For ekstra long receiver antenna cable maybe? i dont know. There are some tiny holes all over the frame which they fits, but most certainly shouldnt be placed. I'm not shure if everyone gets six legs for the version II, but i received an extra pair. The hole frame seems very steady and firm in it's construction. To pitty i'm not gonna put any electronics on it yet. I've just built a DJI550 with landing legs from Jacub and now i need to save some money for a while. Jorn |
Romania, Dolj, Craiova
Joined Sep 2007
You will see soon why you need extra legs.. a lot, not only two
![]() I broken two instantly this Sunday when trying to maiden on a 20kmph wind. This legs aren't good for anything else than a perfectly vertical nice landing, I wouldn't even trust to put my Nex on them, already looking for a replacement. |
Latest blog entry: JRSky - birth of a dream radio
Ok. I'll see if i can figure out something, but first i need motors for the bird, i thought i'll buy the same as for my HK550, http://www.hobbyking.com/hobbyking/s...dProduct=16230 But then i need to drill holes through the aluminium arm for the shaft. This motor shall have a tourque of 1,1 - 1,6kg. What motors do you recommend? I'm going to use a Panasonic HDR-CX570E Videocamera for filming. I thought of ESC, Plush 40A as i use in the HK550 I think i read somewhere in here that someone use a gyro to stabilize the gimbal. I 'm not shure what FC i'm gonna use. In the HK550 i use the KK2. At the end i'll buy the YS-X6 for one of them. Jorn |
Joined Sep 2007
Personally I had bad experience with NTM motors, and since then I avoid them.
The one pointed above is way too powerful for such task. Check their own diagram, the optimal efficiency, (which is lame at 70%...) is at 1.1 kg thrust and 16A consumption. Do you see this machine as quad at 4.4kg and drawing 64Amps ?! Come-on... A mk octo of same weight draws only 35Amps, are they comparable ? Imo, HK is not a source of good motors in this moment for multicopters. Batteries, ESCs, and nothing more. For FC, frames and motors they are late to the show, and lame as offer. The only I would be curious to try is the last model stocked, from iflightrc, this: http://www.hobbyking.com/hobbyking/s...tor_Motor.html But the 3mm axis and lack of a serious prop mount make it also not attractive... So far, at an average price, the best I see is this: http://www.bevrc.com/ax2810q-kv750-h...otor_p413.html Received Monday a 6 units set and will test them this weekend. So far, visually they looks good. |
Joined Sep 2007
Not the legs breaks, but the clips to body pipes.
I'm looking forward to see the test results. Jorn |
| Thread Tools | |
| New Product NEW Carbon-Glass-Alu SCORPIO Mini HEXA Frame (WITH PLANS) | mifau | Multirotor Talk | 49 | Mar 05, 2013 01:40 PM |
| Sold RC Carbon Y-6 Carbon Fiber Folding Frame | Adidas4275 | Aircraft - Electric - Multirotor (FS/W) | 2 | Apr 22, 2012 10:44 PM |
| For Sale Hexa Glass Fiber Frame for DIYer (without power unit) | kevinlib | Aircraft - Electric - Multirotor (FS/W) | 11 | Apr 14, 2012 10:48 AM |
| Discussion carbon fiber frame vs fiber glass frame? | ChatXT | Multirotor Talk | 1 | Feb 09, 2012 02:38 AM |
| For Sale TRex 450 Frame Carbon Fiber CNC full frameset | MJW2006 | Aircraft - Electric - Helis (FS/W) | 2 | Sep 25, 2007 05:12 PM |
