Old May 19, 2012, 02:30 PM
count74 is offline
Find More Posts by count74
Germany, SL, Rehlingen-Siersburg
Joined Sep 2011
Help!
Yaw problem with HK KK Board V2.1, KK firmware 4.7
Hi,
the controller mentioned above worked fine before, but was lying in its box for a while. Now I installed it in my H-Quad and started to test everything, when I noticed the motors only react to left yaw input and counteract right (CW) yaw rotation only. Pitch and roll work as expected.
I would be very thankful for any ideas.
Count
count74 is offline Find More Posts by count74
Old May 21, 2012, 03:29 PM
mattcro is offline
Find More Posts by mattcro
KK Tri Flyer
mattcro's Avatar
United Kingdom, Scotland, Glasgow
Joined Feb 2012
Do you have 2 motors spinning faster than the other pair (aka lazy motor)? You might need to add some rudder subtrim until the motor speeds balance out. Check if you have some trim/subtrim on the pitch/roll, and add a similar amount for rudder.
mattcro is offline Find More Posts by mattcro
Old Jul 18, 2014, 03:37 PM
broty is offline
Find More Posts by broty
Belgium, Walloon Region, Andenne
Joined Apr 2012
what about a double check on the direction of each motor spinning?
broty is offline Find More Posts by broty
Rave HK KK V2 Quad board (and other recent KK boards) randall1959 Multirotor Electronics 2584 Aug 11, 2014 02:01 PM
Discussion KK 4.7+ Yaw problem SatelliteBiker Multirotor Talk 11 May 11, 2012 12:42 PM
Discussion Hobbyking KK board Yaw problem dmcke5 Multirotor Talk 4 Mar 27, 2012 11:38 PM
Help! Problem with HK board v2.1 Arxangel Multirotor Talk 3 Feb 24, 2012 05:37 PM
Discussion [tricopter] yaw mechanism KK board problem?(video) abriosi Multirotor Talk 2 Nov 14, 2011 03:13 PM
