do I line up the 2mm fillet with the leading edge?
mkcp40 is offline Find More Posts by mkcp40
Old Jul 27, 2012, 04:07 PM
au117 is offline
Joined Jun 2010
looks good put your spar in and take the top bulkheads off you will need to lay it flat. The do not cut line is the fillet line look at pic 1
Old Jul 27, 2012, 04:57 PM
mkcp40 is offline
mkcp40's Avatar
Joined Oct 2010
Spar? Is that the black line running between the two wing pieces? I have some CF rod if that is what is needed.
Old Jul 27, 2012, 07:16 PM
au117 is offline
Joined Jun 2010
Yes it is. have you built esprits f-22? the f-35 is based off that type of construction. If you have not, I would highly recommend looking at it. If this is your first 10 in micro jet build i would recommend doing it first its a awesome plane, and after looking at his instructions things should make more sense.
Old Jul 28, 2012, 03:10 PM
pattypilot is offline
Find More Posts by pattypilot
No dear, That isn't New!
pattypilot's Avatar
United States, IL, Urbana
Joined Nov 2006
mkcp40 I used a .052 CF rod. It's just about a perfect fit.
pattypilot is offline Find More Posts by pattypilot
Old Jul 30, 2012, 07:01 PM
pattypilot's Avatar
Joined Nov 2006
I know, if everyone was as slow at building as I am, we would never get to fly it! I have made some progress. Albeit small gains.
Jim
Old Aug 02, 2012, 10:40 AM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Hey guys,
I couldn't believe it but au117 gave me the sticks yesterday to his F-35c model. I was so impressed with its small field flying qualities. It ultimately looks like a high performance jet but it flies like a gentle park flyer. With that lifting fuselage it can make tight turns and without any tendency to fall or drop a wing. On 3s most of the flight was at 70% throttle. It was a bit surreal flying this f-35 design in a small park surrounded by trees. Micro edf's have come a long way in the last few years! This model not only looks good but it's light weight and high power makes it so easy to fly. I really like the direction Au117 has gone with this project and his construction and attention to weight reduction is really influencing me on future micro EDF projects! Thanks again for the stick time Au117!
pdawg is online now Find More Posts by pdawg
Old Aug 02, 2012, 10:52 PM
Kevin Greene is online now
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
Originally Posted by pdawg View Post
Hey guys,
So---For high alpha with a tight flying area you would recommend the C model???...Perhaps for a larger flying area the A model would be better???
I'm planning on using the GP fan/motor on 3S...I like the high alpha flying but want to zip around as well...In the video in the hangar---Is that a C model or A model???
Kevin
Kevin Greene is online now Find More Posts by Kevin Greene
Old Aug 02, 2012, 11:13 PM
pdawg is online now
Need 4 Speed!
pdawg's Avatar
Joined Apr 2004
Hi Kevin,
Those are good questions for Au117 to answer. My flight did not get close to pushing the airframe. This Saturday though the guys are going to do some indoor flying and I'm sure au117 will be doing some high alpha flying. I personally have never flown indoors before....should be an experience one way or another. Anyone wanna place bets whether my little F-86 smacks a wall?
Old Aug 03, 2012, 08:52 AM
pattypilot's Avatar
Joined Nov 2006
You’ll do fine, looking forward to Saturday morning! Should be fun. See you then.
Jim
Old Aug 03, 2012, 09:38 AM
Joined Mar 2007
Au117---Can you sell the intake bell mouth???...To make it worth your while I'll order 5 now...
Kevin
Old Aug 03, 2012, 09:47 AM
au117 is offline
Joined Jun 2010
Kevin the high alpha video is the f-22. The f-35 will do maybe 20 degrees, watch the first video that's the A model inside. The c should do a little better., weight is the key to going slow. With the gp 30 on 3s be very careful, only short bursts, you can and will burn it up. I only do 2 high speed passes and then go to 50% for a pass to cool down, most of the flight is at 60 to 70 %.
I had a good time pdawg looking forward to sat. you will do fine. the trees take some getting used to as a background. The walls are the same, Just closer
Old Aug 03, 2012, 11:59 AM
Joined Mar 2007
Thanks for the clarification!!!.......I downloaded both sets of wings......Looking forward to the posting of the decal sheet(s) for the grey camo planes...And about the intake bellmouth---Are you able to make any to sell???......
Kevin
Old Aug 03, 2012, 02:51 PM
au117 is offline
Joined Jun 2010
Kevin let me see what i can do. i only had 3 made.I will have to get some more made, Jim b will need 1 to. So we will work something out.
I received a prototype25 mm fan using gp's motor to test in the F-35 on 3s. I hope to fly it this weakened.
Sold Haier HLT10 10-Inch Handheld TV SugarLandFlyer FPV Equipment (FS/W) 12 Apr 27, 2013 06:06 PM
Sold Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 MicroESC $20 w/Free Shipping C Plasmajoe Aircraft - General - Radio Equipment (FS/W) 6 Jan 15, 2012 07:51 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2012 12:26 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2012 12:23 AM
For Sale 7 inch LCD TV w/ inputs for FPV GuyPilot FPV Equipment (FS/W) 28 Dec 25, 2011 05:56 PM
