Old May 19, 2012, 04:51 AM
ldmx88 is offline
Find More Posts by ldmx88
Joined May 2012
GSR260Z Assembly Kit w/Engine RC helicopter
Overall length : 1,623mm
Overall width : 380mm
Overall height : 704mm
Gross weight : 7,800g or more (with Main rotor blade)
Main rotor diameter : 1,765mm (JRC800)
Tail rotor diameter : 288mm
Gear Ratio : 8:1:5.18
Swash type : 120 CCPM/MPM (Option
Items included
Engine G260PUH・1 (with muffler)
JRC800 Carbon
Assembly Manual
Hex Wrench (1.5mm/2mm/2.5mm/3mm)
Thread Lock (Soft/Hard)
Items needed to fly
5-Channel or greater helicopter RC system with CCPM and 5 servos
* When MPM system is used,Itís not required to have CCPM-compliant radio.
Gyro system (G770T,G750T,G7000T etc.)
Servo horn
* Not necessary if supplied with your radio set.
* Big Horn 3pcs and Super Horn 1psc are included.
・Radius of 27mm (for CCPM) 3pcs
・Radius of 10.5mm (for MPM) 3pcs
・Radius of 14-17mm (for Rudder) 1pc
・Radius of 12.5mm (for Throttle) 1pc
* If you wish to use MPM system,please purchase following item.
MPM conversion set [No.61211]
Lead harness [No.04634] 2-3 pcs
* Check your gyro for required quantity
Fuel:Gasoline and Engine oil for two-cycle engine. [No.55100,Engine oil 1,000cc]
Engine starting tool:
Starting rod [No.60227],Starter and Power supply are needed when shaft starter is used.
If you use Fuel pump,please use the one with gasoline resistant.
Tools Required For Assembly
Phillips Screwdriver (Large/Small)
Nut Drivers (4mm-12mm)
Needle-nose pliers
Drils (3mm/4mm/6mm)
Metric rule (300mm or longer)
Scissors
Hobby knife
Quick Drying Glue
Epoxy Resin (30 minutes)
JR Thrust bearing Grease [No.61005]
Spray bottle
JR Universal Precision Pitch Gauge [No.60326]
Other general tools for assembling model helicopter
Useful Tools
JR Universal Ball Link Driver [No.61360]
JR Universal Ball Link Sizing Tool [No.60219]
JR Universal Ball Link Pliers C (Straight Tip) [No.60242]
Box drivers (4.5mm/5mm/5.5mm)
Hex drivers (1.5mm/2mm/2.5mm/3mm/4mm)
Reamer or Stepped reamer
Rotor balancer
ldmx88 is offline Find More Posts by ldmx88
Old Sep 04, 2012, 08:31 AM
aPetrov is offline
Find More Posts by aPetrov
Joined Sep 2012
i Buy http://www.vivetango.de/page18.php
aPetrov is offline Find More Posts by aPetrov
For Sale LPU75% Done RC Skyshark JU-87B Stuka kit w/engine, servos, & hardware - $500 (Dallas) Carlo182 Aircraft - Fuel - Airplanes (FS/W) 0 Apr 08, 2012 09:16 PM
Video 2011 HeliFreak Rc Helicopters Fun Fly Highlights w/ HobbyPartz hobbypartz Electric Heli Talk 0 Oct 12, 2011 10:52 PM
Discussion Detrum 450 RC Helicopter Brushless Upgrade Combo System w/ 3600KV $49.70 hobbypartz Hot Online Deals 0 Oct 05, 2011 02:59 PM
Discussion New Syma S027 Big Fire Wolf 3 Channel Airwolf Ready-to-Fly RC Helicopt james1300 Coaxial Helicopters 3 Apr 21, 2011 02:35 AM
