Old Jan 15, 2013, 08:01 PM
mikeramos is offline
Find More Posts by mikeramos
Philippines, NCR, Manila
Joined Oct 2007
Thanks AU, will start building this weekend
mikeramos is offline Find More Posts by mikeramos
Old Jan 16, 2013, 08:01 AM
Bill Quantock is offline
Find More Posts by Bill Quantock
Wingnutz
Bill Quantock's Avatar
Canada, ON, Markham
Joined May 2009
Settings question
Originally Posted by au117 View Post
Pitch 3/8 up and down, 20 expo
Roll 3/8, for C model 20 to 25% more down then up. 5 to 10% for the A model. 20 expo
Yaw about 1/8 I use a high exp. 40
The differential in roll should be close. Cleans the roll up a lot.
au,
Intrigued by the suggested settings above, particularly "20 to 25% more down then up" in the roll settings.
1. Is this "aileron differential" on a conventional wing layout?
2. I usually try to program more up than down to eliminate adverse yaw. Have I missed the point?
3. I'm using a Spektrum tx which requires selecting elevon wing type to get the desired control surface response. Will differential still work with elevon wing type selected?
Bill Quantock is offline Find More Posts by Bill Quantock
Old Jan 16, 2013, 11:09 AM
au117 is offline
Find More Posts by au117
Joined Jun 2010
Bill
The nose is wanting to be lifted in the roll, Due to the roll control being at the tail of the aircraft. The effect is that the roll turns into a corkscrew. The larger wings on the C model grab more air creating a larger corkscrew. By increasing the down defection in the roll, this will tuck the nose causing a more a axial roll.
au117 is offline Find More Posts by au117
Old Jan 17, 2013, 02:26 PM
T-spin is online now
Find More Posts by T-spin
Joined Mar 2005
Here's a couple of pictures showing a push rod on the thrust vectoring.
Tony
T-spin is online now Find More Posts by T-spin
Old Jan 17, 2013, 04:27 PM
au117 is offline
Joined Jun 2010
looks good T-spin
Old Jan 17, 2013, 11:28 PM
Wingnutz
Canada, ON, Markham
Joined May 2009
Bill
Thanks au. Like your pushrod t-spin.
Old Jan 18, 2013, 08:39 AM
Joined Oct 2007
Great build!
Just question sorry..How do you mix the TV servo? Do you mix it with ailerons?
Old Jan 18, 2013, 08:57 AM
au117 is offline
Joined Jun 2010
Put it on the rudder or yaw. I have not mixed it with roll.
Old Jan 18, 2013, 02:59 PM
Joined Mar 2005
au117,
Do you fine them to be nose heavy? Did you add any weight to get the proper c/g ?
Tony
Old Jan 18, 2013, 03:59 PM
au117 is offline
Joined Jun 2010
You have got to cut a hole and slide the batt. into the splitter look at pic #28
Old Jan 18, 2013, 04:26 PM
Wingnutz
Canada, ON, Markham
Joined May 2009
Hyperflow 30mm question
I've pushed the fan as far onto the motor shaft as it seems to want to go, but the fan blades are just starting to enter the stator ring. Any hints on how far to push to seat the fan appreciated.
Old Jan 18, 2013, 04:32 PM
au117 is offline
Joined Jun 2010
Bill look at pic #8
Old Jan 20, 2013, 06:57 PM
Jack Brewer is offline
Find More Posts by Jack Brewer
United States, IN, Lafayette
Joined Dec 2003
My first F-35
Hear is my first F-35 with a new nose after test flight. I have a second one under const. with a few changes. First one nose heavy but flew until to much vectored thrust was used, and rolled it over an in. I made the cutout for moving the battery back.
Jack
Jack Brewer is offline Find More Posts by Jack Brewer
Old Jan 23, 2013, 08:38 AM
feco is offline
Find More Posts by feco
Joined Aug 2011
I can be building F-35A 30mm-s with EdF help
EDF 30 (0 min 47 sec)
: Confused:
feco is offline Find More Posts by feco
Old Jan 23, 2013, 04:45 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
feco - I don't know what to say....
NitroCharged is offline Find More Posts by NitroCharged
Sold Haier HLT10 10-Inch Handheld TV SugarLandFlyer FPV Equipment (FS/W) 12 Apr 27, 2013 06:06 PM
Sold Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 MicroESC $20 w/Free Shipping C Plasmajoe Aircraft - General - Radio Equipment (FS/W) 6 Jan 15, 2012 07:51 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2012 12:26 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2012 12:23 AM
For Sale 7 inch LCD TV w/ inputs for FPV GuyPilot FPV Equipment (FS/W) 28 Dec 25, 2011 05:56 PM
