Old May 21, 2012, 01:25 PM
MassiveOverkill is online now
Find More Posts by MassiveOverkill
MassiveOverkill's Avatar
United States, SD, Custer
Joined Feb 2011
Double Horse 7009 15"
Well, I wanted to get another boat since the cheapie Sundance Racer my GF got me corroded out.
I haven't seen any reviews for this, so I guess I'll be doing one (looks like it was just released).
Here are some close-ups
http://www.ujtoys.com/Double-Horse-7...-p/dh-7009.htm
and I ordered it from here:
http://www.amazon.com/7009-Double-Ho.../dp/B007RZ4OEO
Videos show sit moving pretty fast for a single 380-powered motor, but it's a small boat. Has proportional control and air cooling (have to see if it does anything when I get it).
Here's a youtube of it in action:
7009 boat (1 min 10 sec)
Hopefully it's worth the 50 bucks. If I like it I'll order more batteries for it.
I welcome any comments.
MassiveOverkill is online now Find More Posts by MassiveOverkill
Site Sponsor
Old May 21, 2012, 03:07 PM
Joined Feb 2011
Wow 55 views and not one comment
Site Sponsor
Old May 22, 2012, 05:18 PM
Joined Feb 2011
It's funny, some subforums are active, others are dead at RC Groups.
Site Sponsor
Old May 22, 2012, 09:48 PM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
Its a stock brushed boat if you hop it up some may be interested. = )
Amp Abuser is online now Find More Posts by Amp Abuser
Old May 23, 2012, 09:50 AM
Joined Feb 2011
Hey a comment!?! Well here's the thing: Is there anything better that can be purchased for 50 bucks? Will such a small boat be able to handle more power?
Site Sponsor
Old May 23, 2012, 02:43 PM
Amp Abuser's Avatar
Joined Dec 2007
Yes should be able to go up to about 130 watts on a 15in boat. your around 10amps my guess right now. 10a x 7v for 70w rough guess. The new smaller mono's have done well out the box on a 380/400 size brushed motors, great way to start for cheap. I would start off with a brushless boat and esc if at all possible.
Old May 24, 2012, 09:07 PM
Joined Feb 2011
Thanks. I got her in today and partially charged the battery to do a test run. This thing is pretty quick, just like the video. Gets up on plane fairly fast. I wish she were 2.4 Ghz for better range\interference, but I can't complain for 50 bucks. I have a Prophet Sport II charger that I've adapted to charge the battery faster\better than the stock one, which doesn't have automatic cut-off. I'll try and get my own video done this weekend.
I'm already wanting more range from this thing, so a 2.4 Ghz setup is my next upgrade\boat. Other than that it's great.
Site Sponsor
Old May 25, 2012, 06:20 PM
Joined Feb 2011
Rough water conditions:
Double Horse 7009 Micro Boat in Rough Water (2 min 15 sec)
Not glassy but better:
Double Horse 7009 Micro Boat in Smoother Water (1 min 55 sec)
I've added a shroud to the cooling fan:
and I'll add a motor heat sink later. I know, I should just retrofit water cooling. I've also put weaker springs in the remote as the stock ones were pretty stiff, making the controls hard to use with precision.
Pics:
Site Sponsor
Old May 27, 2012, 10:18 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
380(Speed-400 size)boats can be quite lively, built quite a few before Lipo&brushless became common and had a blast. Most converted well to 20mm brushless and Lipo really improved the speed a lot. Today its actually easier and cheaper to go brushless, my last good brushed speed-480/BB was almost $ 50 at the LHS. When it melted its brush holder it was replaced by a $15 KDA 20mm for an amazing jump in performance!
coriolan is online now Find More Posts by coriolan
Old May 27, 2012, 11:56 AM
Joined Feb 2011
My micro heli uses lipos, and I'm actually OK with brushed and NiMH for now as there's not as much maintenence\danger as you have with lips, but I'm sure I'll make the switch eventually. Right now I have chargers for NiMH, so the lipo charger would have to factor into my purchases (micro lipo charger isn't suitable for larger batteries).
I'm looking at the Warrior 2 or the Mini Mono next.
Site Sponsor
Old May 27, 2012, 04:02 PM
Amp Abuser's Avatar
Joined Dec 2007
lighter higher kv and watt brushless motor/esc and metal prop upgrade should boost the speed 25% if not the lipo's change
Old May 27, 2012, 04:19 PM
coriolan's Avatar
Canada
Joined Sep 2006
My best results with brushed Speed-400/Speed-480 were with Octura X431 plastic or X430 bronze props. When I moved to brushless(4800 Kv)with 2 cells Lipo X430 was best for surface drive monos and X427 for 3 cells Hydroplane.
Boats in that size are really fun and less troubles to run than bigger boats, they can also be used in smaller pond. For brushed motors I was using a cheap GWS esc and 7-cells 1000mA Nimh, when I moved to Lipo&brushless I used 1800 or 2200 mA(2/3 cells)and CS Thunderbird-36 esc(Blew a few of the infamous
TowerPro W30A Brushless Speed Controller)
http://www.hobbyking.com/hobbyking/s...ontroller.html
Old May 27, 2012, 06:57 PM
Joined Feb 2011
I'm actually fine with the speed of this, knowing that a lipo-brushless could go much faster. I flipped her today with the winds of TS Beryl, but luckily she blew to shore. Only thing I'm really wishing for right now is more range. I appreciate the suggestions though.
Site Sponsor
Old May 28, 2012, 02:11 AM
Sailboat Mike is offline
Find More Posts by Sailboat Mike
Australia, VIC, Cranbourne North
Joined Apr 2012
These cheapos can be so much fun, I bought a 450mm long Exceed Z for $49,00, that has twin 380 motors and goes really well, sure the hull is plastic and the quality isnt sensational but it runs well and it does 25Kph or so the blurb on the box says, battery is a Mhi 7.2 Volt 1800Mha which only gives around 6 or 7 minutes toa charge, so a new battery is high on the agenda, but for $49 bucks , if it dies who cares, i can strip the bits out and use them for other projects.
Enjoy, and dont worry about the snobs on here that dont give you the time of day unless you are willing so spend thousands of dollars, its all just for fun, seems there fun is more in being nasty to people who are starting out in the hobby, rather than helping and encouraging
Cheers Mike
PS Just bought a sea plane of Ebay $50 second hand (unwanted gift so still new) - BONUS
Sailboat Mike is offline Find More Posts by Sailboat Mike
Old May 28, 2012, 03:07 AM
Aaron qin is offline
Find More Posts by Aaron qin
Aaron qin's Avatar
China, Guangdong
Joined Oct 2011
WOW,so fast!can not wait to get one
Aaron qin is offline Find More Posts by Aaron qin
Site Sponsor
Sold Like new doubl brushless CB100 45 fly bar program screen remote w extras 100 shipped! blueindian Aircraft - Electric - Helis (FS/W) 2 Aug 29, 2010 10:29 AM
Question Question about HORS... Has anyone used one of the 1/9 scale Revell models? Akura2 Motorcycles 41 Oct 03, 2006 06:41 PM
Help! Old to TT's, New to HORS, What is best first mods to this bike? Links to old threads? BACKEMFNRG Motorcycles 14 Jun 15, 2006 07:45 PM
Discussion Butters/Hoverboy-Kyosho HORs Butters Motorcycles 4 Jan 21, 2006 06:57 PM
FOR SALE: NF SF501, 2 X HORs brushless, 3CH FM radio hercdriver7777 Motorcycles 4 Jul 30, 2005 03:21 AM
