Old Sep 22, 2012, 06:23 AM
renatoa is offline
Find More Posts by renatoa
Romania, Dolj, Craiova
Joined Sep 2007
Already posted, new thread in one of the multirotor forums, here:
http://www.rcgroups.com/forums/showthread.php?t=1733937
Sounds very good for the price !
renatoa is offline Find More Posts by renatoa
Old Sep 22, 2012, 06:32 AM
Ramnes is offline
Find More Posts by Ramnes
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
Best place to put ESC,s etc
Hi
Can you please put out some picts of how/where you placed the electric equipment on the Mini650 frame V1/V2?
I have the Plush 40A ESC's and with the camera gimbal on, i dont know where to put them.
I'm thinking of making a power distribution board/cable etc. have someone made one og tried out something that fits on this frame?
Jorn
Ramnes is offline Find More Posts by Ramnes
Old Sep 23, 2012, 01:27 AM
FAST is offline
Find More Posts by FAST
Brasil
Joined Mar 2004
Originally Posted by FAST View Post
BEWARE when you try to pay to buychina.
It redirects to a suspicious page with a bigger value.
My order is U$65.00 !!!!!!!!!
HEY BUYCHINA.
WHY DON'T YOU ANSWER MY E-MAILS????????
Send me a paypal link to pay my order.
FAST is offline Find More Posts by FAST
Old Sep 23, 2012, 03:15 AM
renatoa is offline
Joined Sep 2007
Yesterday I had another maiden attempt, went fine until a bit harder landing than usual, but don't imagine crash !
When walked to pickup the frame, was shocked to find two broken arms ! Not sure if was a landing in one of the arms, and I doubt, because the two broken arms are opposite, not neighbor, as supposed to find them broken if an arm landing !
As you can see from the pictures, the arms are cut surgically exactly at frame exit clips level, and you can see also the reason, the extremely thin carbon tube thickness, we label here such cases as "peel of onion" I measured and it is 0.43mm !!!
Now it's clear the reason of arms replacement, the initial design of this frame wasn't able to sustain even his own weight !!! I would add that the landing place was knee high grass !
I am balancing now between switching to Alu tubes, or ordering more serious 1mm wall thick carbon tubes, these:
http://www.hobbyking.com/hobbyking/s...mm_2_pcs_.html
Old Sep 23, 2012, 03:23 AM
renatoa is offline
Joined Sep 2007
Originally Posted by Ramnes View Post
Hi
Jorn
See here my ESC placement.
Unwrapped them, paired two to share the same Alu heatsink, because in tests they were very cold.
Re-wrapped the two ESCs having an opposite direction of motor wires, so they are very close to arm exit hole, where motor wires should be routed.
This way they fit perfectly between the two central plates.
The two ESC pairs are connected together with an AWG14 cable mounted with zip ties on top of upper plate, having a battery plug in the middle.
Old Sep 23, 2012, 03:28 AM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
Nice! lets see the upgrade kit they are sending. will it be with the same tubes?
tigar is offline Find More Posts by tigar
Old Sep 23, 2012, 04:30 AM
AliB is online now
Find More Posts by AliB
kitesurfer
United Kingdom, England, Hayling Island
Joined Dec 2005
The alu arms are strong. But they bend in crashes and not break. But the frame is quite flexy. Significant flex just before takeoff. See if v2 is better because I have one in the post
AliB is online now Find More Posts by AliB
Old Sep 23, 2012, 06:50 AM
rwijnhov is online now
Find More Posts by rwijnhov
Netherlands
Joined Feb 2009
Ok what do I need more to finish this? What gyros (how many). What servo's?
rwijnhov is online now Find More Posts by rwijnhov
Old Sep 23, 2012, 07:12 AM
Netherlands
Joined Feb 2009
Oh and i have some ipower 2814 motors will they fit? they are the same size as all the other 2814 motors.
Old Sep 23, 2012, 07:17 AM
renatoa is offline
Joined Sep 2007
Will fit, but too powerful, will carry at least 100 grams in motors steel and copper without any benefit.
Those are motors for 3kg ++ auw.
Old Sep 23, 2012, 07:28 AM
Netherlands
Joined Feb 2009
I know but I have them lying and love them because they are verry smooth. So if they fit i will order me the frame
Old Sep 23, 2012, 01:22 PM
Jodde73 is offline
Find More Posts by Jodde73
Jodde73's Avatar
Stockholm
Joined Sep 2009
This came up the other day, is it the "v2" version?
http://www.goodluckbuy.com/mini650-m...ount-ptz-.html
Jodde73 is offline Find More Posts by Jodde73
Old Sep 23, 2012, 02:45 PM
Ramnes is offline
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
Jodde73
I dont think it is V2. The picts are not very good. V2 comes in a small box without the bag(mine did).
Take a look at the picts i uploaded earlier of the V2 frame.
About the bag for the V2 frame. I hope they'le put it out for sale on buychina with the possibillity to pay through Paypal. I was told it was $10, but i wasnt able to buy it maybe since i had no plans buying anything else at the moment.
Jorn
Old Sep 23, 2012, 02:49 PM
Ramnes is offline
Still flying
Ramnes's Avatar
Oslo, Norway
Joined Feb 2009
RENATOA
I like that solution for the ESC's! I just have to drill holes in the plastic so the wires can run inside the steel tube. Thanks!
Jorn
Old Sep 24, 2012, 04:29 AM
katipo is offline
Find More Posts by katipo
New Zealand, Auckland
Joined Apr 2004
Hello All.
I'm just setting up my V2 Steadicam Mini 650 now, and I'm wondering what battery sizes I should run and where on the frame they should go.
So to all those that have theirs flying. What is your main flight battery set up and what kind of duration and AUW have you got?
I was thinking I could run a 5000mha as the counterweight pack and two 2500mha packs on the sides of the frame. Would this be to heavy or would a 4200mha and 2x 2100mha be ok or still to much? What do you think? what should the total flight pack capacity be?
Cheers,
Michael
katipo is offline Find More Posts by katipo
New Product NEW Carbon-Glass-Alu SCORPIO Mini HEXA Frame (WITH PLANS) mifau Multirotor Talk 49 Mar 05, 2013 01:40 PM
Sold RC Carbon Y-6 Carbon Fiber Folding Frame Adidas4275 Aircraft - Electric - Multirotor (FS/W) 2 Apr 22, 2012 10:44 PM
For Sale Hexa Glass Fiber Frame for DIYer (without power unit) kevinlib Aircraft - Electric - Multirotor (FS/W) 11 Apr 14, 2012 10:48 AM
Discussion carbon fiber frame vs fiber glass frame? ChatXT Multirotor Talk 1 Feb 09, 2012 02:38 AM
For Sale TRex 450 Frame Carbon Fiber CNC full frameset MJW2006 Aircraft - Electric - Helis (FS/W) 2 Sep 25, 2007 05:12 PM
