Old May 21, 2012, 09:54 AM
Tom.in.Maryland is offline
Find More Posts by Tom.in.Maryland
Tom.in.Maryland's Avatar
United States, DC, Washington
Joined Mar 2012
What effect does monokote covering have on influencing the CG
I have done a rough balance of a Great Planes PT60 and it seems to balance correctly un-covered, I was wondering what effect monokote will influence the weight?
See Pic
Tom
Tom.in.Maryland is offline Find More Posts by Tom.in.Maryland
Old May 21, 2012, 10:52 AM
JohnGilmore is offline
Find More Posts by JohnGilmore
Joined May 2012
I've done a pre-covering rough balance on most of my planes. It seems (if memory serves) that the CG will move a bit to the rear. I usually add trim to the fin/rudder and stab/elevator - both sides. And fuse side trim all the way to the fuse end. (I use Ultracote).
JohnGilmore is offline Find More Posts by JohnGilmore
Old May 21, 2012, 01:59 PM
NACA0012 is offline
Find More Posts by NACA0012
Joined Mar 2012
I see your engine has no prop or spinner on it, so that will give you some room to work with too. The APC's are heavy, MAS's less so, and woods are usually pretty light.
When I'm as close as you are, I start to fine tune the CG with things like wheel selection (ex. Sullivan Skylight vs heavier rubber vs very light foam)
Did you lay some pushrods in the fuselage? They weigh too. Nylon tail skids, horns/bolts and other bits of hardware do add up too.
NACA0012 is offline Find More Posts by NACA0012
Old May 21, 2012, 03:26 PM
Joined May 2012
Oh yea - APC props in the 11 / 12 inch range weight 1.7 to 1.9 oz. Whereas a wood prop like a Zinger or MAS weigh in at .7 to .9 oz. - a full oz. difference. Harry Higley sells hubs & mini-spinners with or without a locking nut. You can add up to 3.0 oz. with the heavy bits. There is a debate - how detrimental is weight that is added to the engine's crank.
Old May 21, 2012, 10:18 PM
psmith36 is offline
Find More Posts by psmith36
psmith36's Avatar
United States, CA, Bakersfield
Joined Jan 2012
Thats a great plane your gonna love it. I have a pt40 (not the mkII) that i built roughly 15 yrs ago. I finally joined a club and have some time to fly know at 36 yrs old. The plane flies great. I would suggest you go with the bolt on wing if it's not to late. I wish mine was bolt on.
psmith36 is offline Find More Posts by psmith36
Old May 21, 2012, 10:30 PM
Joined May 2012
Never too late to convert to bolt down wing. The exercise will just give you an excuse to update the covering.
Old May 22, 2012, 08:35 AM
Oberst is offline
Find More Posts by Oberst
Oberst's Avatar
Lacona, NY
Joined Dec 2009
That's very true John, but me personally I like the old fashon rubber bands. It kind of gives it that nostalgic look to it.
Pete
Oberst is offline Find More Posts by Oberst
Old May 22, 2012, 09:46 AM
Joined May 2012
Pete - I'm not sure that there's a cure for what you have.
Old May 26, 2012, 09:17 AM
Oberst is offline
Oberst's Avatar
Lacona, NY
Joined Dec 2009
There is no cure for opinion.
Pete
Old May 26, 2012, 02:29 PM
abenn is offline
Find More Posts by abenn
Letchworth, Great Britain (UK)
Joined Jul 2004
Most of the surface area of the model is behind the c of g, so covering it will add more weight to the rear than it does to the front. So, it will get tail-heavy when you cover it, if it was balancing without covering.
abenn is offline Find More Posts by abenn
Old May 27, 2012, 09:33 PM
Joined May 2012
Thanks of an "on topic" post. I second what you said.
Old Jun 03, 2012, 09:34 PM
Joined Mar 2012
This is the completed model PT60 it balanced to the CG of 4 1/8" just fine.
Old Jun 04, 2012, 08:43 AM
RC Trainer plane is offline
Find More Posts by RC Trainer plane
Balsa builder and balsa basher
RC Trainer plane's Avatar
Joined Apr 2012
looks great
RC Trainer plane is offline Find More Posts by RC Trainer plane
Old Jun 05, 2012, 03:53 PM
flycatch is offline
Find More Posts by flycatch
United States, CA, Barstow
Joined May 2004
Your kidding?
flycatch is offline Find More Posts by flycatch
Old Jun 05, 2012, 03:56 PM
Joined Apr 2012
Originally Posted by flycatch View Post
Your kidding?
me ?
Poll Does Paint or Vinyl look better on Fabric Covering Vapor Trails Painting and Finishing Tips 19 Oct 22, 2013 09:45 AM
Help! What effect does changing the propellor have? papabearflying Electric Plane Talk 8 May 09, 2012 02:02 AM
Question What effect does a 'windmilling' prop have? UlteriorModem Electric Sailplanes 23 Oct 03, 2011 05:22 PM
Question What effect does CG have? Bugman Jeff Electric Heli Talk 6 Dec 14, 2010 12:11 PM
what effect does chord length have on wing characteristics? Ben74 Power Systems 6 Jul 24, 2001 02:31 AM
