Old May 20, 2012, 07:37 AM
HiTekCub1 is offline
Find More Posts by HiTekCub1
United States, IL, Belvidere
Joined May 2012
Controlling torque roll
Hoping that the wisdom out here can help me. Got a YB-22 Park model and it's a ton of fun except for the excessive torque roll to the left at about 3/4 to full throttle. Am using 1300 3cell, DS6i, 7x5 prop. I did program about 40% expo in it. With the 7x5 prop the torque roll is insane and after a few tries I don't dare run it much beyond half throttle. I added a couple of finishing nail in the right wing as the manual suggests but no change. I went to a 6x4 prop and it was a little better but still I cannot give it enough right stick (turn) to counteract the roll. Anybody out here have any ideas? Thanks in advance!!
HiTekCub1 is offline Find More Posts by HiTekCub1
Old Jun 01, 2012, 01:46 PM
El Hefe is offline
Find More Posts by El Hefe
Joined Dec 2009
What is the motor KV?
El Hefe is offline Find More Posts by El Hefe
Old Jun 01, 2012, 04:51 PM
Joined May 2012
2200kv
Old Jun 01, 2012, 05:06 PM
El Hefe is offline
Joined Dec 2009
2200KV with a 7X5 is a little much for the YB's. You should go with a smaller prop with less pitch.
Old Jun 01, 2012, 06:56 PM
Joined May 2012
I ended up with a 5x5 that seems to work ok. Tried a 6x4 & still a lot of torque roll. The 5x5 seems a litttle weak though
Old Jun 02, 2012, 09:14 AM
El Hefe is offline
Joined Dec 2009
The Full size YB's were designed around the 1700KV motor and a 7X5 APC. 2200KV and 5X5 May give you better top speed but less vert.
Old Jul 25, 2012, 01:58 AM
whitebearcvv is offline
Find More Posts by whitebearcvv
Joined Jul 2012
2200kv
whitebearcvv is offline Find More Posts by whitebearcvv
Reply With Quote  (Disabled)
Old Sep 08, 2012, 08:02 PM
ChrisS is offline
Find More Posts by ChrisS
Really?!?
ChrisS's Avatar
Lost ...on the 3rd rock out
Joined Sep 2001
I too have this problem, but on a different airframe. It's an Radical Rc Hornet with a Great Planes Ammo 28-45-3600 motor swinging a Graupner 5X5 prop at like 32000 rpm on a 3 cell pack. The torque roll at full tilt is enough to roll the plane with just a bit less force than full opposite aileron can overcome. I used a program mix of throttle to aileron to overcome this but of course that is just adding drag whick slows the plane...What else can be done, besides letting off the throttle?
Chris
ChrisS is offline Find More Posts by ChrisS
Discussion Torque-induced roll w/ HK Tuff Trainer doughpat Beginner Training Area (Aircraft-Electric) 18 Dec 10, 2013 08:17 AM
Discussion rc phoenix +torque Roll smiley007 Simulators 1 Mar 28, 2012 10:17 AM
Discussion 3d jets torque roll igorp Fuel Jet Talk 9 Jan 29, 2012 11:20 PM
Discussion Torque Roll Kai Wren RC Hovercraft 4 Jan 20, 2012 01:56 PM
