Old May 21, 2012, 11:10 AM
xDennis is offline
Find More Posts by xDennis
Joined Jul 2009
Can Nitro fuel pump be used in my gas setups?
I'm converting to Gas. I have a manual fuel pump to pump from the nitro to the tank. I was wondering if I can also use this to pump my gas to my gas tanks.
Is there a specific cleaning method I should use, and or should I just purchase a new one?
How safe are electric pumps with gas setups?
Dennis
xDennis is offline Find More Posts by xDennis
Old May 21, 2012, 11:31 AM
countilaw is offline
Find More Posts by countilaw
Joined Jan 2012
Some pumps willl work fine with gasoline but some won't. The cheap Chinese pumps may not use rubber products that will stand up to petroleum products. Robart had a pump out called the "six shooter" that would work. The rubber tube was more plastic than rubber and since it's mechanical no worries with a spark.
If you want an electric pump, you can find 12 v fuel pumps for cars at Summit Performance Parts. You will need one that has a outlet presure of 12 lbs or less.
Frank
countilaw is offline Find More Posts by countilaw
Reply With Quote  (Disabled)
Old May 22, 2012, 08:53 AM
xDennis is offline
Joined Jul 2009
Sounds good. I've got one of those el cheapo tower pumps.
Old May 22, 2012, 06:56 PM
Fokker DII is offline
Find More Posts by Fokker DII
Gas Only
Fokker DII's Avatar
USA So. Cal.
Joined Sep 2010
I have a Dubro that is good for either fuel. Do not use it back and forth though!
Fokker DII is offline Find More Posts by Fokker DII
Old May 23, 2012, 06:44 PM
epoxyearl is offline
Find More Posts by epoxyearl
Bellanca Kruesmaster
epoxyearl's Avatar
United States, MD, Elkton
Joined Oct 2011
pumping station
I have twp pumps that transfer gas...The black one from Tower Hobbies is a pair of gears,that will pump most any fluid.I use it for gasoline,and smoke oil.
The Dave Brown Six-Shooter is a very versatile pump..The tubing allows many different fluids also,and it moves a lot of it !
epoxyearl is offline Find More Posts by epoxyearl
Discussion Can a RX battery be used in combination with a BEC? twinster2 Power Systems 8 Mar 23, 2012 04:52 PM
Sold Electric fuel pump 2.5 Gal Kerosene Can zzr Aircraft - General - Miscellaneous (FS/W) 7 Mar 10, 2012 04:00 PM
For Sale Fuel hand pump, gas or glow Full Spool Aircraft - General - Miscellaneous (FS/W) 6 Oct 12, 2011 05:32 AM
Question Can a Gas engine Propeller be used with a Electric Motor? DL8698 Beginner Training Area (Aircraft-Electric) 18 Sep 23, 2011 10:58 AM
Discussion Wich synthetic oil i can use to mix with my 20% nitro fuel ? DjRedFoxx Engines 37 Jul 20, 2010 02:18 AM
