Old Nov 13, 2012, 08:04 AM
au117 is offline
Find More Posts by au117
Joined Jun 2010
Bill looks good, clean build. keep us updated.
au117 is offline Find More Posts by au117
Old Nov 16, 2012, 11:52 PM
MustangAce17 is offline
Find More Posts by MustangAce17
3d and EDF, some scale
MustangAce17's Avatar
United States, FL, Ocala
Joined Sep 2005
T/A 38 COD: Black Ops 2 F-35 delta adaptation
couldn't resist trying this one, pics to come
it's hard to tell exactly what the concept looks like but here's my version
MustangAce17 is offline Find More Posts by MustangAce17
Last edited by MustangAce17; Nov 17, 2012 at 12:01 AM. Reason: added converted drawing
Old Nov 17, 2012, 01:01 AM
minimicrorc is offline
Find More Posts by minimicrorc
Joined Apr 2012
r u gonna post plans?
Really looking forward to this : eek:
minimicrorc is offline Find More Posts by minimicrorc
Old Nov 24, 2012, 11:24 PM
HeliFax is offline
Find More Posts by HeliFax
Inverted Airfield
Iowa
Joined Nov 2009
What type of foam safe glue are you using on this jet?
HeliFax is offline Find More Posts by HeliFax
Old Nov 24, 2012, 11:29 PM
Joined Sep 2005
Mini, plans will just be a conversion off the bird posted here, still trying to work out the back end details( twin exhaust)
Heli, i use Bob Smith Super Gold medium/ gap filling with ZAP foam safe accelerator,awesome stuff
Old Nov 25, 2012, 11:59 AM
Bill Quantock is offline
Find More Posts by Bill Quantock
Wingnutz
Bill Quantock's Avatar
Canada, ON, Markham
Joined May 2009
Maidened!
Sorry about the tardy reply...unseasonably warm, calm week here and lots of flying...including four outdoor flights for my micro F-35C!
Went pretty well but the little 27mm edf unit has to work pretty hard to keep the model from losing altitude...throttle >2/3 or the model starts to lose altitude. Kept it right side up as I wasn't sure about recovery with marginal power and not too much altitude. Outdoor only as I think it's too fast for the indoor site (triple gymnasium filled with other flyers) Sorry, no pics in the air as I flew by myself and haven't mastered helmet camming something this small. Have bought a Hyperflow 30mm fan and Ammo motor for the next one to see if that addresses the thrust concern.
It was fun! Thanks to all who contributed to the thread,especailly au117!
Bill Quantock is offline Find More Posts by Bill Quantock
Old Nov 26, 2012, 08:16 AM
au117 is offline
Joined Jun 2010
Nice job Bill looks good. You will like the GP 30mm fan. Did you do the thrust vectoring cone? If you did, you will be able to fly a lot slower. Once you get used to lifting the nose 15 degrees and flying off the left stick. Glad to see success.
Old Nov 26, 2012, 08:57 PM
Wingnutz
Canada, ON, Markham
Joined May 2009
Waiting for the wind to stop
Yes. the thrust cone is driven by a servo and a pull-pull thread arrangement. Cut out and mounted the canopy trim...looks better!
Old Nov 26, 2012, 09:29 PM
pdawg is online now
Find More Posts by pdawg
Need 4 Speed!
pdawg's Avatar
United States, OH, Dayton
Joined Apr 2004
Very nice Job Bill!
pdawg is online now Find More Posts by pdawg
Old Nov 27, 2012, 06:38 PM
mkcp40 is offline
Find More Posts by mkcp40
mkcp40's Avatar
United States, MD, Potomac
Joined Oct 2010
That's a very nice job you've done on it- you'll enjoy the C model a lot. I had some fun over Thanksgiving dogfighting with around a dozen crows at once
mkcp40 is offline Find More Posts by mkcp40
Old Dec 08, 2012, 07:00 PM
mkcp40 is offline
mkcp40's Avatar
Joined Oct 2010
au117- would you be willing to post decal sheets for the A and C variants?
Old Dec 09, 2012, 01:15 PM
seanm135 is offline
Find More Posts by seanm135
Joined Dec 2011
I'm starting to build one of these and have a couple of questions... What do you guys use to connect the servo to the thrust cone? The same music wire used for the elevons? And how/where is it connected to the cone itself?
seanm135 is offline Find More Posts by seanm135
Old Dec 09, 2012, 04:14 PM
mkcp40 is offline
mkcp40's Avatar
Joined Oct 2010
http://static.rcgroups.net/forums/at...2-f35%2019.jpg
I think it is a pull-pull system with string from this picture. I'd also be interested in the answer to the third question.
Over Winter Break I will be building this particular aircraft:
http://www.key.aero/central/images/news/1346.jpg
Unfortunately, no VTOL!
Old Dec 09, 2012, 11:03 PM
Wingnutz
Canada, ON, Markham
Joined May 2009
Pull pull thrust cone...carbon pushrods
seanm135 and mkcp40'
My micro F-35C has six flights without a scratch and uses cotton (I think) thread to connect the thrust cone to the servo. The thread is tied and CAed to a plastic ring (cut from the top of a pill bottle with my scroll saw) CAed to the paper cone. The plastic ring was drilled with #60 drill in four spots...two for the thread anchor points and two for the pivot points. Straight pins were cut to length as pivot pins and were CAed into the shroud of the EDF reinforced with small pieces of 1/32 balsa. You can see the plastic ring and the head of the top pin in the accompanying photo.
I may try to make the thrust cone out of something other than paper on the next model as the paper doesn't hold its shape well if it gets damp landing in damp grass.
I used 0.8mm carbon rod for the taileron/elevon pushrods and connected the pushrods to the control horns (1/64 or 1/32 ply...I can't remember) with shrink wrap.
Old Dec 10, 2012, 08:08 AM
au117 is offline
Joined Jun 2010
Sorry i did not check this over the weekend. I make the yaw cone out of a 1\64 ply ring and the paper cone in the drawings. I use fishing line and pull pull.I paint the paper cone with lacquer paint and then it is water prof. The paper cone, ply ring, fishing line and paint weigh about .05 grams. mkcp I will post markings for the air force and navy this weak. hope this helps Sean
Sold Haier HLT10 10-Inch Handheld TV SugarLandFlyer FPV Equipment (FS/W) 12 Apr 27, 2013 06:06 PM
Sold Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 MicroESC $20 w/Free Shipping C Plasmajoe Aircraft - General - Radio Equipment (FS/W) 6 Jan 15, 2012 07:51 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 0 Jan 13, 2012 12:26 AM
Sold PRICE REDUCTION Hi-Tec Feather Rx w/ 3 HS-55 Servo's & ElectriFly C-10 Micro ESC Plasmajoe Aircraft - General - Radio Equipment (FS/W) 1 Jan 13, 2012 12:23 AM
For Sale 7 inch LCD TV w/ inputs for FPV GuyPilot FPV Equipment (FS/W) 28 Dec 25, 2011 05:56 PM
