Old May 20, 2012, 10:29 AM
blueman is offline
Find More Posts by blueman
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Build Log
FSW EDF 50mm
Hello all, I think it's been about 7 years since I've been here on rc groups. Been busy and kinda fell out of the hobby. So this is what I am building to get back into the air. A custom eye-balled FSW with a Dons RC Wemotec/5400kv/30 amp esc/ 3cell -800mahx 2ea in parallel. Should burn a whole in the sky, I hope. A little dodgy on how to figure out the CG though, any input would be greatly appreciated, anything to help me from burying this in the dirt in 5 seconds.
blueman is offline Find More Posts by blueman
Old May 20, 2012, 02:13 PM
ApexAero is offline
Find More Posts by ApexAero
Aka: Tom Jenkins
ApexAero's Avatar
United States, FL, West Palm Beach
Joined Aug 2008
Blue man I can calculate your CG for you if you tell me the wing span, root, and tip measurements. Also accurate sweep measurement on main wing at leading edge. I'll volunteer.
ApexAero is offline Find More Posts by ApexAero
Old May 20, 2012, 08:27 PM
clinth01 is offline
Find More Posts by clinth01
Vertical Arrival Specialist
clinth01's Avatar
Townsville, Australia
Joined Sep 2009
Blueman
Try this one. Select the 'Calculate CG' page and just follow your nose - it's pretty straight forward and intuitive.
Download and then rename the file extension fron .txt to .xls before opening (because I can't upload Excel spreadsheets here, but can do text files).
Clint
clinth01 is offline Find More Posts by clinth01
Old May 20, 2012, 08:49 PM
clinth01 is offline
clinth01's Avatar
Joined Sep 2009
Bugger, the upload program is smarter than I thought, and refused to post the attachment.
I'll zip it up and send it from home tonight.
Old May 20, 2012, 11:16 PM
clinth01 is offline
clinth01's Avatar
Joined Sep 2009
There you go Blueman.
Old May 22, 2012, 10:57 PM
ApexAero is offline
Aka: Tom Jenkins
ApexAero's Avatar
Joined Aug 2008
clinth, I couldn't get yours to work. Try this one
Old May 25, 2012, 03:39 AM
blueman is offline
blueman's Avatar
Japan, Tokyo, Fussa
Joined Jul 2003
Sorry for the late reply, work has me jobbin'!
ApexAero- thanks for volunteering your experience/knowledge! I attached a quick drawing with some dimensions. I am not quite sure how to calculate the sweep angle, I dont even have a protractor or anything! haha. Would you happen to know how to calculate with triangles and all that greek math?
I tried plugging in numbers for your FSW CG calc, but the cg keeps coming out to around - .69-ish. That doesn't make sense to me... :P Maybe i need to take into account the center lifting surface from the front of the fan trailing back to the wing itself?
I havent added elevons yet, will I need to account for those as well in the dimensions?
Sold LPU in San Antonio area: 50mm JPower EDF Jets FoamJunkE Aircraft - Electric - Airplanes (FS/W) 2 Jun 20, 2012 06:57 AM
Sold NIB 1.97 50MM EDF Housing warbirdguyn951 Aircraft - Electric - Power Systems (FS/W) 4 May 20, 2012 10:35 AM
Found Need 50mm EDF gasturbineman Aircraft - Electric - Jets (FS/W) 0 Mar 06, 2012 04:15 PM
Sold MB-1, Wemotec 50mm, JPower 50mm edf units FS FoamJunkE Aircraft - Electric - Power Systems (FS/W) 0 Feb 01, 2012 09:09 AM
