Old May 20, 2012, 09:17 AM
jktravis is offline
Find More Posts by jktravis
jktravis's Avatar
United States, KY, Somerset
Joined Aug 2011
Blade 450 3D "Idle" Issue
Hey all. Not sure if there is a better spot for this and couldn't find good keywords to hone down my search.
I recently purchased a Blade 450 3D on eBay. Everything seems to work okay, but at bottom throttle/pitch stick the thing seems to want to "idle". The throttle curve for the respective flight mode bottoms out at 0%. I'm having to use ~5 clicks worth of trim to keep it from spinning up in this mode. What I find just as interesting is the throttle hold mode is set at -0% at all points and the motor doesn't spin at all (as expected.)
Being that this is electric, is this normal for the B450? Can I fix this somehow? I can't go negative throttle on that flight mode.
jktravis is offline Find More Posts by jktravis
Old May 20, 2012, 09:28 AM
wparsons is offline
Find More Posts by wparsons
wparsons's Avatar
Canada, ON, Whitby
Joined Aug 2008
What do the throttle and pitch curves look like for all modes? What TX are you flying with?
wparsons is offline Find More Posts by wparsons
Old May 20, 2012, 09:42 AM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
I'm using a DX6i.
Throttle Curves
Norm: 0.0, 56.5, 72.5, 72.5, 72.5
Stunt: 72.5, 72.5, 72.5, 72.5, 72.5
Hold: -0.0, -0.0, -0.0, -0.0, -0.0
Pitch Curves
Norm: 45.0, 51.0, 60.0, 73.5, 91.0
Stunt: 0.0, 25.0, 50.0, 75.0, 100.0
Hold: 0.0, 25.0, 50.0, 75.0, 100.0
Old May 20, 2012, 10:24 AM
mdugas is offline
Find More Posts by mdugas
Joined Aug 2003
hi ,sounds like you need to do the calibrate esc to thottle range bit
mdugas is offline Find More Posts by mdugas
Old May 20, 2012, 10:28 AM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
Hmm...I hadn't heard of doing that. I'm sure all ESCs are different, too. To the sleuth-mobile!
Old May 20, 2012, 11:02 AM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
Well that was simple enough!
  1. Full throttle stick
  2. Plug in battery
  3. Wait for beeps
  4. Lower throttle stick
  5. Profit!
Thanks!
Old May 23, 2012, 09:28 PM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
Well, I just noticed that programming the ESC this way only corrected the problem until power loss. Once I disconnected the battery and plugged it back up again, the problem was evident again. I don't have the heli at the moment, but I'm thinking of trying to rebind it and see if that helps.
Old May 23, 2012, 09:46 PM
Skidpad is offline
Find More Posts by Skidpad
United States, NC, Winston-Salem
Joined Dec 2011
Try and re-bind and low-stick; let us know how it goes.
Skidpad is offline Find More Posts by Skidpad
Old May 24, 2012, 07:31 AM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
It looks like re-binding [tentatively] fixed it. I say tentatively because I thought it was fixed before. I suppose I may have accidentally nudge the throttle when I was binding the last time.
Thanks for the responses.
Old May 24, 2012, 12:06 PM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
/sigh
I re-bound the thing, turned off both the TX and heli, powered on the TX, then powered on the heli. At first, everything worked as expected. I get the thing out to the park, power everything up again, turn off TH, and the damn thing spins-up.
Old May 25, 2012, 02:42 AM
Roto Rob is offline
Find More Posts by Roto Rob
Denver, CO
Joined Dec 2005
The DX6i has an offset between Throttle Hold, and Normal mode. So if you plug in the lipo while in Throttle Hold the esc will see a higher throttle point when you switch to Normal mode. To fix this you can plug in while in Normal Mode. Or go to the monitor screen, and increase the Throttle Hold percentage until the Normal Mode's 0 matches Throttle Holds 0. Should be some where around 17%. If you have anything that can read the receivers signal, like some servo/esc programmers, or an oscilloscope you can get it exact.
Roto Rob is offline Find More Posts by Roto Rob
Old May 25, 2012, 01:03 PM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
Interesting. So I presume this is why they [Horizon Hobby] recommend using 10% throttle on throttle hold. I was wondering about that. I haven't had a chance to try it yet, but I'll be sure to post back when I do.
Old May 25, 2012, 03:22 PM
jktravis is offline
jktravis's Avatar
Joined Aug 2011
Thanks! Using the monitor to close the gap between throttle hold and normal mode seems to have corrected this issue.
Last edited by jktravis; May 25, 2012 at 03:33 PM. Reason: correcting non-sensical statements
Old May 25, 2012, 08:01 PM
Roto Rob is offline
Denver, CO
Joined Dec 2005
Yes, they recommend 10%. Not all of the transmitters are the same. The early ones are closer to 17%, I think most of the newer ones are around the 10% offset.
This matters mostly when you have an ESC that autodetects low throttle on every startup, and you plug in the helicopter while in Throttle Hold.
Discussion Saito 220 4S Idle Issues flycatch Engines 28 Jun 10, 2016 03:14 PM
Discussion Blade 450 3d take off issue diveh2omike Beginner Training Area (Heli-Electric) 9 May 20, 2012 09:44 AM
Discussion Blade 450 3D / Trex Blades interchange? jrjr Electric Heli Talk 3 Apr 28, 2012 07:07 PM
Sold Blade SR and Blade 450 3d Free UPS Shipping Canada only Nerm Aircraft - Electric - Helis (FS/W) 8 Mar 25, 2012 10:44 AM
For Sale RTF blade 450 3d and BNF Blade MCPX stafphoto Aircraft - Electric - Helis (FS/W) 4 Mar 13, 2012 02:11 PM
