Old Dec 10, 2012, 08:39 AM
seanm135 is offline
Find More Posts by seanm135
Joined Dec 2011
Originally Posted by au117 View Post
Sorry i did not check this over the weekend. I make the yaw cone out of a 1\64 ply ring and the paper cone in the drawings. I use fishing line and pull pull.I paint the paper cone with lacquer paint and then it is water prof. The paper cone, ply ring fishing line and paint weigh about .05 grams. I will post markings for the air force and navy this weak. hope this helps Sean
Thanks, that helps a lot! What do you use as pivot points on the vertical axis for the cone?
seanm135 is offline Find More Posts by seanm135
Old Dec 10, 2012, 10:05 AM
au117 is offline
Find More Posts by au117
Joined Jun 2010
carbon rod. look at pic #19 shows fishing line tied to ply ring. carbon rod is glued to the ply tabs that are glued to the inner stationary cone. the ring has the hole. the tabs have the carbon.
au117 is offline Find More Posts by au117
Old Dec 10, 2012, 10:57 AM
seanm135 is offline
Joined Dec 2011
thanks au.... thats what i figured but wanted to check. great set of plans by the way, I can't wait to finish mine
Old Dec 10, 2012, 11:45 AM
au117 is offline
Joined Jun 2010
Thanks Seanm. I started a 150% A model, 15 in span, giant scale it does seam big after doing the 10in. The 150% airframe weight is 32 grams. I think we can do it at 100 grams + batt. under 150. auw.
pdawg is working on some 200 gram thrust 40mm fans. This is going to be fun. Will post some pics soon.
Old Dec 10, 2012, 01:14 PM
chester2240 is offline
Find More Posts by chester2240
chester2240's Avatar
United States, CO, Westminster
Joined Jul 2011
So is it gonna be a 40mm edf?
chester2240 is offline Find More Posts by chester2240
Old Dec 10, 2012, 02:16 PM
au117 is offline
Joined Jun 2010
yes 40 mm fan 150% 15in ws 360 tv
Old Dec 10, 2012, 02:49 PM
Joined Jul 2011
Nice!
same size as Esprit440 F-22 i wonder how the handling will be in comparison
Old Dec 10, 2012, 04:05 PM
Bill Quantock is offline
Find More Posts by Bill Quantock
Wingnutz
Bill Quantock's Avatar
Canada, ON, Markham
Joined May 2009
Wow! looks huge!
"Au, your "giant" F-35 really looks huge sitting beside the blue one!
360 TV??? C"an you fill us in a bit?
I'm ready to build my second one and would really love to build one that can slow down enough to fly indoors in a triple gym.My present one (27mm fan) can just manage enough speed to climb slowly and at that speed is still way more than I could handle indoors....SO I'd appreciate you thoughts on; keeping the small platform electronics, Hyperflow 30mm fan and motor, increasing the 13.5"C ws by 5-10% and creating a partially undercambered wing by inclining the leading and trailing edge.
Looking forward to the C graphics! Thanks for sharing! Your thread has been a wonderful resource!
Bill Quantock is offline Find More Posts by Bill Quantock
Old Dec 10, 2012, 05:14 PM
Joined Jul 2011
Id like to build a pusher version of it also im getting tierd of my F-22
Old Dec 11, 2012, 12:30 PM
au117 is offline
Joined Jun 2010
This is the 360 gimbal. It will have pull pull on the inner ring for yaw and the outer ring is for pitch. I'm not sure how to answer your questions Bill. Flying slow is a matter of wing loading. The F-35 will fly pretty slow, but it is in high alpha, at 15 to 20 degrees. It will become unstable at angles of attack higher than that. You will find that you lose control because the tailarons do not have enough authority, even with large movements, that is when the yaw cone comes into play. The wing will couple roll with yaw inputs. If this doesn't make sense let me know and I will try to explain it further.
The changes you're thinking of making to the wing will help it fly slower but at speed it will not fly right. I think it could be bad. Hope this helps.
chester your F-22 is bad a$$. I love e spirits F-22.
Bill have you done a F-22? It's much better at high alpha.
Old Dec 12, 2012, 07:06 AM
Wingnutz
Canada, ON, Markham
Joined May 2009
More thanks and more questions...
Thanks for the suggestions and info on the 360TV...impressive!
I have Matt Wherry's plans for a 15" F-22. Is this one you'd recommend for indoors?
Old Dec 12, 2012, 08:13 AM
au117 is offline
Joined Jun 2010
page 5 post 64 10in f-22 high alpha. this is a good example of flying on the yaw cone. The F-35 will not do high alpha like that but will go about 20 degrees. As for flying slow and on step they are about the same.
Old Dec 12, 2012, 08:34 AM
Joined Jul 2011
I dont know Espirits440 real name but heres the link to the F22 plans http://www.rcgroups.com/forums/showthread.php?t=782213
Old Dec 14, 2012, 04:05 PM
au117 is offline
Joined Jun 2010
40mm 360 tv
Old Dec 15, 2012, 10:35 AM
seanm135 is offline
Joined Dec 2011
Au117, can you post the 150% scaled plans? I have all the electronics for a 40mm fan setup that I'd like to use in the A variant if your design... It will be a great complement to the 30mm C I'm doing right now
Sold Haier HLT10 10-Inch Handheld TV SugarLandFlyer FPV Equipment (FS/W) 12 Apr 27, 2013 06:06 PM
Sold Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 MicroESC $20 w/Free Shipping C Plasmajoe Aircraft - General - Radio Equipment (FS/W) 6 Jan 15, 2012 07:51 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2012 12:26 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2012 12:23 AM
For Sale 7 inch LCD TV w/ inputs for FPV GuyPilot FPV Equipment (FS/W) 28 Dec 25, 2011 05:56 PM
