| View Poll Results: Is a 15cm (6") aircraft with a 10g payload possible | |||
| yes |
41 | 93.18% |
| no |
3 | 6.82% |
| Voters: 44. You may not vote on this poll | |||
| Thread Tools |
Can't give you a definitive answer. However I can tell you that you will have to "roll your own". AFAIK there are no off the shelf planes in this size. 15 cm is very little so you probably need a something with the largest possible wing area which would be a square. That will give you a wing area of 2.25 dm2. With commercially available equipment you can acheive a 20gram or less AUW (excluding payload). Mind you, that is with equipment that will give you decent range and duration. Add the 10 gram payload and you end up with a wingloading of 13.3 g/dm2 which should work ok. Take a look at this thread for starters - you might just be able to shrink the Drenalyn and make it work.
http://www.rcgroups.com/forums/showt...light=drenalyn Can't help with the hard facts for the database - I'm more of a "that looks about right" kinda guy. You could try and contact Matt Keenon who makes MAVs for a living. Michael |
Try this link for Matt's Black Widow information: http://www.aerovironment.com/area-ai...rv/bwidpap.pdf
Check this site out
http://www.aeronutz.flyer.co.uk/ and than this one too http://www.smarttoolsinc.com |
Joined Jan 2003
Hi
I have been flying electric aircraft exclusively for the last 4yr. You will probably want to go with the rffs-100 system, utilize lithium-polymer batteries. I have seen the skeeter micro plane that uses the rffs-100 and it flys very well. You can get more info at www.slowfly.com on this system. I am assuming that the system needs to be proportional. The rffs-100 system utilizing the actuators is extremely light. Are you wing area limited?? If not consider a biplane or a tandem wing platform utilizing contra rotating inline props similar to the do-335 this will relieve torque problems and allow a larger disk area for better power transfer, of course remembering that more motors requires more availiable power which causes more weight which requires either higher speed or more area. Last but not least, parasitic drag on small aircraft is a killer so keep it to a min. Boy what a balancing act. Hope this helps |
Houston, Texas
Joined Nov 2001
Micro Air Vehicle Project
I took a quick look at the references that others have provided and there is one additional reference that I would like to recommend. It is Radio Control MicroFlight and their URL is:
<http://www.rcmicroflight.com/> Someone else has already provided the URL to the only other web site that I would recommend in this instance and that is: <http://www.aeronutz.flyer.co.uk/> Good luck and God speed on your project. I would appreciate it if you would occasionally inform us of your progress and further information needs. Bryan Swinney |
| Thread Tools | |
| Micro air Vehicle propulsion system | charles27 | UAV - Unmanned Aerial Vehicles | 7 | Jul 31, 2005 01:05 AM |
| WASP Micro Air Vehicle | nanoflite | Indoor and Micro Models | 3 | Apr 07, 2005 09:13 PM |
| Micro Air Vehicle Science Project | KatanaGuy | Indoor and Micro Models | 11 | Sep 07, 2003 08:31 PM |
| Build a WASP Micro Air Vehicle!? | Nowell York | Electric Plane Talk | 16 | Mar 04, 2003 09:01 PM |
| DARPA's Micro Air Vehicle has batteries for wings.... | Steve McBride | Batteries and Chargers | 0 | Dec 31, 2002 01:17 PM |
