Old May 20, 2012, 09:21 PM
klhoard is offline
Find More Posts by klhoard
Collierville, TN
Joined Aug 2003
Why not more Propeller projects?
Kinda new to this stuff, curious why more guys don't use the Propeller chip?
klhoard is offline Find More Posts by klhoard
Old May 26, 2012, 12:09 PM
Wrend is offline
Find More Posts by Wrend
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
From what I can tell, it seems less approachable.
And what about interrupts?
Wrend is offline Find More Posts by Wrend
Old May 27, 2012, 03:36 PM
klhoard is offline
Collierville, TN
Joined Aug 2003
No interrupts, but you have eight processors (cogs) running simultaneously. 32K RAM. I got a kit from Parallax for $99 to learn it.
Old May 29, 2012, 06:28 PM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Yeah, it's my understanding that you can have one of the eight, or perhaps more, waiting to read inputs while the others run the rest of the program (programs?).
I'm trying to read 14 channels from an RX using interrupts on the Mega 2560, storing the values, and "relaying" them to output servo signals, or to activate different functions of the program, so I don't think the Propeller would work well for my main intended use.
That aside, the Propeller does have a lot to offer, in many ways more than the Arduinos. Generally speaking, I think the main reasons Arduinos are so widely used are that they're easier to use since there's less to set up with them and they tend to initially be more of a complete solution for hobbyists. It's pretty easy to get started with them and use them. If people stay with it, I can see them easily "graduating" to other microcontrollers that might be more capable for some uses.
Old May 29, 2012, 07:47 PM
klhoard is offline
Collierville, TN
Joined Aug 2003
I'm on vacation this week, but have been reading the books. The good thing I've found is that Parallax puts their books online for free.
Each Cog has two independent timers that you can set to time the pulses. I haven't been able to play with this yet, but I plan on doing something similar, reading pulses from a receiver.
Old May 30, 2012, 01:42 AM
Wrend is offline
どうもありがとうミスターロボット
Wrend's Avatar
United States, IL
Joined Jul 2009
Ah, OK. Let me (us?) know how it goes. Some more people might want to give it a try then, if it works well for this kind of application.
Old May 31, 2012, 06:56 PM
hornet_dave is offline
Find More Posts by hornet_dave
hornet_dave's Avatar
USA, IA, Cedar Rapids
Joined May 2003
I think the two downsides of the prop are a lack of ADC's and the learning curve for passing values between cogs; it takes a bit of learning to figure things out but its not impossible by any means. For simpler tasks, the arduino is far easier to use.
As far as reading RC channels is concerned, if your channels are always produced in a sequential manner, the prop should be able to measure them on a single cog. If they are being produced in a random order, that becomes more difficult, i wasnt able to read the pins fast enough using spin to get accurate pulse width values.
Im a complete amateur with these things, my microcontroller experience is comprised entirely of three motion control hobby projects, one using an hc6811 and assembly, the next a propeller using spin, and the last is an arduino using wiring. So take this all with a grain of salt.
hornet_dave is offline Find More Posts by hornet_dave
Discussion Design idea for motor mount - why is this not used more often? TheZero Multirotor Talk 4 Dec 05, 2011 11:23 AM
Why not more Jet models? PhilLin Electric Plane Talk 22 Dec 03, 2003 08:01 PM
An Apology.......(or why you should not bite off more than you can chew) Steve McBride Electric Plane Talk 16 Jan 24, 2003 09:42 PM
Full Tip Plates, why do I not see more? rparigoris Power Systems 4 May 14, 2002 12:20 PM
